2022“杭电杯”中国大学生算法设计超级联赛(7)签到题5题
小哈里 发表于 2022/08/10 23:59:47 2022/08/10
【摘要】 Solved Problem ID Title Ratio (Accepted / Submitted) 1001 Bowling 7.63% (18/236) 1002 Independent Feed...
1002 Independent Feedback Vertex Set 42.38% (189/446)
1003 Counting Stickmen 23.06% (463/2008)
1004 Black Magic 35.71% (886/2481)
1005 Cyber Painter 16.67% (9/54)
1006 Sumire 22.67% (221/975)
1007 Weighted Beautiful Tree 21.99% (84/382)
1008 Triangle Game 23.25% (600/2581)
1009 Counting Good Arrays 13.73% (84/612)
1010 Connectivity of Erdős-Rényi Graph 39.37% (50/127)
1011 Rock Tree 8.52% (15/176)
4.Black Magic
Black Magic
Time Limit: 2000/1000 MS (Java/Others) Memory Limit: 524288/524288 K (Java/Others)
Total Submission(s): 39 Accepted Submission(s): 17
Problem Description
HoshiYo is learning Black Magic with n blocks. The left and right sides of each block are painted black or white. HoshiYo arranges the blocks in a row in a certain order without rotating them and then releases the Black Magic. Here’s what happens next:
For any two adjacent blocks, if the right side of the left block and the left side of the right block are both painted black, then the two sides will be pasted together making the two blocks into one.
HoshiYo wants to know the minimum and maximum blocks he can get after releasing the Black Magic.
Input
The first line contains an integer T (1≤T≤4×103), indicating the number of test cases.
Each test case contains four integers E,L,R,B (0≤E,L,R,B≤105,E+L+R+B≥1), indicating the number of blocks.
E: the number of blocks whose both sides are painted white.
L: the number of blocks whose left side is painted black and right side is painted white.
R: the number of blocks whose right side is painted black and left side is painted white.
B: the number of blocks whose both sides are painted black.
It guaranteed that the sum of E+L+R+B over all test cases won’t exceed 106.
Output
For each test case, output two integers in a single line, indicating the minimum and maximum blocks HoshiYo can get.
Sample Input
3
1 1 1 1
1 2 3 4
3 4 5 6
Sample Output
2 4
4 8
8 16
Hint
Let’s denote a block by (x,y), where x indicates the color on the left side, and y indicates the color on the right side. We use 0 to represent white and 1 to represent black.
For the first test case in the sample, here is a possible solution to get the minimum number of blocks:
(0,0)(0,1)(1,1)(1,0)
As shown above, the last three blocks will be pasted into one.
And here is a possible solution to get the maximum number of blocks:
(0,0)(1,0)(1,1)(0,1)
As shown above, any two blocks will not be pasted together.
Source
题意:
  • 给出 n 个方块,每个方块的左/右都可能是黑或白(共四种)。
  • 将这些方块排成一列,如果两个相邻方块相连接的面都是黑色,那么这两个方块会连在一起。
  • 求连通块的最大/最小数量
思路:
  • 分类讨论即可,最小就让01 11 10合并成一整块的尽可能多,最大就让10 11 01 分成三块的尽可能多。
  • 注意边界的判断,即某些块没有的样例情况下。如以下数据:
    5
    1 1 1 1
    0 1 1 1
    1 0 0 1
    1 1 1 0
    0 0 0 1
    2 4
    1 3
    2 2
    2 3
    1 1
//1004
#include<bits/stdc++.h>
using namespace std;
#define IOS ios::sync_with_stdio(0), cin.tie(0),cout.tie(0)
typedef long long LL;
int main(){
	IOS;
	LL T;  cin>>T;
    while(T--){
		LL E, L, R, B;
		cin>>E>>L>>R>>B;
		LL a = E, b = L, c = R, d = B;
		//最小
		if(d>0)d = 1;                 //11 11 11 合并成11
		if(b>0 || c>0)d = 0;          //01 11 合并成01
		LL t = min(b,c);              //01 10 合并成00
		b -= t;  c-=t;  a += t;       //00++
		LL mi = a+b+c+d;
		//最大
		t = min(a,d);				  //00 11 合并为 01(答案+t)
		a -= t;  d -= t;  c += t;     //01++
		LL mx = t+b+c;	   			  //10 10 10 01 01 01 (d的块数+1, 答案+b+c)
		if(a>0) mx += a;
		if(d>0) mx++;                 //10 10 (11) 01 01 中间可以放一块
		cout<<mi<<" "<<mx<<"\n";
    return 0;
8.Triangle Game
Triangle Game
Total Submission(s): 51 Accepted Submission(s): 37
Problem Description
Kate and Emilico are playing a game. There are 3 integers a,b,c. It is guaranteed that there exists a non-degenerate triangle whose side lengths are a,b,c respectively. The game goes as follows. Players take turns in decreasing a certain positive integer on one of the 3 integers. If there doesn’t exist a non-degenerate triangle whose side lengths are a,b,c after a player’s operation, the player loses.
