【机房】结账——SSTab的使用
Laura_张 发表于 2022/08/27 00:15:59 2022/08/27
【摘要】 机房收费系统中管理员可以对操作员进行结账操作。 窗体界面: 结账用到了SSTab选项卡,SSTab的添加:添加SSTab选项卡 每一个选项下面对应的连接数据库和想要查询的内容都是不一样的。 代码...
窗体界面:
代码展示:
Private Sub SSTab1_Click(PreviousTab As Integer)
    Dim txtSQL As String
    Dim MsgText As String
    Dim mrc As Recordset
     Select Case SSTab1.Tab
        Case 0      '显示购卡
            MSHFlexGrid1.Rows = 1
            With MSHFlexGrid1
                .CellAlignment = 4
                .TextMatrix(0, 0) = "学号"
                .TextMatrix(0, 1) = "卡号"
                .TextMatrix(0, 2) = "日期"
                .TextMatrix(0, 3) = "时间"
            End With
            '连接数据库 student 表
            txtSQL = "select * from student_info where UserID='" & Trim(ComboUserID.Text) & "'and Ischeck='" & "未结账" & "'"
            Set mrc = ExecuteSQL(txtSQL, MsgText)
            Do While Not mrc.EOF
                With MSHFlexGrid1
                    .Rows = .Rows + 1
                    .CellAlignment = 4
                    .TextMatrix(.Rows - 1, 0) = mrc.Fields(1)
                    .TextMatrix(.Rows - 1, 1) = mrc.Fields(0)
                    .TextMatrix(.Rows - 1, 2) = mrc.Fields(12)
                    .TextMatrix(.Rows - 1, 3) = mrc.Fields(13)
                    '移动到下一条记录
                    mrc.MoveNext
                End With
            Loop
            mrc.Close
        Case 1      '显示充值
            MSHFlexGrid2.Rows = 1
            With MSHFlexGrid2
                .CellAlignment = 4
                .TextMatrix(0, 2) = "充值金额"
                .TextMatrix(0, 3) = "日期"
                .TextMatrix(0, 4) = "时间"
            End With
            '连接数据库 Recharge 表
            txtSQL = "select * from Recharge_info where UserID='" & Trim(ComboUserID.Text) & "'and status='" & "未结账" & "'"
                With MSHFlexGrid2
                    .Rows = .Rows + 1
                    .CellAlignment = 4
                    .TextMatrix(.Rows - 1, 1) = mrc.Fields(2)
                    .TextMatrix(.Rows - 1, 2) = mrc.Fields(3)
                    .TextMatrix(.Rows - 1, 3) = mrc.Fields(4)
                    .TextMatrix(.Rows - 1, 4) = mrc.Fields(5)
                    '移动到下一条记录
                    mrc.MoveNext
                End With
            Loop
            mrc.Close
        Case 2      '显示退卡
            MSHFlexGrid3.Rows = 1
            With MSHFlexGrid3
                .CellAlignment = 4
                .TextMatrix(0, 2) = "退卡金额"
            End With
            '连接数据库 CancelCard 表
            txtSQL = "select * from CancelCard_info where UserID='" & Trim(ComboUserID.Text) & "'and status='" & "未结账" & "'"
                With MSHFlexGrid3
                    .Rows = .Rows + 1
                    .CellAlignment = 4
                    .TextMatrix(.Rows - 1, 0) = mrc.Fields(0)
                    .TextMatrix(.Rows - 1, 1) = mrc.Fields(1)
                    .TextMatrix(.Rows - 1, 2) = mrc.Fields(2)   '退卡金额
                    .TextMatrix(.Rows - 1, 3) = mrc.Fields(3)   '日期
                    .TextMatrix(.Rows - 1, 4) = mrc.Fields(4)   '时间
                    '移动到下一条记录
                    mrc.MoveNext
                End With
            Loop
            mrc.Close
        Case 3      '显示临时用户
            MSHFlexGrid4.Rows = 1
            With MSHFlexGrid4
                .CellAlignment = 4
            End With
