Spring整合MyBatis和Junit
不会压弯的小飞侠 发表于 2022/08/08 22:40:40 2022/08/08
【摘要】 ✨博客主页:👉不会压弯的小飞侠 ✨欢迎关注:👉点赞👍收藏⭐留言✒ ✨系列专栏:👉spring专栏 ✨如果觉得博主的文章还不错的话,请三连支持一下博主。 ✨欢迎大佬指正,一起学习!一起加油! ...
✨博客主页:👉不会压弯的小飞侠
✨欢迎关注:👉点赞👍收藏⭐留言✒
✨系列专栏:👉spring专栏
✨欢迎大佬指正,一起学习!一起加油!
一、整合MyBatis
<configuration>
    <environments default="development">
        <environment id="development">
            <transactionManager type="JDBC"/>
            <dataSource type="POOLED">
                <property name="driver" value="com.mysql.jdbc.Driver"/>
                <property name="url" value="jdbc:mysql://localhost:3306/mybatis?useSSL=false&amp;useUnicode=true&amp;characterEncoding=UTF-8"/>
                <property name="username" value="root"/>
                <property name="password" value="root"/>
            </dataSource>
        </environment>
    </environments>
     <!--加载sql映射文件-->
    <mappers>
        <package name="com.jkj.Mapper"/>
    </mappers>
</configuration>
1.将SqlSessionFactory相关的配置转化为:
 @Bean
    public SqlSessionFactoryBean sqlSessionFactory(DataSource dataSource){
        SqlSessionFactoryBean factory = new SqlSessionFactoryBean();
        factory.setTypeAliasesPackage("com.jkj.pojo");
        factory.setDataSource(dataSource);
        return factory;
2.映射配置转化为:
 @Bean
    public MapperScannerConfigurer mapperScannerConfigurer(){
        MapperScannerConfigurer msc = new MapperScannerConfigurer();
        msc.setBasePackage("com.jkj.dao");
        return msc;
3.案例
首先创建一个数据库Spring设计一个表,表名为j_account
1.j_account
2.导入依赖
 <dependencies>
        <dependency>
            <groupId>org.springframework</groupId>
            <artifactId>spring-context</artifactId>
            <version>5.2.10.RELEASE</version>
        </dependency>
        <dependency>
            <groupId>com.alibaba</groupId>
            <artifactId>druid</artifactId>
            <version>1.1.16</version>
        </dependency>
        <dependency>
            <groupId>org.mybatis</groupId>
            <artifactId>mybatis</artifactId>
            <version>3.5.6</version>
        </dependency>
        <dependency>
            <artifactId>spring-jdbc</artifactId>
        </dependency>
        <dependency>
            <artifactId>mybatis-spring</artifactId>
            <version>1.3.0</version>
        </dependency>
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <version>5.1.47</version>
        </dependency>
    </dependencies>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
3.Account
package com.jkj.pojo;
public class Account {
    private Integer id;
    private String name;
    private Double money;
    public Account() {
    public Account(Integer id, String name, Double money) {
        this.id = id;
        this.name = name;
        this.money = money;
    public Integer getId() {
        return id;
    public void setId(Integer id) {
        this.id = id;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
    public Double getMoney() {
        return money;
    public void setMoney(Double money) {
        this.money = money;
    @Override
    public String toString() {
        return "Account{" +
                "id=" + id +
                ", name='" + name + '\'' +
                ", money=" + money +
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
4.AccountDao
package com.jkj.dao;
import com.jkj.pojo.Account;
import org.apache.ibatis.annotations.Delete;
import org.apache.ibatis.annotations.Insert;
import org.apache.ibatis.annotations.Select;
import org.apache.ibatis.annotations.Update;
import java.util.List;
public interface AccountDao {
    //查询全部
    @Select("select * from j_account")
    List<Account> findAll();
    //通过id查询
    @Select("select * from j_account where id=#{id}")
    Account FindById(Integer id);
    //增加数据
    @Insert("insert into j_account (id,name,money) values(id#{id},#{name},#{money})")
    void save(Account account);
    //删除数据
    @Delete("delete from j_account where id=#{id}")
    void delete(Integer id);
    //修改数据
    @Update("update j_account set name=#{name},money=#{money} where id=#{id}")
    Account update(Integer id);
  • 26
  • 27
  • 28
5.AccountService
package com.jkj.service;
public interface AccountService {