Kate goes first. If both of them play optimally, will Kate win?
Input
The first line of input contains one integer T (1≤T≤104), indicating the number of test cases.
For each test case, the only line contains 3 integers a,b,c (1≤a,b,c≤109). It is guaranteed that there exists a non-degenerate triangle whose side lengths are a,b,c respectively.
Output
For each test case, if Kate will win, output Win in a single line. Otherwise, output Lose in a single line.
Sample Input
3
2 2 3
2 3 4
5 3 4
Sample Output
Win
Lose
Win
Source
题意:
  • 给出一个三角形,三边边长分别为 a,b,c。 现 Kate 和 Emilico 二人做游戏,每轮需要令三角形的一边长度减去一正整数,使这个三角形退化的一方输。
  • Kate 先手,双方均采用最优策略,问 Kate 是否会获胜。
思路:
  • 结论是:Kate 获胜当且仅当 (a-1)^(b-1)^(c-1)!=0。
    值得一提的是,这个结论与上一把牛客7的 K. Great Party 题是一样的。
  • 官方证明:
int main(){
    int T;  cin>>T;
    while(T--){
        LL a, b, c;  cin>>a>>b>>c;
        a--; b--; c--;
        if((a^b^c)==0)cout<<"Lose\n";
        else cout<<"Win\n";
    return 0;
3.Counting Stickmen
Counting Stickmen
Time Limit: 18000/9000 MS (Java/Others) Memory Limit: 524288/524288 K (Java/Others)
Total Submission(s): 84 Accepted Submission(s): 30
Problem Description
Namesolo has fallen in love with the game Stick Fight. But when he is playing the game, he wonders how to find out the number of stickmen in the game.
In this question, we define the stick man as shown in the picture above. It has a chain of length 1 as the head, two chains of length 2 as the arms, a chain of length 1 as the body, and two chains of length 1 as the legs. For example, the red part in this picture can be viewed as a stick man, with chain (2,3) to be the head, chains (3,4,6) and (3,9,10) to be the arms, chain (3,5) to be the body, and chains (5,7) and (5,8) to be the legs.
The game can be viewed as a tree, and Namesolo wants to know how many stickmen are there. Please note that two stickmen are different when there is at least one different edge between the two edge sets that make up the two stickmen.
Because the answer may be too large, Namesolo wants to know the answer modulo 998244353.
Input
The first line of input contains one integer T (1≤T≤15), indicating the number of test cases.
For each test case, the first line contains an integer n (1≤n≤5×105), indicating the number of vertices in the tree. Each of the following n−1 lines contains two integers a,b (1≤a,b≤n), indicating that there is an edge connecting a and b in the tree.
It is guaranteed that the sum of n over all cases won’t exceed 3×106.
Output
For each test case, output an integer representing the answer modulo 998244353.
