第二篇:SpringBoot入门案例(IDEA联网版本)
花花叔叔 发表于 2022/08/13 00:38:24 2022/08/13
【摘要】 文章目录 starterparent引导类tomcat服务器创建好springboot项目之后,就可以开始写第一个SpringBoot项目了。@RestController@RequestMapp...
starter
SpringBoot中常见的项目名称,定义当前项目使用的所有依赖坐标,以达到减少依赖配置的目的。
就比如说web的依赖,只需要引入下面的一个依赖就可以了,这个依赖里面有很多小依赖。
<dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
点进去之后会看到有很多的小依赖。
<project xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd" xmlns="http://maven.apache.org/POM/4.0.0"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <!-- This module was also published with a richer model, Gradle metadata,  -->
  <!-- which should be used instead. Do not delete the following line which  -->
  <!-- is to indicate to Gradle or any Gradle module metadata file consumer  -->
  <!-- that they should prefer consuming it instead. -->
  <!-- do_not_remove: published-with-gradle-metadata -->
  <modelVersion>4.0.0</modelVersion>
  <version>2.6.3</version>
  <name>spring-boot-starter-web</name>
  <description>Starter for building web, including RESTful, applications using Spring MVC. Uses Tomcat as the default embedded container</description>
  <url>https://spring.io/projects/spring-boot</url>
  <organization>
    <name>Pivotal Software, Inc.</name>
    <url>https://spring.io</url>
  </organization>
  <licenses>
    <license>
      <name>Apache License, Version 2.0</name>
      <url>https://www.apache.org/licenses/LICENSE-2.0</url>
    </license>
  </licenses>
  <developers>
    <developer>
      <name>Pivotal</name>
      <email>info@pivotal.io</email>
      <organization>Pivotal Software, Inc.</organization>
      <organizationUrl>https://www.spring.io</organizationUrl>
    </developer>
  </developers>
  <scm>
    <connection>scm:git:git://github.com/spring-projects/spring-boot.git</connection>
    <developerConnection>scm:git:ssh://git@github.com/spring-projects/spring-boot.git</developerConnection>
    <url>https://github.com/spring-projects/spring-boot</url>
  </scm>
  <issueManagement>
    <system>GitHub</system>
    <url>https://github.com/spring-projects/spring-boot/issues</url>
  </issueManagement>
  <dependencies>
    <dependency>
      <artifactId>spring-boot-starter</artifactId>
      <scope>compile</scope>
    </dependency>
    <dependency>
      <artifactId>spring-boot-starter-json</artifactId>
    </dependency>
    <dependency>
      <artifactId>spring-boot-starter-tomcat</artifactId>
    </dependency>
    <dependency>
      <groupId>org.springframework</groupId>
      <artifactId>spring-web</artifactId>
      <version>5.3.15</version>
    </dependency>
    <dependency>
      <artifactId>spring-webmvc</artifactId>
    </dependency>
  </dependencies>
</project>
parent
所有的SpringBoot项目都要继承的项目,定义了若干个坐标的版本号(依赖管理,而非依赖),已达到减少依赖冲突的目的。就是在下面协写依赖的时候,有时候可能没有版本号,其实本质上是SpringBoot已经收录了。
<parent>
        <artifactId>spring-boot-starter-parent</artifactId>
    </parent>
引导类
SpringBoot工程提供引导类来用于启动成程序,就是run这个引导类就可以启动SpringBoot项目了,本质上这个东西就是一个大的Spring容器,然后之后写的bean都会放到这个spring里面的。
tomcat服务器
内嵌Tomcat服务器是SpringBoot辅助功能之一。
package com.itheima;
import org.springframework.web.bind.annotation.RequestMapping;
@RestController
@RequestMapping("/books")
public class BookController {
    @GetMapping("/news")
    public String getId() {
        System.out.println("SpringBoot is running");
        return "SpringBoot is running";
@RestController
@RestController = @ResponseBody + @Controller合在一起的作用
如果只是使用@RestController注解Controller,则Controller中的方法无法返回jsp页面,配置的视图解析器InternalResourceViewResolver不起作用,返回的内容就是Return 里的内容。
例如:本来应该到success.jsp页面的,则其显示success.
如果需要返回到指定页面,则需要用 @Controller配合视图解析器InternalResourceViewResolver才行。
如果需要返回JSON,XML或自定义mediaType内容到页面,则需要在对应的方法上加上@ResponseBody注解。(@Controller + @ResponseBody)
@RequestMapping
@GetMapping
@PostMapping
@PutMapping
@DeleteMapping
@PatchMapping
@PathVariable
import org.springframework.web.bind.annotation.PathVariable;
@RestController
    @GetMapping("{id}")
    public String getById(@PathVariable Integer id) {
        System.out.println(id);
        return id + "";
文章来源: blog.csdn.net,作者:花花叔叔,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_52077949/article/details/123035264
