字符串中找出连续最长的数字串_数组中出现次数超过一半的数字
bug郭 发表于 2022/08/26 23:50:22 2022/08/26
【摘要】 字符串中找出连续最长的数字串字符串中找出连续最长的数字串import java.util.*;public class Main{ public static String findLongNumberStr(String str){ String strResult = new String(); String tmp = new String(); ...
字符串中找出连续最长的数字串
字符串中找出连续最长的数字串
image-20220430090113079
import java.util.*;
public class Main{
        for(int i = 0;i < str.length();i++){
            char ch = str.charAt(i);
            if(ch>='0'&&ch<='9'){//该位置是数字!!
                tmp +=(""+ch); //拼接!
            }else{
                //不连续!
                if(strResult.length()<tmp.length()){
                       strResult = tmp;//更新结果!
                tmp = new String();
        //如果最长数字序列在最后,需要单独进行处理!!!
        return strResult;
    public static void main(String[] args){
        Scanner sc = new Scanner(System.in);
        String str = sc.nextLine();
        String result = findLongNumberStr(str);
        System.out.println(result);
数组中出现次数超过一半的数字
题目链接
image-20220430091529600
import java.util.Arrays;
public class Solution {
    public int MoreThanHalfNum_Solution(int [] array) {
        if(array==null||array.length==0){
            return -1;
        //先将数组排序!!!
        //排序后,中间的数就是出现次数超过了长度一半的数!
        Arrays.sort(array);
        int len = array.length;
        int midNumber = array[len/2];
      return midNumber;