Sample Input
1
9
1 2
2 3
3 4
2 5
5 6
2 7
7 8
7 9
Sample Output
1
Source
题意:
  • 给出一棵n(5e5)个点的树,判断其中有多少个火柴人(2手臂,2手掌,身体,2腿,共8条边),输出数量%998244353。
思路:
  • 首先枚举每个点作为身体,然后往外拓展一层 ,可以得到他儿子的信息,根据子树大小分别为0,1,>2的分成三类(0只能做头,1只能做头和手, >2都可以)。
  • 然后我们对于当前点u为身体下脚的可能性(肯定是>2的点),那么脚的可选方案数就是C(x,2)。
    然后对于这个脚,我们可以选0或1作为头,也可以选剩下的2作为头,总共分为3大类。
    对于这3大类,再对两只手分类(手=1+1, 或=1+2,或者=2+2)。
    总共就是9类。
  • 对于每一类按照脚的方案数x头的方案数x手的方案数,用乘法原理算出结果,最后累加即可。
const LL maxn = 5e5+10, mod = 998244353;
LL pows(LL a, LL x) { if(x==0)return 1; LL t = pows(a, x>>1); if(x%2==0)return t*t%mod; return t*t%mod*a%mod; }
LL pows(LL a, LL x, LL p) { if(x==0)return 1; LL t = pows(a, x>>1, p); if(x%2==0)return t*t%p; return t*t%p*a%p; }
LL exgcd(LL a, LL b, LL &x, LL &y){ if(!b){ x = 1, y = 0; return a; }else{LL r = exgcd(b, a%b, x, y); LL t = x; x = y; y = t-a/b*y; return r; }}
void exgcd(LL a, LL b, LL &d, LL &x,  LL & y, LL MOD) { if (b==0) { d = a; x = 1; y = 0; } else { exgcd(b, a % b, d, y, x, MOD); y -= x * (a / b); } }
LL inv(LL a, LL MOD) { LL d=0, x=0, y=0; exgcd(a, MOD,  d,  x, y, MOD); return d == 1 ? (x + MOD) % MOD : -1; }
LL fac[maxn], inv2[maxn];
LL mpow(LL a, LL x) {
	if(x==0)return 1;
	LL t = mpow(a, x>>1);
LL init(){
	fac[0]=inv2[0]=1;
	for(LL i = 1; i < maxn; i++){
		fac[i]=fac[i-1]*i%mod; inv2[i]=mpow(fac[i],mod-2);
	}return 0;
LL C(LL x, LL y) {
	if(y<0 || y>x)return 0;
	return fac[x]*inv2[y]%mod*inv2[x-y]%mod;
vector<LL>G[maxn];
int main(){
    IOS;
    init();
    LL T;  cin>>T;
    while(T--){
        LL n;  cin>>n;
        for(int i = 1; i <= n; i++)G[i].clear();
        for(LL i = 1; i < n; i++){
            LL u, v;  cin>>u>>v;
            G[u].push_back(v);
            G[v].push_back(u);
        LL ans = 0;
        for(LL i = 1; i <= n; i++){
            LL a = 0, b = 0, c = 0; //子树大小分别为0,1,>2
            vector<LL>vc;
            LL sum = 0;
            //a只能做头,b只能做头和手, c都可以
            for(LL v : G[i]){
                if(G[v].size()==1)a++;
                else if(G[v].size()==2)b++;
                else {
                    c++;
                    vc.push_back(G[v].size());
                    sum = (sum+G[v].size()-1)%mod;
            LL res = 0;
            LL sum2 = 0; //所有脚作为手的可能性
            for(auto x : vc) {
                x--;
                sum2 = (sum2+(sum-x)*x%mod+mod)%mod;
            sum2 = sum2*inv(2,mod)%mod;
            //选脚作为脚(必须)
            for(auto x : vc){
                x = x-1;
                LL sum3 = (sum2-x*(sum-x)%mod+mod)%mod; //去掉了x的所有脚x脚
                //res += 脚x头x手
                //选头作为头
                if(c>=3 && a>=1)res = (res+C(x,2)*a%mod*sum3%mod)%mod;    //手=脚+脚
                if(c>=2 && a>=1 && b>=1)res = (res+C(x,2)*a%mod*((sum-x)%mod*b)%mod)%mod ; //手=脚+手
                if(c>=1 && a>=1 && b>=2)res = (res+C(x,2)*a%mod*C(b,2)%mod)%mod;  //手=手+手
