实测 ubuntu 20.04 使用 lidar_imu_calib 功能包 进行 激光雷达与imu标定
月照银海似蛟龙 发表于 2022/09/02 14:35:14 2022/09/02
【摘要】 功能包介绍功能包名称:lidar_imu_calib功能包简介:在基于3D激光雷达开发slam时,我们经常使用imu为匹配算法(icp, ndt)提供先验,所以需要校准lidar和imu之间的变换。对于匹配算法,transfom中的姿态比transform中的位置更重要 , 并且位置通常设置为 0。所以这个功能包只校准激光雷达和 imu 之间转换中的姿态分量。功能包地址:https://g...
功能包介绍
功能包名称:
lidar_imu_calib
功能包简介:
功能包地址:
https://github.com/chennuo0125-HIT/lidar_imu_calib
功能包下载与编译
安装步骤:
mkdir -p catkin_ws/src
cd catkin_ws/src
git clone https://github.com/chennuo0125-HIT/lidar_imu_calib.git
cd ..
catkin_make -DCATKIN_WHITELIST_PACKAGES="ndt_omp;lidar_imu_calib"
此时会出现报错问题
报错内容:
/usr/include/pcl-1.10/pcl/common/impl/io.hpp: In function ‘void pcl::copyPointCloud(const pcl::PointCloud<PointT>&, const std::vector<pcl::PointIndices>&, pcl::PointCloud<PointOutT>&)’:
/usr/include/pcl-1.10/pcl/common/impl/io.hpp:272:16: error: use of ‘auto’ in lambda parameter declaration only available with ‘-std=c++14’ or ‘-std=gnu++14’
  272 |       [](const auto& acc, const auto& index) { return index.indices.size() + acc; });
/usr/include/pcl-1.10/pcl/common/impl/io.hpp:272:33: error: use of ‘auto’ in lambda parameter declaration only available with ‘-std=c++14’ or ‘-std=gnu++14’
/usr/include/pcl-1.10/pcl/common/impl/io.hpp: In lambda function:
/usr/include/pcl-1.10/pcl/common/impl/io.hpp:272:61: error: request for member ‘indices’ in ‘index’, which is of non-class type ‘const int’
In file included from /usr/include/pcl-1.10/pcl/io/pcd_io.h:44,
                 from /home/jone/jone_ws/src/lidar_imu_calib/lidar_imu_calib/src/lib/calibExRLidar2Imu.cpp:5:
/usr/include/pcl-1.10/pcl/io/file_io.h: At global scope:
/usr/include/pcl-1.10/pcl/io/file_io.h:235:8: error: ‘enable_if_t’ in namespace ‘std’ does not name a template type; did you mean ‘enable_if’?
  235 |   std::enable_if_t<std::is_floating_point<Type>::value>
      |        enable_if
/usr/include/pcl-1.10/pcl/io/file_io.h:252:8: error: ‘enable_if_t’ in namespace ‘std’ does not name a template type; did you mean ‘enable_if’?
  252 |   std::enable_if_t<std::is_integral<Type>::value>
      |        enable_if
/usr/include/pcl-1.10/pcl/io/file_io.h:266:18: error: expected initializer before ‘<’ token
  266 |   copyValueString<std::int8_t> (const pcl::PCLPointCloud2 &cloud,
/usr/include/pcl-1.10/pcl/io/file_io.h:280:18: error: expected initializer before ‘<’ token
  280 |   copyValueString<std::uint8_t> (const pcl::PCLPointCloud2 &cloud,
/usr/include/pcl-1.10/pcl/io/file_io.h:304:8: error: ‘enable_if_t’ in namespace ‘std’ does not name a template type; did you mean ‘enable_if’?
  304 |   std::enable_if_t<std::is_floating_point<Type>::value, bool>
      |        enable_if
/usr/include/pcl-1.10/pcl/io/file_io.h:317:8: error: ‘enable_if_t’ in namespace ‘std’ does not name a template type; did you mean ‘enable_if’?
