【Redis】Redis与SpringBoot整合
Laura_张 发表于 2022/08/27 22:44:45 2022/08/27
【摘要】 文章目录 一、在pom.xml文件中引入redis相关依赖二、application.properties配置redis配置三、添加redis配置类RedisConfig四、测试 RedisTes...
操作简单,按照步骤操作即可。
<!-- redis -->
<dependency>
<artifactId>spring-boot-starter-data-redis</artifactId>
</dependency>
<!-- spring2.X集成redis所需common-pool2-->
<dependency>
<groupId>org.apache.commons</groupId>
<artifactId>commons-pool2</artifactId>
<version>2.6.0</version>
</dependency>
#Redis服务器地址
spring.redis.host=192.168.140.136
#Redis服务器连接端口
spring.redis.port=6379
#Redis数据库索引(默认为0)
spring.redis.database= 0
#连接超时时间(毫秒)
spring.redis.timeout=1800000
#连接池最大连接数(使用负值表示没有限制)
spring.redis.lettuce.pool.max-active=20
#最大阻塞等待时间(负数表示没限制)
spring.redis.lettuce.pool.max-wait=-1
#连接池中的最大空闲连接
spring.redis.lettuce.pool.max-idle=5
#连接池中的最小空闲连接
spring.redis.lettuce.pool.min-idle=0
@EnableCaching
@Configuration
public class RedisConfig extends CachingConfigurerSupport {
    @Bean
    public RedisTemplate<String, Object> redisTemplate(RedisConnectionFactory factory) {
        RedisTemplate<String, Object> template = new RedisTemplate<>();
        RedisSerializer<String> redisSerializer = new StringRedisSerializer();
        Jackson2JsonRedisSerializer jackson2JsonRedisSerializer = new Jackson2JsonRedisSerializer(Object.class);
        ObjectMapper om = new ObjectMapper();
        om.setVisibility(PropertyAccessor.ALL, JsonAutoDetect.Visibility.ANY);
        om.enableDefaultTyping(ObjectMapper.DefaultTyping.NON_FINAL);
        jackson2JsonRedisSerializer.setObjectMapper(om);
        template.setConnectionFactory(factory);
//key序列化方式
        template.setKeySerializer(redisSerializer);
//value序列化
        template.setValueSerializer(jackson2JsonRedisSerializer);
//value hashmap序列化
        template.setHashValueSerializer(jackson2JsonRedisSerializer);
        return template;
    @Bean
    public CacheManager cacheManager(RedisConnectionFactory factory) {
//解决查询缓存转换异常的问题
// 配置序列化(解决乱码的问题),过期时间600秒
        RedisCacheConfiguration config = RedisCacheConfiguration.defaultCacheConfig()
                .entryTtl(Duration.ofSeconds(600))
                .serializeKeysWith(RedisSerializationContext.SerializationPair.fromSerializer(redisSerializer))
                .serializeValuesWith(RedisSerializationContext.SerializationPair.fromSerializer(jackson2JsonRedisSerializer))
                .disableCachingNullValues();
        RedisCacheManager cacheManager = RedisCacheManager.builder(factory)
                .cacheDefaults(config)
                .build();
        return cacheManager;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
四、测试 RedisTestController中添加测试方法
@RestController
@RequestMapping("/redisTest")
public class RedisTestController {
    @Autowired
    private RedisTemplate redisTemplate;
    @GetMapping
    public String testRedis() {
        //设置值到redis
        redisTemplate.opsForValue().set("name","lucy");
        //从redis获取值
        String name = (String)redisTemplate.opsForValue().get("name");
        return name;
文章来源: blog.csdn.net,作者:张艳伟_Laura,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/Laura__zhang/article/details/121878757
