聊聊Mybatis的binding模块
周杰伦本人 发表于 2022/08/30 10:31:54 2022/08/30
【摘要】 聊聊Mybatis的binding模块 映射注册类MapperRegistry 映射代理工厂类MapperProxyFactory 映射代理类MapperProxy 默认方法调用类DefaultMethodInvoker 总结 聊聊Mybatis的binding模块为什么我们在使用Mybatis的时候只需要写接口和xml文件就能执行sql呢?这就是Mybatis的binding模块需要做的...
聊聊Mybatis的binding模块
为什么我们在使用Mybatis的时候只需要写接口和xml文件就能执行sql呢?这就是Mybatis的binding模块需要做的事情了,今天我们分析一下Mybatis的binding模块,binding包下的类主要有四个MapperRegistry、MapperProxyFactory、MapperProxy和MapperMethod
映射注册类MapperRegistry
MapperRegistry是个注册类,它的knownMappers集合保存着Mapper接口和MapperProxyFactory实例的映射关系
它的addMapper()方法就是用来添加映射关系的,我们不妨看一下MapperRegistry类的添加映射的方法的实现逻辑
MapperRegistry的addMapper()方法:
  public <T> void addMapper(Class<T> type) {
    if (type.isInterface()) {
      if (hasMapper(type)) {
        throw new BindingException("Type " + type + " is already known to the MapperRegistry.");
      boolean loadCompleted = false;
      try {
        knownMappers.put(type, new MapperProxyFactory<>(type));
        // It's important that the type is added before the parser is run
        // otherwise the binding may automatically be attempted by the
        // mapper parser. If the type is already known, it won't try.
        MapperAnnotationBuilder parser = new MapperAnnotationBuilder(config, type);
        parser.parse();
        loadCompleted = true;
      } finally {
        if (!loadCompleted) {
          knownMappers.remove(type);
当传入的type是个接口并且knownMappers集合中没有,就把type和对应的MapperProxyFactory实例放入knownMappers集合中
然后在执行sql的时候,Mybatis会调用MapperRegistry.getMapper()方法
  @SuppressWarnings("unchecked")
  public <T> T getMapper(Class<T> type, SqlSession sqlSession) {
    final MapperProxyFactory<T> mapperProxyFactory = (MapperProxyFactory<T>) knownMappers.get(type);
    if (mapperProxyFactory == null) {
      throw new BindingException("Type " + type + " is not known to the MapperRegistry.");
    try {
      return mapperProxyFactory.newInstance(sqlSession);
    } catch (Exception e) {
      throw new BindingException("Error getting mapper instance. Cause: " + e, e);
  1. 先从knownMappers集合中找到对应的MapperProxyFactory实例
  2. 然后调用newInstance()方法
MapperProxyFactory的newInstance()方法:
  public T newInstance(SqlSession sqlSession) {
    final MapperProxy<T> mapperProxy = new MapperProxy<>(sqlSession, mapperInterface, methodCache);
    return newInstance(mapperProxy);
  protected T newInstance(MapperProxy<T> mapperProxy) {
    return (T) Proxy.newProxyInstance(mapperInterface.getClassLoader(), new Class[] { mapperInterface }, mapperProxy);
生成mapperInterface接口 的代理对象的实例,代理类是MapperProxy,它实现了InvocationHandler,利用jdk动态代理生成代理对象
看一下它重写的invoke()方法:
映射代理类MapperProxy
MapperProxy的invoke()方法定义如下:
@Override
  public Object invoke(Object proxy, Method method, Object[] args) throws Throwable {
    try {
      if (Object.class.equals(method.getDeclaringClass())) {
        return method.invoke(this, args);
        return cachedInvoker(method).invoke(proxy, method, args, sqlSession);
    } catch (Throwable t) {
      throw ExceptionUtil.unwrapThrowable(t);
不是Object的类会被拦截,拦截调用cachedInvoker()方法,其他执行invoke()方法,
  private MapperMethodInvoker cachedInvoker(Method method) throws Throwable {
    try {
      return MapUtil.computeIfAbsent(methodCache, method, m -> {
        if (m.isDefault()) {
          try {
            if (privateLookupInMethod == null) {
              return new DefaultMethodInvoker(getMethodHandleJava8(method));
              return new DefaultMethodInvoker(getMethodHandleJava9(method));
          } catch (IllegalAccessException | InstantiationException | InvocationTargetException
              | NoSuchMethodException e) {
            throw new RuntimeException(e);
          return new PlainMethodInvoker(new MapperMethod(mapperInterface, method, sqlSession.getConfiguration()));
    } catch (RuntimeException re) {
      Throwable cause = re.getCause();
      throw cause == null ? re : cause;
  1. 从methodCache中获取对应的MapperMethodInvoker
  2. 如果缓存没有,如果是方法是default方法就创建DefaultMethodInvoker对象,否则创建PlainMethodInvoker对象
对于DefaultMethodInvoker类通过MethodHandle完成调用
private static class DefaultMethodInvoker implements MapperMethodInvoker {
    private final MethodHandle methodHandle;
    public DefaultMethodInvoker(MethodHandle methodHandle) {
      super();
      this.methodHandle = methodHandle;
    @Override
    public Object invoke(Object proxy, Method method, Object[] args, SqlSession sqlSession) throws Throwable {
      return methodHandle.bindTo(proxy).invokeWithArguments(args);
对于普通方法对应的类PlainMethodInvoker通过MapperMethod来完成调用,
private static class PlainMethodInvoker implements MapperMethodInvoker {
    private final MapperMethod mapperMethod;
    public PlainMethodInvoker(MapperMethod mapperMethod) {
      super();
      this.mapperMethod = mapperMethod;
    @Override
      return mapperMethod.execute(sqlSession, args);
这篇文章主要介绍了聊聊Mybatis的binding模块,它的MapperRegistry保存着Mapper接口和MapperProxyFactory实例的映射关系,而MapperProxyFactory是一个的工厂,生成的是Mapper接口的代理类,MapperProxy实现InvocationHandler,重写invoke()方法进行拦截处理,根据方法判断是不是default类型创建不同的MethodInvoker类,然后调用MapperMethod执行sql,下篇文章我们将介绍MapperMethod类