                //选手作为头
                if(c>=3 && b>=1)res = (res+C(x,2)*b%mod*(sum3)%mod)%mod;       //手=脚+脚
                if(c>=2 && b>=2)res = (res+C(x,2)*b%mod*(sum-x)%mod*(b-1)%mod)%mod;       //手=脚+手
                if(c>=1 && b>=3)res = (res+C(x,2)*b%mod*C(b-1,2)%mod)%mod;       //手=手+手
                //选脚作为头
                if(c>=4)res = (res+C(x,2)*(c-3)%mod*sum3%mod)%mod;       //手=脚+脚
                if(c>=3 && b>=1)res = (res+C(x,2)*(c-2)%mod*((sum-x)*b%mod)%mod)%mod;       //手=脚+手
                if(c>=2 && b>=2)res = (res+C(x,2)*(c-1)%mod*C(b,2)%mod)%mod;       //手=手+手
            ans = (ans+res+mod)%mod;
        cout<<(ans+mod)%mod<<'\n';
    return 0;
几组非样例的数据:
2
9
1 2
2 3
3 4
2 5
5 6
2 7
7 8
7 9
11
1 2
2 3
2 11
3 4
3 5
3 9
4 6
5 7
5 8
9 10
1
10
1
13
1 2
2 3
2 11
3 4
3 5
3 9
4 6
5 7
5 8
9 10
4 12
9 13
48
1
15
1 2
2 3
2 11
3 4
3 5
3 9
4 6
5 7
5 8
9 10
4 12
9 13
3 14
14 15
144
  • 官方题解如下:
const LL maxn = 1e7+10, mod = 998244353;
vector<LL>G[maxn];
LL s0[maxn], s1[maxn], s2[maxn];
LL C(LL x, LL y){ return x*(x-1)/2%mod; }// C(x,2)
int main(){
    IOS;
    LL T;  cin>>T;
    while(T--){
        LL n;  cin>>n;
        for(int i = 1; i <= n; i++)G[i].clear(),s0[i]=s1[i]=s2[i]=0;
            LL u, v;  cin>>u>>v;
            G[u].push_back(v);
            G[v].push_back(u);
        //预处理
        for(int i = 1; i <= n; i++){
            s0[i] = G[i].size();    //i的儿子总数
            for(int v: G[i]){
                s1[i] = (s1[i]+G[v].size()-1+mod)%mod;     //i的孙子总数
                s2[i] = (s2[i]+C(G[v].size()-1,2)+mod)%mod;//i的每个孙子选出两条的方案数
        LL ans = 0;
        for(int i = 1; i <= n; i++){ //枚举靠头一侧的端点
            if(s0[i] >= 4){          //至少要有4条边
                for(int v : G[i]){   //枚举靠腿一侧的端点
                    if(s0[v] >= 3){  //至少要有3条边(1条跟头连)
                        LL head = s0[i]-3; //头的方案数
                        LL foot = s0[v]-1; //腿的方案数
                        LL hand = (s1[i]-foot+mod)%mod; //手的方案数
                        //res = 头*( C(手,2)-(i手总数-C(腿-1,2)) ) * C(腿,2)
                        LL res = head*(C(hand,2)-(s2[i]-C(G[v].size()-1,2))+mod)%mod*C(foot,2)%mod;
        cout<<ans<<"\n";
    return 0;
6.Sumire
Sumire
Time Limit: 7000/3500 MS (Java/Others) Memory Limit: 524288/524288 K (Java/Others)
Total Submission(s): 234 Accepted Submission(s): 68
Problem Description
Calculate
∑i=lrfk(i,B,d)
where f(x,B,d) means the number of times that digit d appears in the base-B form of x (ignoring leading zeros).
In this problem, we consider that 00=0.
Input
The first line contains one integer T (1≤T≤104), denoting the number of test cases.
For each test case, the only line contains five integers k,B,d,l,r (0≤k≤109, 2≤B≤109, 0≤d<B, 1≤l≤r≤1018), as the statement shows.
