Bootstrap补充内容
花花叔叔 发表于 2022/08/12 22:44:47 2022/08/12
【摘要】 掌握BootStrap手册用法,使用全局CSS样式美化标签 简单的说,就是在标签后面加上类名就可以了 <!DOCTYPE html> <html lang="en"> &lt...
  1. 掌握BootStrap手册用法,使用全局CSS样式美化标签
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>全局CSS样式-表格</title>
    <link rel="stylesheet" href="./bootstrap-3.4.1-dist/css/bootstrap.min.css">
</head>
<body>
    <table class="table table-striped table-bordered table-hover">
        <tr>
            <th>数字1</th>
            <th>数字2</th>
            <th>数字3</th>
        </tr>
        <tr>
            <td>1</td>
            <td>2</td>
            <td>3</td>
        </tr>
        <tr>
            <td>1</td>
            <td>2</td>
            <td>3</td>
        </tr>
        <tr>
            <td>1</td>
            <td>2</td>
            <td>3</td>
        </tr>
    </table>
</body>
</html>
  1. 使用BootStrap组件快速布局网页
直接复制过来食用就可以
<!DOCTYPE html>
<html lang="en">
<head>
    <title>组件</title>
</head>
<body>
    <div class="dropdown">
        <button class="btn btn-default dropdown-toggle" type="button" id="dropdownMenu1" data-toggle="dropdown" aria-haspopup="true" aria-expanded="true">
          下拉
          <span class="caret"></span>
        </button>
        <ul class="dropdown-menu" aria-labelledby="dropdownMenu1">
          <li><a href="#">Action</a></li>
          <li><a href="#">Another action</a></li>
          <li><a href="#">Something else here</a></li>
          <li role="separator" class="divider"></li>
          <li><a href="#">Separated link</a></li>
        </ul>
      </div>
      <ol class="breadcrumb">
        <li><a href="#">首页</a></li>
        <li><a href="#">用户中心</a></li>
        <li><a href="#">用户</a></li>
        <li class="active">数据</li>
      </ol>
</body>
</html>
字体图标
<!DOCTYPE html>
<html lang="en">
<head>
    <title>字体图标</title>
</head>
<body>
    <i class="glyphicon glyphicon-user"></i>
</body>
</html>
  1. 插件
因为使用了js,所以要多加两个js代码,剩下的直接复制过来修改一点点就可以了。
<!DOCTYPE html>
<html lang="en">
<head>
    <title>插件</title>
</head>
<body>
    <!-- <div class="dropdown">
        <button id="dLabel" type="button" data-toggle="dropdown" aria-haspopup="true" aria-expanded="false">
          Dropdown trigger
        </button>
        <ul class="dropdown-menu" aria-labelledby="dLabel">
          <li>111</li>
          <li>111</li>
          <li>111</li>
        </ul>
      </div> -->
      <div id="carousel-example-generic" class="carousel slide" data-ride="carousel">
        <!-- Indicators -->
        <ol class="carousel-indicators">
          <li data-target="#carousel-example-generic" data-slide-to="0" class="active"></li>
          <li data-target="#carousel-example-generic" data-slide-to="1"></li>
          <li data-target="#carousel-example-generic" data-slide-to="2"></li>
          <li data-target="#carousel-example-generic" data-slide-to="3"></li>
        </ol>
        <!-- Wrapper for slides -->
        <div class="carousel-inner" role="listbox">
          <div class="item active">
            <img src="../03-项目-AlloyTeam/AlloyTeam/uploads/banner_1.jpg" alt="...">
            <div class="carousel-caption">
            </div>
          </div>
          <div class="item">
            <img src="../03-项目-AlloyTeam/AlloyTeam/uploads/banner_2.jpg" alt="...">
            </div>
          </div>
          <div class="item">
            <img src="../03-项目-AlloyTeam/AlloyTeam/uploads/banner_3.jpg" alt="...">
            </div>
          </div>
          <div class="item">
            <img src="../03-项目-AlloyTeam/AlloyTeam/uploads/banner_4.jpg" alt="...">
            </div>
          </div>
        </div>
        <!-- Controls -->
        <a class="left carousel-control" href="#carousel-example-generic" role="button" data-slide="prev">
          <span class="glyphicon glyphicon-chevron-left" aria-hidden="true"></span>
          <span class="sr-only">Previous</span>
        </a>
        <a class="right carousel-control" href="#carousel-example-generic" role="button" data-slide="next">
          <span class="glyphicon glyphicon-chevron-right" aria-hidden="true"></span>
          <span class="sr-only">Next</span>
        </a>
      </div>
    <script src="./js/jquery.js"></script>
    <script src="./bootstrap-3.4.1-dist/js/bootstrap.min.js"></script>
</body>
</html>
文章来源: blog.csdn.net,作者:花花叔叔,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_52077949/article/details/119962118