  317 |   std::enable_if_t<std::is_integral<Type>::value, bool>
      |        enable_if
^CIn file included from /usr/include/c++/9/algorithm:62,
                 from /usr/include/boost/smart_ptr/shared_ptr.hpp:39,
                 from /usr/include/pcl-1.10/pcl/pcl_macros.h:69,
                 from /usr/include/pcl-1.10/pcl/point_types.h:42,
                 from /home/jone/jone_ws/src/lidar_imu_calib/lidar_imu_calib/include/calibExRLidar2Imu.h:9,
                 from /home/jone/jone_ws/src/lidar_imu_calib/lidar_imu_calib/src/lib/calibExRLidar2Imu.cpp:1:
/usr/include/c++/9/bits/stl_algo.h: In instantiation of ‘_OIter std::transform(_IIter, _IIter, _OIter, _UnaryOperation) [with _IIter = __gnu_cxx::__normal_iterator<const pcl::Vertices*, std::vector<pcl::Vertices> >; _OIter = std::back_insert_iterator<std::vector<pcl::Vertices> >; _UnaryOperation = pcl::PolygonMesh::concatenate(pcl::PolygonMesh&, const pcl::PolygonMesh&)::<lambda(int)>]’:
/usr/include/pcl-1.10/pcl/PolygonMesh.h:55:24:   required from here
/usr/include/c++/9/bits/stl_algo.h:4343:24: error: no match for call to ‘(pcl::PolygonMesh::concatenate(pcl::PolygonMesh&, const pcl::PolygonMesh&)::<lambda(int)>) (const pcl::Vertices&)’
 4343 |  *__result = __unary_op(*__first);
In file included from /usr/include/pcl-1.10/pcl/common/io.h:50,
                 from /usr/include/pcl-1.10/pcl/filters/filter.h:43,
                 from /usr/include/pcl-1.10/pcl/filters/voxel_grid.h:43,
                 from /home/jone/jone_ws/src/lidar_imu_calib/lidar_imu_calib/include/calibExRLidar2Imu.h:11,
/usr/include/pcl-1.10/pcl/PolygonMesh.h:45:22: note: candidate: ‘pcl::PolygonMesh::concatenate(pcl::PolygonMesh&, const pcl::PolygonMesh&)::<lambda(int)>’
   45 |                      [point_offset](auto polygon)
/usr/include/pcl-1.10/pcl/PolygonMesh.h:45:22: note:   no known conversion for argument 1 from ‘const pcl::Vertices’ to ‘int’
In file included from /usr/include/c++/9/numeric:62,
                 from /usr/include/boost/random/discrete_distribution.hpp:18,
                 from /usr/include/boost/random.hpp:63,
                 from /usr/include/pcl-1.10/pcl/filters/boost.h:48,
                 from /usr/include/pcl-1.10/pcl/filters/voxel_grid.h:42,
/usr/include/c++/9/bits/stl_numeric.h: In instantiation of ‘_Tp std::accumulate(_InputIterator, _InputIterator, _Tp, _BinaryOperation) [with _InputIterator = __gnu_cxx::__normal_iterator<const pcl::PCLPointField*, std::vector<pcl::PCLPointField> >; _Tp = std::__cxx11::basic_string<char>; _BinaryOperation = pcl::getFieldsList(const pcl::PCLPointCloud2&)::<lambda(const int&, const int&)>]’:
/usr/include/pcl-1.10/pcl/common/io.h:144:82:   required from here
/usr/include/c++/9/bits/stl_numeric.h:166:22: error: no match for call to ‘(pcl::getFieldsList(const pcl::PCLPointCloud2&)::<lambda(const int&, const int&)>) (std::__cxx11::basic_string<char>&, const pcl::PCLPointField&)’
  166 |  __init = __binary_op(_GLIBCXX_MOVE_IF_20(__init), *__first);
只截取了其中一段
报错原因:
ubuntu 20.04 的 ros版本是noetic 带的pcl是 pcl-1.10,这个版本和之前的有所不同
这么多错误就一个原因 : pcl-1.10需要用c++14及以上编译。
报错解决方法:
打开 lidar_imu_calib 文件夹下的 CMakeLists.txt
将第五行
add_compile_options(-std=c++11)
换成
add_compile_options(-std=c++14)
即可编译成功
使用功能包
接入雷达和imu
找个电源适配器,9-18v给雷达供电。雷达连接其连接器,网口接到ROS的工控机上即可
将工控机的网口配置为
ipv4,方式设置为手动
ip地址、掩码以及网关设置成下图
其中地址 不能为 192.168.1.201 ,这个是雷达的地址
运行雷达驱动程序
roslaunch velodyne_pointcloud VLP16_points.launch
imu模块的硬件连接很简单,usb给模块供电,并与pc通信,插上后
运行imu驱动程序
roslaunch fdilink_ahrs ahrs_data.launch
通过 rostopic list 指令,检查下消息是 否正确
图片中的/imu /velodyne_points就是两个传感器的消息名称
录制 rosbag 文件
通过
rosbag record /imu /velodyne_points
来录制两个传感器的消息
执行 lidar_imu_calib 功能包
上面的工作主要是给功能包准备数据,下面即可执行功能包了
首先需要 修改 配置文件
相关的参数没有config文件夹的yaml文件,是直接在其launch文件中设置的
将 /lidar_topic 和 /imu_topic 与/bag_file 修改成自己的
之后便可以运行功能包
roslaunch lidar_imu_calib calib_exR_lidar2imu.launch
功能包会显示添加 lidar 消息
最后会显示 lidar的消息数量和imu的数量 形成约束的数量
再等一下就会出现计算的结果
