OpenCV中的深度学习车辆检测
Gere 发表于 2022/08/07 19:21:56 2022/08/07
【摘要】 完整源码GitHub使用高斯混合模型(BackgroundSubtractorMOG2)对背景建模,提取出前景使用中值滤波去掉椒盐噪声,再闭运算和开运算填充空洞使用cvBlob库追踪车辆,我稍微修改了cvBlob源码来通过编译由于要对背景建模,这个方法要求背景是静止的另外不同车辆白色区域不能连通,否则会认为是同一物体[cpp]  view plain  copyvoid processVid...
完整源码GitHub
  1. 使用高斯混合模型(BackgroundSubtractorMOG2)对背景建模,提取出前景
  2. 使用中值滤波去掉椒盐噪声,再闭运算和开运算填充空洞
  3. 使用cvBlob库追踪车辆,我稍微修改了cvBlob源码来通过编译
  1. void processVideo(char* videoFilename)
  2. {
  3.     Mat frame; // current frame
  4.     Mat fgMaskMOG2; // fg mask fg mask generated by MOG2 method
  5.     Mat bgImg; // background
  6.     Ptr<BackgroundSubtractorMOG2> pMOG2 = createBackgroundSubtractorMOG2(200, 36.0, false); // MOG2 Background subtractor
  7.
  8.     while (true)
  9.     {
  10.         VideoCapture capture(videoFilename);
  11.         if (!capture.isOpened())
  12.         {
  13.             cerr << "Unable to open video file: " << videoFilename << endl;
  14.             return;
  15.         }
  16.
  17.         int width = (int)capture.get(CV_CAP_PROP_FRAME_WIDTH);
  18.         int height = (int)capture.get(CV_CAP_PROP_FRAME_HEIGHT);
  19.
  20.         unique_ptr<IplImage, void(*)(IplImage*)> labelImg(cvCreateImage(cvSize(width, height), IPL_DEPTH_LABEL, 1),
  21.             [](IplImage* p){ cvReleaseImage(&p); });
  22.         CvBlobs blobs;
  23.         CvTracks tracks;
  24.
  25.         while (true)
  26.         {
  27.             // read input data. ESC or 'q' for quitting
  28.             int key = waitKey(1);
  29.             if (key == 'q' || key == 27)
  30.                 return;
  31.             if (!capture.read(frame))
  32.                 break;
  33.
  34.             // update background
  35.             pMOG2->apply(frame, fgMaskMOG2);
  36.             pMOG2->getBackgroundImage(bgImg);
  37.             imshow("BG", bgImg);
  38.             imshow("Original mask", fgMaskMOG2);
  39.
  40.             // post process
  41.             medianBlur(fgMaskMOG2, fgMaskMOG2, 5);
  42.             imshow("medianBlur", fgMaskMOG2);
  43.             morphologyEx(fgMaskMOG2, fgMaskMOG2, MORPH_CLOSE, getStructuringElement(MORPH_RECT, Size(5, 5))); // fill black holes
  44.             morphologyEx(fgMaskMOG2, fgMaskMOG2, MORPH_OPEN, getStructuringElement(MORPH_RECT, Size(5, 5))); // fill white holes
  45.             imshow("morphologyEx", fgMaskMOG2);
  46.
  47.             // track
  48.             cvLabel(&IplImage(fgMaskMOG2), labelImg.get(), blobs);
  49.             cvFilterByArea(blobs, 64, 10000);
  50.             cvUpdateTracks(blobs, tracks, 10, 90, 30);
  51.             cvRenderTracks(tracks, &IplImage(frame), &IplImage(frame));
  52.
  53.             // show
  54.             imshow("Frame", frame);
  55.
  56.             key = waitKey(30);
  57.         }
  58.     }
  59. }
