MyBatis的增删改查操作(详细代码)
不会压弯的小飞侠 发表于 2022/08/08 22:45:22 2022/08/08
【摘要】 🍁博客主页:👉不会压弯的小飞侠 ✨欢迎关注:👉点赞👍收藏⭐留言✒ ✨系列专栏:👉MyBatis详解 ✨如果觉得博主的文章还不错的话,请三连支持一下博主。 🔥欢迎大佬指正,一起 学习!...
🍁博客主页:👉不会压弯的小飞侠
✨欢迎关注:👉点赞👍收藏⭐留言✒
✨系列专栏:👉MyBatis详解
🔥欢迎大佬指正,一起 学习!一起加油!
一、案例
1.pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>org.example</groupId>
    <artifactId>MyBatis-Demo1</artifactId>
    <version>1.0-SNAPSHOT</version>
    <dependencies>
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <version>5.1.32</version>
        </dependency>
        <dependency>
            <groupId>org.mybatis</groupId>
            <artifactId>mybatis</artifactId>
            <version>3.4.6</version>
        </dependency>
        <dependency>
            <groupId>junit</groupId>
            <artifactId>junit</artifactId>
            <version>4.12</version>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>log4j</groupId>
            <artifactId>log4j</artifactId>
            <version>1.2.17</version>
        </dependency>
    </dependencies>
</project>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
2.User
package com.jkj.domain;
public class User {
    private int id;
    private String username;
    private String password;
    public int getId() {
        return id;
    public void setId(int id) {
        this.id = id;
    public String getUsername() {
        return username;
    public void setUsername(String username) {
        this.username = username;
    public String getPassword() {
        return password;
    public void setPassword(String password) {
        this.password = password;
    @Override
    public String toString() {
        return "User{" +
                "id=" + id +
                ", username='" + username + '\'' +
                ", password='" + password + '\'' +
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
3.user数据表
4.mybatis-config.xml
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE configuration
        PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-config.dtd">
<!--configuration core file-->
       <configuration>
    <environments default="development">
        <environment id="development">
            <transactionManager type="JDBC"/>
            <dataSource type="POOLED">
                <property name="driver" value="com.mysql.jdbc.Driver"/>
                <property name="url" value="jdbc:mysql://localhost:3306/mybatisthree?useSSL=false&amp;useUnicode=true&amp;characterEncoding=UTF-8"/>
                <property name="username" value="root"/>
                <property name="password" value="root"/>
            </dataSource>
        </environment>
    </environments>
    <!--加载sql映射文件-->
    <mappers>
        <mapper resource="com/jkj/mapper/UserMapper.xml"/>
    </mappers>
</configuration>
5.UserMapper.xml
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "http://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="userMapper">
   <!-- 查询-->
    <select id="findAll" resultType="com.jkj.domain.User">
        select * from user
    </select>
   <!-- 插入-->
    <insert id="save" parameterType="com.jkj.domain.User">
        insert into user values(#{id},#{username},#{password})
    </insert>
   <!-- 修改-->
    <update id="update" parameterType="com.jkj.domain.User">
        update user set username=#{username},password=#{password} where id=#{id}
    </update>
   <!-- 删除-->
    <delete id="delete" parameterType="com.jkj.domain.User">
        delete from user where id=#{id}
    </delete>
</mapper>
6.MyBatisTest测试类
package com.jkj.test;
import com.jkj.domain.User;
import org.apache.ibatis.io.Resources;
import org.apache.ibatis.session.SqlSession;
import org.apache.ibatis.session.SqlSessionFactory;
import org.apache.ibatis.session.SqlSessionFactoryBuilder;
import org.junit.Test;
import java.io.IOException;
import java.io.InputStream;
import java.util.List;
public class MyBatisTest {
    //查询
    @Test
    public void test() throws IOException {
        //1.加载MyBatis的核心配置文件获取sqlSessionFactory
        InputStream inputStream = Resources.getResourceAsStream("mybatis-config.xml");
        SqlSessionFactory sqlSessionFactory = new SqlSessionFactoryBuilder().build(inputStream);
        //2.获取sqlSession,执行sql
        SqlSession sqlSession = sqlSessionFactory.openSession();
        //3.执行sql
        List<User> users = sqlSession.selectList("userMapper.findAll");
        System.out.println(users);
        //4.释放资源
        sqlSession.close();
    //插入
    @Test
    public void save() throws IOException {
        //模拟User对象
        User user = new User();
        user.setUsername("科比");
        user.setPassword("123456");
        //3.执行sql
       sqlSession.insert("userMapper.save",user);
       //4.提交事务
        sqlSession.commit();
        //5.释放资源
        sqlSession.close();
    //修改
    @Test
    public void update() throws IOException {
        //模拟User对象
        user.setId(5);
        user.setUsername("RC");
        user.setPassword("555555");
        //3.执行sql
       sqlSession.update("userMapper.update",user);
        //4.提交事务
        //5.释放资源
        sqlSession.close();
    //删除
    //修改
    @Test
    public void delete() throws IOException {
        //3.执行sql
        sqlSession.delete("userMapper.delete",5);
        //4.提交事务
        //5.释放资源
        sqlSession.close();
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
二、sql操作注意的问题
  • 删除语句使用delete标签
  • Sql语句中使用#{任意字符串}方式引用传递的单个参数
  • 删除操作使用的API是sqlSession.delete(“命名空间.id”,Object)
  • 修改语句使用update标签
  • 修改操作使用的API是sqlSession.update(“命名空间.id”,实体对象)
  • 插入语句使用insert标签
  • 在映射文件中使用parameterType属性指定要插入的数据类型
  • Sql语句中使用#{实体属性名}方式引用实体中的属性值
  • 插入操作使用的API是sqlSession.insert(“命名空间.id”,实体对象);
  • 插入操作涉及数据库数据变化,所以要使用sqlSession对象显示的提交事务,即sqlSession.commit()
文章来源: blog.csdn.net,作者:不会压弯的小飞侠,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_43514330/article/details/125584866
