Android:点击按钮,保存图片到本地相册
zstar 发表于 2022/08/06 22:31:40 2022/08/06
【摘要】 效果:点击按钮,将ImageView的图片保存到相册中。 activity_main: <?xml version="1.0" encoding="utf-8"?> <LinearL...
activity_main:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="match_parent"
    android:orientation="vertical"
    android:layout_height="match_parent" >
    <Button
        android:layout_width="wrap_content"
        android:id="@+id/tvSave"
        android:layout_marginTop="15dp"
        android:text="保存"
        android:layout_height="wrap_content" />
    <TextView
        android:id="@+id/tvpath"
        android:text="保存"
    <TextView
        android:id="@+id/tvpath2"
        android:text="保存"
    <ImageView
        android:id="@+id/imgPingjia2"
        android:layout_marginLeft="15dp"
        android:layout_gravity="center_horizontal"
        android:src="@mipmap/img_default_bg" />
</LinearLayout>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
MainActivity.java
package com.netease.nim.imagesave;
import android.Manifest;
import android.content.Intent;
import android.content.pm.PackageManager;
import android.graphics.Bitmap;
import android.graphics.Canvas;
import android.net.Uri;
import android.os.Environment;
import android.os.Handler;
import android.os.Message;
import android.provider.MediaStore;
import android.support.v4.app.ActivityCompat;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.ImageView;
import android.widget.TextView;
import android.widget.Toast;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
public class MainActivity extends AppCompatActivity {
    Button tvSave;
    ImageView imageShowPic;
    TextView tvpath;
    TextView tvpath2;
    private String savedPath = Environment.getExternalStorageDirectory().getAbsolutePath() +
            File.separator  + String.valueOf(System.currentTimeMillis()) + ".png";
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        tvpath = findViewById(R.id.tvpath);
        tvpath2 = findViewById(R.id.tvpath2);
        imageShowPic = findViewById(R.id.imgPingjia2);
        imageShowPic.setImageResource( R.mipmap.demo_tribe_header );
        tvSave = findViewById(R.id.tvSave);
        tvSave.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View view) {
//                tvSave.setClickable(false);
//相关权限的申请 存储权限
                try {
                    if (ActivityCompat.checkSelfPermission(MainActivity.this, Manifest.permission.READ_EXTERNAL_STORAGE)
                            != PackageManager.PERMISSION_GRANTED
                            || ActivityCompat.checkSelfPermission(MainActivity.this, Manifest.permission.WRITE_EXTERNAL_STORAGE)
                            != PackageManager.PERMISSION_GRANTED) {
// 申请一个(或多个)权限,并提供用于回调返回的获取码(用户定义)
                        ActivityCompat.requestPermissions(MainActivity.this, new String[]{Manifest.permission.READ_EXTERNAL_STORAGE, Manifest.permission.WRITE_EXTERNAL_STORAGE}, 1);
//                        mLDialog.setDialogText("正在保存图片...");
//                        mLDialog.show();
                        saveMyBitmap("AuthCode", createViewBitmap(imageShowPic));
                } catch (Exception e) {
                    e.printStackTrace();
    //权限申请的回调
    @Override
    public void onRequestPermissionsResult(int requestCode,
                                           String permissions[], int[] grantResults) {
        switch (requestCode) {
            case 1: {
// If request is cancelled, the result arrays are empty.
                if (grantResults.length > 0
                        && grantResults[0] == PackageManager.PERMISSION_GRANTED) {
//                    mLDialog.show();
                    try {
                    tvSave.setClickable(true);
                    Toast.makeText(MainActivity.this, "请先开启读写权限", Toast.LENGTH_SHORT).show();
                return;
    //使用IO流将bitmap对象存到本地指定文件夹
    public void saveMyBitmap(final String bitName, final Bitmap bitmap) {
        new Thread(new Runnable() {
            @Override
            public void run() {
                String filePath = Environment.getExternalStorageDirectory().getPath();
                File file = new File(savedPath);
                try {
                    file.createNewFile();
                    FileOutputStream fOut = null;
                    fOut = new FileOutputStream(file);
                    bitmap.compress(Bitmap.CompressFormat.PNG, 100, fOut);
                    Message msg = Message.obtain();
                    msg.obj = file.getPath();
                    handler.sendMessage(msg);
//Toast.makeText(PayCodeActivity.this, "保存成功", Toast.LENGTH_LONG).show();
                    fOut.flush();
                    fOut.close();
                } catch (IOException e) {
        }).start();
    Handler handler = new Handler() {
        @Override
        public void handleMessage(Message msg) {
            super.handleMessage(msg);
            String picFile = (String) msg.obj;
            String[] split = picFile.split("/");
            String fileName = split[split.length - 1];
            try {
                MediaStore.Images.Media.insertImage(getApplicationContext()
                        .getContentResolver(), picFile, fileName, null);
            } catch (FileNotFoundException e) {
// 最后通知图库更新
            sendBroadcast(new Intent(
                    Intent.ACTION_MEDIA_SCANNER_SCAN_FILE, Uri.parse("file://"
                    + picFile)));
            Toast.makeText(MainActivity.this, "图片保存图库成功", Toast.LENGTH_LONG).show();
//            if (mLDialog != null && mLDialog.isShowing()) {
//                mLDialog.dismiss();
    //将要存为图片的view传进来 生成bitmap对象
    public Bitmap createViewBitmap(View v) {
        Bitmap bitmap = Bitmap.createBitmap(v.getWidth(), v.getHeight(),
                Bitmap.Config.ARGB_8888);
        Canvas canvas = new Canvas(bitmap);
        v.draw(canvas);
        return bitmap;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
参考资源:
https://download.csdn.net/download/wangqing830414/11197239
文章来源: zstar.blog.csdn.net,作者:zstar-_,版权归原作者所有,如需转载,请联系作者。
原文链接:zstar.blog.csdn.net/article/details/120393529
