聊聊Mybatis的binding模块之MapperMethod
周杰伦本人 发表于 2022/08/30 10:56:04 2022/08/30
【摘要】 聊聊Mybatis的binding模块之MapperMethod 构造方法 SqlCommand MapperMethod的执行方法 总结 聊聊Mybatis的binding模块之MapperMethodMybatis的绑定真正操作是通过MapperProxy来调用MapperMethod的execute()方法 构造方法先看一下MapperMethod的构造方法:public Mappe...
构造方法
public MapperMethod(Class<?> mapperInterface, Method method, Configuration config) {
    this.command = new SqlCommand(config, mapperInterface, method);
    this.method = new MethodSignature(config, mapperInterface, method);
构造方法中填充了command属性和method属性,下面我们就看一下这两个属性的填充
SqlCommand
command属性填充的时候通过创建SqlCommand对象来完成。
SqlCommand是用来记录sql语句的唯一标识和sql语句的类型:UNKNOWN, INSERT, UPDATE, DELETE, SELECT, FLUSH
我们看一下SqlCommand类在创建的时候进行了哪些操作,也就是它的构造方法的实现逻辑。
SqlCommand类的构造方法:
public SqlCommand(Configuration configuration, Class<?> mapperInterface, Method method) {
      final String methodName = method.getName();
      final Class<?> declaringClass = method.getDeclaringClass();
      MappedStatement ms = resolveMappedStatement(mapperInterface, methodName, declaringClass,
          configuration);
      if (ms == null) {
        if (method.getAnnotation(Flush.class) != null) {
          name = null;
          type = SqlCommandType.FLUSH;
          throw new BindingException("Invalid bound statement (not found): "
              + mapperInterface.getName() + "." + methodName);
        name = ms.getId();
        type = ms.getSqlCommandType();
        if (type == SqlCommandType.UNKNOWN) {
          throw new BindingException("Unknown execution method for: " + name);
  1. 获取Mapper接口对应的方法名
  2. 获取Mapper接口的类型
  3. 调用resolveMappedStatement()方法返回MappedStatement,MappedStatement是xml文件中的sql解析得到的对象,id是接口名+方法名
  4. 设置name 和type
可以看出SqlCommand类的构造方法主要是对一些属性的填充
而MapperMethod类中保存的是方法的一些信息,下面我们看看它这个类,重点在于下面的执行方法
MapperMethod的执行方法
上面我们说到通过MapperProxy来调用MapperMethod的execute()方法,我们就来看一下MapperMethod的execute()方法
MapperMethod的execute()方法:
public Object execute(SqlSession sqlSession, Object[] args) {
    Object result;
    switch (command.getType()) {
      case INSERT: {
        Object param = method.convertArgsToSqlCommandParam(args);
        result = rowCountResult(sqlSession.insert(command.getName(), param));
        break;
      case UPDATE: {
        result = rowCountResult(sqlSession.update(command.getName(), param));
        break;
      case DELETE: {
        result = rowCountResult(sqlSession.delete(command.getName(), param));
        break;
      case SELECT:
        if (method.returnsVoid() && method.hasResultHandler()) {
          executeWithResultHandler(sqlSession, args);
          result = null;
        } else if (method.returnsMany()) {
          result = executeForMany(sqlSession, args);
        } else if (method.returnsMap()) {
          result = executeForMap(sqlSession, args);
        } else if (method.returnsCursor()) {
          result = executeForCursor(sqlSession, args);
          result = sqlSession.selectOne(command.getName(), param);
          if (method.returnsOptional()
              && (result == null || !method.getReturnType().equals(result.getClass()))) {
            result = Optional.ofNullable(result);
        break;
      case FLUSH:
        result = sqlSession.flushStatements();
        break;
      default:
        throw new BindingException("Unknown execution method for: " + command.getName());
    if (result == null && method.getReturnType().isPrimitive() && !method.returnsVoid()) {
      throw new BindingException("Mapper method '" + command.getName()
          + " attempted to return null from a method with a primitive return type (" + method.getReturnType() + ").");
    return result;
代码看着比较长,但整体的逻辑是很好理解的,下面就带大家分析一下
  1. 根据sql语句的类型进行调用,对应INSERT、UPDATE、DELETE,逻辑都差不多,都是调用convertArgsToSqlCommandParam()方法处理参数,然后调用sqlSession来进行执行sql最后返回的结果通过rowCountResult来进行处理
  2. 对于SELECT语句,根据方法的返回类型选择不同的execute方法执行,最后都是调用SqlSession中的方法
至此,mybatis的binding模块差不多分析完了,大体流程就是MapperRegistry根据不同的Mapper接口获取MapperProxyFactory的实例,然后调用newInstance()方法,利用MapperProxy代理类获取Mapper接口的动态代理对象,最终调用MapperMethod的execute()传入参数和封装的sql对象信息,执行sql语句
