“蔚来杯“2022牛客暑期多校训练营8,签到题F
小哈里 发表于 2022/08/17 23:19:40 2022/08/17
【摘要】 题号 标题 已通过代码 通过率 团队的状态 A Puzzle: X-Sums Sudoku 点击查看 19/55 B Puzzle: Patrick’s Parabox 点击查看 1/70 C Puz...
C Puzzle: Hearthstone 点击查看 2/105
D Poker Game: Decision 点击查看 311/3285
E Poker Game: Construction 点击查看 1/64
F Longest Common Subsequence 点击查看 1332/9989
G Lexicographic Comparison 点击查看 12/159
H Expression Evaluation 点击查看 2/26
I Equivalence in Connectivity 点击查看 39/252
J Symmetry: Tree 点击查看 17/336
K Symmetry: Convex 点击查看 2/12
L Symmetry: Closure 点击查看 1/21
F.Longest Common Subsequence
链接:https://ac.nowcoder.com/acm/contest/33193/F
来源:牛客网
题目描述
Given sequence ss of length nn and sequence tt of length mm, find the length of the longest common subsequence of ss and tt.
输入描述:
There are multiple test cases. The first line of input contains an integer TT(1\le T\le 10^31≤T≤10
3
), the number of test cases.
For each test case:
The only line contains 77 integers, nn, mm, pp, xx, aa, bb, cc (1\le n1≤n, m\le 10^6m≤10
6
, 0\le x0≤x, aa, bb, c<p\le 10^9c<p≤10
9
). nn is the length of ss, mm is the length of tt.
To avoid large input, you should generate the sequences as follows:
For each i=1i=1, 22, \cdots⋯, nn in order, update xx to (ax^2+bx+c)\bmod p(ax
2
+bx+c)modp, and then set s_is
i
to xx. And then, for each i=1i=1, 22, \cdots⋯, mm in order, update xx to (ax^2+bx+c)\bmod p(ax
2
+bx+c)modp, and then set t_it
i
to xx.
It is guaranteed that the sum of nn and the sum of mm over all test cases does not exceed 10^610
6
输出描述:
For each test case:
Output an integer – the length of the longest common subsequence of ss and tt, in one line.
示例1
输入
复制
2
4 3 1024 1 1 1 1
3 4 1024 0 0 0 0
输出
复制
0
3
说明
In the first sample, s=[3,13,183,905]s=[3,13,183,905] and t=[731,565,303]t=[731,565,303].
In the second sample, s=[0,0,0]s=[0,0,0] and t=[0,0,0,0]t=[0,0,0,0].
题意:
  • 给出n, m, p, x, a, b, c。 令 f ( x ) = ( a x 2 + b x + c ) % p f(x) = (ax^2+bx+c)\%p f(x)=(ax2+bx+c)%p。
    让长为n的序列s,s[1]=f(x), s[2]=f(s[1]), s[3]=f(s[2]),依次递推。
    让长为m的序列t,t[1]=f(s[n]), t[2] = f(t[1]), t[3] = f(t[2]),依次类推。
  • 最后求序列s和序列t的LCS(最长公共子序列)。
思路:
  • 因为要%p,所以可以发现,到后面这两个序列都是循环的。换句话说,如果两个序列中有相同数字,那么后面的数字一定全一样。
  • 开个map记录下序列s中每个数第一次出现的位置。对于t进行遍历的时候,找到这个数的位置,将序列t[j]与s[i]对上后,不难发现 [ t[j], m ] 与 [ s[i], n ] 这两个区间一定是一样的,因为都是往后无限循环,取个min就是LCS的大小。遍历一遍维护最大值即可。
#include<bits/stdc++.h>
using namespace std;
#define IOS ios::sync_with_stdio(0), cin.tie(0),cout.tie(0)
typedef long long LL;
int main(){
    LL T;  cin>>T;
    while(T--){
        LL n, m, p, x, a, b, c;  cin>>n>>m>>p>>x>>a>>b>>c;
        unordered_map<LL,LL>mp;        //每个数最早出现的位置
        for(LL i = 1; i <= n; i++){
            x = (a*x%p*x+b*x+c)%p;
            if(!mp.count(x))mp[x] = i;
        LL ans = 0;
        for(LL i = 1; i <= m; i++){
            if(mp.count(x)){
                //LCS可选 [mp[x],n] 或 [i,m]
                ans = max(ans, min(n-mp[x], m-i)+1);
        cout<<ans<<"\n";
    return 0;
文章来源: gwj1314.blog.csdn.net,作者:小哈里,版权归原作者所有,如需转载,请联系作者。
原文链接:gwj1314.blog.csdn.net/article/details/126321997
