创建单链表 打印单链表 插入删除节点 查找功能
花花叔叔 发表于 2022/08/18 00:53:36 2022/08/18
【摘要】 代码: #include<stdio.h> #include<stdlib.h> #define OK 1 #define FALSE 0 typedef int Status;...
代码:
#include<stdio.h>
#include<stdlib.h>
#define OK 1
#define FALSE 0
typedef int Status;
typedef float ElemType;
typedef struct LNode
	ElemType data;
	struct LNode *next;
 } LNode,* LinkList;
LinkList s,r,P;
Status i;
//创建单链表
void CreatListTail(LinkList &L,Status n)
	r=L=(LinkList)malloc(sizeof(LNode));
	L->next=NULL;
	for(i=1;i<=n;++i)
		s=(LinkList)malloc(sizeof(LNode));
		scanf("%f",&s->data);
		s->next=NULL;
		r->next=s;
		r=s;
ElemType GetElem(LinkList &L,Status i)
	i=i+1;
	LinkList P;
	Status j;
	P=L;
	j=1;
	while(P&&j<i)
		P=P->next;
		j++;
	return P->data;
ElemType ListInsert(LinkList &L,int  i,ElemType e)
	i=i+1;
	Status j;
	P=L;
	j=1;
	while(P&&j<i-1)
		P=P->next;
		++j;
	if(!P||j>i-1)
		return FALSE;
	s->data=e;
	s->next=P->next;
	P->next=s;
	return OK;
void print(LinkList &L)
	LinkList P;
	P=L->next;
	while(P!=NULL)
		printf("%f ",P->data);
		P=P->next;
Status ListDelete(LinkList &L,int i)
	i=i+1;
	ElemType e;
	Status j;
	LinkList q;
	P=L;
	j=1;
	while(P->next&&j<i-1)
		P=P->next;
		j++;
	if(!(P->next)||j>i-1)
		return FALSE;
	q=P->next;
	P->next=q->next;
	e=q->data;
	free(q);
	return e;
int main()
	Status n,i;
	LinkList L,P;
	printf("请输入节点个数:");
	scanf("%d",&n);
	printf("创建单链表(输入每个结点的数据域):");
	CreatListTail(L,n);
	printf("打印单链表:");
	print(L);
	printf("\n");
	printf("获取第二个元素:%f\n",GetElem(L,2));
	ListInsert(L,2,11);
	printf("将11插入到第二个位置,并输出新的链表:");
	print(L);
	printf("\n");
	printf("删除第二个节点,并打印新的链表");
	ListDelete(L,2);
	print(L);
	return 0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
文章来源: blog.csdn.net,作者:花花叔叔,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_52077949/article/details/115050858