Output
For each test case, output an integer indicating the answer modulo 109+7 in a single line.
Sample Input
3
2 2 0 1 5
1 4 3 11 45
10 14 11 19 198
Sample Output
6
19
1049
Hint
For the first case in the sample, the answer is
∑i=15f2(i,2,0)=02+12+02+22+12=6
Source
题意:
  • 对于区间[l,r]中的每个数x,将x转为B进制,并判断数字中有多少个数字d,将个数的k次方累加,即为答案。
  • k,B,d<1e9, l, r<1e18。
思路:
  • 官方题解:
const LL maxn = 1e7+10, mod = 1e9+7;
LL k, B, d, l, r;
LL s[80], m = 0;
LL dp[80][80][2][2], vis[80][80][2][2];
//dp[i,j,k,l]:已经统计了前i位,其中有j个位上是d, 是否取数字上界, 是否有前导0。
LL dfs(LL dep, LL tot, LL lim, LL zero){
    if(dep==m+1 && tot ==0)return 1;
    if(dep==m+1)return 0;
    if(tot<0)return 0;
    if(vis[dep][tot][lim][zero])return dp[dep][tot][lim][zero]%mod;
    vis[dep][tot][lim][zero]=1;
    LL up=lim?s[dep]:B-1; //当前位取的数字上界(上界orB-1)
    LL c = (d==0);        //无前导0,d=0。 =>c=1
    if(zero&&(d==0))c=0;   //有前导0,d=0。 =>c=0
    LL ct=0, i = 0; //当前位初始为0
    //当前位为0,且目前还在维护前导零
    (dp[dep][tot][lim][zero]+=dfs(dep+1,tot-c,lim&&(s[dep]==0ll),zero))%=mod;  ct++;
    //当前位为d, 并且d!=0, 并且d<=上界
    if(d!=0&&d<=up){
        (dp[dep][tot][lim][zero]+=dfs(dep+1,tot-1,lim&&(s[dep]==d),0)) %= mod;  ct++; i=d;
    //当前位卡住上界(s[dep]==up),且之前也卡住数字上界(lim==1)
    if(i!=up){
        (dp[dep][tot][lim][zero]+=dfs(dep+1,tot,lim&&(s[dep]==up),zero&&(up==0LL))) %= mod;  ct++;
    //其他情况
    (dp[dep][tot][lim][zero]+=dfs(dep+1,tot,0,0)*max(0LL,up-ct+1LL)) %= mod;
LL calc(LL t){
    //将数字t转为B进制
    m = 0;
    while(t)s[++m] = t%B, t/=B;
    reverse(s+1,s+m+1);
    //dp
    memset(dp,0,sizeof(dp));
    memset(vis,0,sizeof(vis));
    LL res = 0;
    for(int i = 1; i <= m; i++){  //枚举1-l所有数字的每个位,贡献*=i^k
        res = (res+dfs(1,i,1,1)*pows(i,k)%mod)%mod;
    return (res+mod)%mod;
int main(){
    ios::sync_with_stdio(0), cin.tie(0),cout.tie(0);
    LL T;  cin>>T;
    while(T--){
        cin>>k>>B>>d>>l>>r;
        LL ans = calc(l-1);
        ans = (calc(r)-ans+mod)%mod;
        cout<<ans<<"\n";
    return 0;
2.Independent Feedback Vertex Set
Time Limit: 6000/3000 MS (Java/Others) Memory Limit: 524288/524288 K (Java/Others)
Total Submission(s): 139 Accepted Submission(s): 82
Problem Description
Yukikaze loves graph theory, especially forests and independent sets.
Forest: an undirected graph without cycles.
Independent set: a set of vertices in a graph such that for every two vertices, there is no edge connecting the two.
Yukikaze has an undirected graph G=(V,E) where V is the set of vertices and E is the set of edges. Each vertex in V has a vertex weight. Now she wants to divide V into two complementary subsets VI and VF such that VI is an independent set, and the induced subgraph G[VF] is a forest. The induced subgraph G[VF] is the graph whose vertex set is VF and whose edge set consists of all of the edges in E that have both endpoints in VF. In addition, she wants to maximize the sum of weights of vertices in VI.