    //查询全部
    public List<Account> findAll();
    //通过id查询
    public Account FindById(Integer id);
    //增加数据
    public void save(Account account);
    //删除数据
    public void delete(Integer id);
    //修改数据
    public Account update(Integer id);
6.AccountServiceImpl
package com.jkj.service.impl;
import com.jkj.dao.AccountDao;
import com.jkj.service.AccountService;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Service;
@Service
public class AccountServiceImpl implements AccountService {
    @Autowired
   private AccountDao accountDao;
    public List<Account> findAll() {
        return accountDao.findAll();
    public Account FindById(Integer id) {
        return accountDao.FindById(id);
    public void save(Account account) {
      accountDao.save(account);
    public void delete(Integer id) {
        accountDao.delete(id);
    public Account update(Integer id) {
        return accountDao.update(id);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
7.JdbcConfig
package com.jkj.config;
import com.alibaba.druid.pool.DruidDataSource;
import org.springframework.beans.factory.annotation.Value;
import org.springframework.context.annotation.Bean;
import javax.sql.DataSource;
public class JdbcConfig {
    @Value("com.mysql.jdbc.Driver")
    private String driver;
    @Value("jdbc:mysql://localhost:3306/spring")
    private String url;
    @Value("root")
    private String username;
    @Value("root")
    private String password;
    //2.添加@Bean,表示当前方法的返回值是一个bean
    @Bean
    //1.定义一个方法获得要管理的对象
    public DataSource dataSource(){
        DruidDataSource ds = new DruidDataSource();
        ds.setDriverClassName(driver);
        ds.setUrl(url);
        ds.setUsername(username);
        ds.setPassword(password);
        return ds;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
8.MyBatisConfig
import org.mybatis.spring.SqlSessionFactoryBean;
import org.mybatis.spring.mapper.MapperScannerConfigurer;
public class MyBatisConfig {
    @Bean
        return factory;
    @Bean
        return msc;
9.SpringConfig
import org.springframework.context.annotation.ComponentScan;
import org.springframework.context.annotation.Configuration;
import org.springframework.context.annotation.Import;
import org.springframework.context.annotation.PropertySource;
@Configuration
@ComponentScan("com.jkj")
@PropertySource("jdbc.properties")
@Import({JdbcConfig.class,MyBatisConfig.class})
public class SpringConfig {
10.Test测试类
import com.jkj.config.SpringConfig;
import org.springframework.context.annotation.AnnotationConfigApplicationContext;
import java.util.ArrayList;
public class Test {
        AnnotationConfigApplicationContext context = new AnnotationConfigApplicationContext(SpringConfig.class);
        AccountService bean = context.getBean(AccountService.class,true);
        //查询全部
        List<Account> all = bean.findAll();
        for (Account account : all) {
            System.out.println(account);
            Account{id=1, name='tom', money=2345.0}
            Account{id=2, name='jery', money=34567.0}
        //根据id查询
       /* Account byId = bean.FindById(1);
        System.out.println(byId);  //Account{id=1, name='tom', money=2345.0}*/
       //删除数据
       /* bean.delete(1);*/
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
二、整合Junit
1.导入依赖
 <dependency>
            <groupId>junit</groupId>
            <artifactId>junit</artifactId>
            <version>4.12</version>
            <scope>test</scope>
        </dependency>
        <dependency>
            <artifactId>spring-test</artifactId>
        </dependency>
2.使用Spring整合Junit专用类加载器
package com.jkj;
import org.junit.Test;
import org.junit.runner.RunWith;
import org.springframework.test.context.ContextConfiguration;
import org.springframework.test.context.junit4.SpringJUnit4ClassRunner;
@RunWith(SpringJUnit4ClassRunner.class)
@ContextConfiguration(classes = SpringConfig.class)
public class ServiceTest {
    @Autowired
    private AccountService as;
    @Test
    public void test(){
        Account byId = as.FindById(1);
文章来源: blog.csdn.net,作者:不会压弯的小飞侠,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_43514330/article/details/125446709
