机器人微控制器编程(CoCube)-突破边界
zhangrelay 发表于 2022/08/12 23:45:34 2022/08/12
【摘要】 将C语言+嵌入式+单片机+ROS2等相关知识点,有机融合到一门课程之中。 突破windows或linux的限制,突破电脑或手机的限制,突破单片机原有的理论实践体系,全面提升到CoCube机器人平台。 模拟量采集和转换: #include "Arduino.h"#include <ESP32AnalogRead.h&...
模拟量采集和转换:
  1. #include "Arduino.h"
  2. #include <ESP32AnalogRead.h>
  3. ESP32AnalogRead adc;
  4. void setup()
  5. {
  6. adc.attach(34);
  7. Serial.begin(115200);
  8. }
  9. void loop()
  10. {
  11. delay(50);
  12. Serial.println("Voltage = "+String(adc.readVoltage()));
  13. }
机器人电池电压的实时监控:
  1. #include <micro_ros_arduino.h>
  2. #include <stdio.h>
  3. #include <rcl/rcl.h>
  4. #include <rcl/error_handling.h>
  5. #include <rclc/rclc.h>
  6. #include <rclc/executor.h>
  7. #include <std_msgs/msg/float32.h>
  8. #if !defined(ESP32) && !defined(TARGET_PORTENTA_H7_M7) && !defined(ARDUINO_NANO_RP2040_CONNECT)
  9. #error This example is only avaible for Arduino Portenta, Arduino Nano RP2040 Connect and ESP32 Dev module
  10. #endif
  11. #define BAT_DET 34
  12. rcl_publisher_t publisher;
  13. std_msgs__msg__Float32 msg;
  14. rclc_support_t support;
  15. rcl_allocator_t allocator;
  16. rcl_node_t node;
  17. #define LED_PIN 13
  18. #define RCCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){error_loop();}}
  19. #define RCSOFTCHECK(fn) { rcl_ret_t temp_rc = fn; if((temp_rc != RCL_RET_OK)){}}
  20. void error_loop(){
  21. while(1){
  22. digitalWrite(LED_PIN, !digitalRead(LED_PIN));
  23. delay(100);
  24. }
  25. }
  26. void timer_callback(rcl_timer_t * timer, int64_t last_call_time)
  27. {
  28. RCLC_UNUSED(last_call_time);
  29. if (timer != NULL) {
  30. RCSOFTCHECK(rcl_publish(&publisher, &msg, NULL));
  31. msg.data++;
  32. }
  33. }
  34. void setup() {
  35. set_microros_wifi_transports("***", "***", "***", 8888);
  36. pinMode(BAT_DET, INPUT);
  37. pinMode(LED_PIN, OUTPUT);
  38. digitalWrite(LED_PIN, HIGH);
  39. delay(2000);
  40. allocator = rcl_get_default_allocator();
  41. //create init_options
  42. RCCHECK(rclc_support_init(&support, 0, NULL, &allocator));
  43. // create node
  44. RCCHECK(rclc_node_init_default(&node, "robot_battery_wifi_node", "", &support));
  45. // create publisher
  46. RCCHECK(rclc_publisher_init_best_effort(
  47. &publisher,
  48. &node,
  49. ROSIDL_GET_MSG_TYPE_SUPPORT(std_msgs, msg, Float32),
  50. "robot_battery"));
  51. msg.data = 0.66;
  52. }
  53. void loop() {
  54. float battery = 4.21 * analogRead(BAT_DET) / 2435;
  55. RCSOFTCHECK(rcl_publish(&publisher, &msg, NULL));
  56. msg.data=battery;
  57. delay(1000);
  58. }
不仅掌握的模拟量基本读取,也能知道其应用,例如电池电量测量,环境亮度监测等一系列涉及到具体机器人各环节的基础知识点。
从原有枯燥的单片机知识点融合到机器人细节设计的实际调试。
C和C++的区别,电脑C++编程和嵌入式C编程,代码如何保持相似的风格。
ESP32:
    &publisher,
    &node,
    ROSIDL_GET_MSG_TYPE_SUPPORT(std_msgs, msg, Int32),
    "topic_name"));
  RCCHECK(rclc_publisher_init_default(
    &publisher,
    &node,
    "topic_name"));
PC:
rclcpp::QoS qos(rclcpp::KeepLast(7));
pub_ = this->create_publisher<std_msgs::msg::String>("chatter", qos);
sub_ = create_subscription<std_msgs::msg::String>("chatter", rclcpp::SensorDataQoS(), callback);
sub_ = create_subscription<std_msgs::msg::String>("chatter", 10, callback);
原文链接:zhangrelay.blog.csdn.net/article/details/126277843