            '连接数据库 sutdent表 临时用户
            txtSQL = "select * from student_info where UserID='" & Trim(ComboUserID.Text) & "' and type='" & Trim(Label11.Caption) & "'"
                With MSHFlexGrid4
                    .Rows = .Rows + 1
                    .CellAlignment = 4
                    .TextMatrix(.Rows - 1, 0) = mrc.Fields(1)   '学号
                    .TextMatrix(.Rows - 1, 1) = mrc.Fields(0)   '卡号
                    .TextMatrix(.Rows - 1, 2) = mrc.Fields(12)   '日期
                    .TextMatrix(.Rows - 1, 3) = mrc.Fields(13)   '时间
                    '移动到下一条记录
                    mrc.MoveNext
                End With
            Loop
            mrc.Close
        Case 4      '显示汇总
            Dim mrcStu As ADODB.Recordset       '连接student表
            Dim mrcCancel As ADODB.Recordset    '连接cancelCard表
            Dim mrcRe As ADODB.Recordset        '连接Rechange表
            '连接student表
            Set mrcStu = ExecuteSQL(txtSQL, MsgText)
                txtSellCardSum.Text = mrcStu.RecordCount       '售卡张数
            '连接数据库 CancelCard 表
            Set mrcCancel = ExecuteSQL(txtSQL, MsgText)
                txtBackCardSum.Text = mrcCancel.RecordCount       '退卡张数
                '退卡金额
                If mrcCancel.EOF = True Then
                    txtBackCardMoney.Text = "0"
                Else
                    txtBackCardMoney.Text = Val(mrcCancel.Fields(2))
                End If
            '连接数据库 Recharge 表
            txtSQL = "select sum(addmoney) from Recharge_info where UserID='" & Trim(ComboUserID.Text) & "'and status='" & "未结账" & "'"
            Set mrcRe = ExecuteSQL(txtSQL, MsgText)
'                mrcRe.Open
                '充值金额
                If IsNull(Trim(mrcRe.Fields(0))) Then
                    txtRecharge.Text = "0"
                Else
                    txtRecharge.Text = Val(mrcRe.Fields(0))
                End If
            '计算总售卡数与应收金额
            txtSellCardActual.Text = Val(txtSellCardSum.Text) - Val(txtBackCardSum.Text)    '总售卡张数
            txtCollectMoney.Text = Val(txtRecharge.Text) - Val(txtBackCardMoney.Text) '应收金额
        Case 5      '退出
            Unload Me
        End Select
End Sub
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
汇总选项卡下面还有一个结账的控件
结账的时候需要连接学生表、充值表和退卡表,综合上机的时间和卡里余额进行结账。
代码展示:
Private Sub cmdAccounts_Click()
            '连接student表
    txtSQL = "select * from student_info where UserID='" & Trim(ComboUserID.Text) & "'"
        Do While Not mrcStu.EOF
            mrcStu!Ischeck = "结账"
            mrcStu.Update
            mrcStu.MoveNext
        Loop
        mrcStu.Close
    '连接数据库 CancelCard 表
    txtSQL = "select * from CancelCard_info where UserID='" & Trim(ComboUserID.Text) & "'"
        Do While Not mrcCancel.EOF
            mrcCancel!Status = "结账"
            mrcCancel.Update
            mrcCancel.MoveNext
        Loop
        mrcCancel.Close
    '连接数据库 Recharge 表
    txtSQL = "select * from Recharge_info where UserID='" & Trim(ComboUserID.Text) & "'"
    Do While Not mrcRe.EOF
            mrcRe!Status = "结账"
            mrcRe.Update
            mrcRe.MoveNext
    Loop
    mrcRe.Close
    MsgBox "结账成功", 64, "温馨提示"
    Exit Sub
End Sub
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
感谢阅读~
文章来源: blog.csdn.net,作者:张艳伟_Laura,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/Laura__zhang/article/details/107528088