Since this problem is NP-hard for general graphs, she decides to solve a special case of the problem. We can build a special graph by the following steps. Initially, the graph consists of three vertices 1,2,3 and three edges (1,2),(2,3),(3,1). When we add a vertex x into the graph, we select an edge (y,z) that already exists in the graph and connect (x,y) and (x,z). Keep doing this until there are n vertices in the graph.
Input
The first line of the input contains a single integer T (1≤T≤103), indicating the number of test cases.
The first line of each test case contains a single integer n (4≤n≤105), indicating the number of vertices in the graph. It is guaranteed that the sum of n over all test cases won’t exceed 106.
The second line of each test case contains n positive integers a1,a2,…,an (1≤ai≤109), indicating the weights of the vertices.
Initially, the graph consists of three vertices 1,2,3 and three edges (1,2),(2,3),(3,1). The i-th line of the next n−3 lines contains two integers u,v (1≤u,v<i+3), indicating the addition of a vertex i+3 and two edges (i+3,u),(i+3,v) to the graph. It is guaranteed that (u,v) already exists in the graph.
Output
For each test case, print an integer in a single line indicating the maximum sum of weights of vertices in VI.
Sample Input
3
4
3 3 2 2
1 2
4
2 5 5 2
2 3
5
3 1 1 1 1
1 2
1 3
Sample Output
4
5
3
Source
题意:
  • n个点的无向图,每个点有一个权重。
    最初,该图由三个顶点 1,2,3 和三个边 (1,2),(2,3),(3,1) 组成。
    接下来n-3个(u,v)表示新建两条(i+3,u), (i+3,v)边加入图中,保证(u,v)已在图中。
  • 现在要将该图的点集V分成两个部分。
    第一部分是独立集(图中的一组顶点,使得对于每两个顶点,没有连接两者的边)。
    第二部分的诱导子图(诱导子图 G[VF] 是一个图,其顶点集为 VF,其边集由 E 由所有端点都在 VF 中的边组成。)是一个森林(无环的无向图)。
  • 现在想要最大化第一部分中顶点的权重总和,输出这个最大值。
思路:
  • 首先理解一下几个概念:
    下面这张图是独立集,森林就是很多个不连通的树。
    独立集
    诱导(导出)子图是由该图顶点的一个子集和该图中两端均在该子集的所有边的集合组成的图。在这里插入图片描述
  • 求的答案是让独立集权值和尽可能大的同时,满足剩下点的诱导子图是个森林。
  • 答案中的独立集 必须包含每个三元环中的恰好一个点,因为一个点都不选则会破坏森林约束,选至少两个则会破坏独立集约束。
  • 同时对于一对有至少两个公共点的三元环,确定了答案包含其中一个的某个点之后另一个也随之确定了。(因为独立集不能有相邻点,因此肯定是对边的那两个点同属于一个集合)
  • 因此答案的独立集只可能有三种,分别对应图中唯一的三染色方案中的每一种颜色的点。
int main(){
    int T;  cin>>T;
    while(T--){
        int n;  cin>>n;
        vector<int>w(n+1);   //权值
        for(int i = 1; i <= n; i++)cin>>w[i];
        vector<int>c(n+1,0); //染色方案
        c[1] = 0;  c[2] = 1;  c[3] = 2;
        for(int i = 4; i <= n; i++){
            int u, v;  cin>>u>>v;
            //因为i与u,v都有边,所以颜色需要与u,v都不同
            c[i] = (3-c[u]-c[v])%3;
        //统计每种颜色(独立集)的点权,取个max即可
        LL ans[3] = {0, 0, 0};
            ans[c[i]] += w[i];
        cout<<max({ans[0], ans[1], ans[2]})<<"\n";
    return 0;
文章来源: gwj1314.blog.csdn.net,作者:小哈里,版权归原作者所有,如需转载,请联系作者。
原文链接:gwj1314.blog.csdn.net/article/details/126252835
