Android:轮播图ViewPager自动轮播最简单方法
zstar 发表于 2022/08/06 00:37:43 2022/08/06
【摘要】 由于博主学疏才浅,并未了解ViewPager底层逻辑,仅仅将可用的方法加以记录。 最新版的使用轮播图,需要在xml文件中添加 <androidx.viewpager.widget.ViewPag...
 <androidx.viewpager.widget.ViewPager
                android:id="@+id/indicator_all"
                android:layout_width="match_parent"
                android:layout_height="match_parent"
            </androidx.viewpager.widget.ViewPager>
之后编写方法
public class shouye extends Fragment {
    View view1,view2,view3,view4;
    private List<View> viewList;
    ViewPager viewPager;
    private Spinner spinner;
    private ArrayAdapter adapter;
    @Nullable
    @Override
    public View onCreateView(LayoutInflater inflater, @Nullable ViewGroup container, @Nullable Bundle savedInstanceState) {
        View view = inflater.inflate(R.layout.fragment_shouye, container, false);
        viewPager = (ViewPager) view.findViewById(R.id.indicator_all);
        inflater = getLayoutInflater();
        view1 = inflater.inflate(R.layout.layout1, null);
        view2 = inflater.inflate(R.layout.layout2, null);
        view3 = inflater.inflate(R.layout.layout3, null);
        view4 = inflater.inflate(R.layout.layout4, null);
        viewList = new ArrayList<View>();// 将要分页显示的View装入数组中
        viewList.add(view1);
        viewList.add(view2);
        viewList.add(view3);
        viewList.add(view4);
        PagerAdapter pagerAdapter = new PagerAdapter() {
            @Override
            public boolean isViewFromObject(@NonNull View arg0, @NonNull Object arg1) {
                // TODO Auto-generated method stub
                return arg0 == arg1;
            @Override
            public int getCount() {
                return viewList.size();
            @Override
            public void destroyItem(ViewGroup container, int position,
                                    @NonNull Object object) {
                container.removeView(viewList.get(position));
            @NonNull
            @Override
            public Object instantiateItem(ViewGroup container, int position) {
                container.addView(viewList.get(position));
                return viewList.get(position);
        viewPager.setAdapter(pagerAdapter);
        mHandler.sendEmptyMessageDelayed(0, 1000*2);
        return view;
    private Handler mHandler = new Handler() {
        public void handleMessage(Message msg) {
            int count = 4;
            int index=viewPager.getCurrentItem();
            index=(index+1)%count;
            viewPager.setCurrentItem(index);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
图片的自动轮播参考了Android之ViewPager自动循环播放(轮播)效果实现(超简单)
填充的资源文件中放置图片
layout_1
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_height="match_parent">
    <ImageView
        android:background="@drawable/pc1">
    </ImageView>
</LinearLayout>
2022-3-22更
如果需要在轮播图上加导航点,可参考这篇博客
带有导航点的ViewPager
文章来源: zstar.blog.csdn.net,作者:zstar-_,版权归原作者所有,如需转载,请联系作者。
原文链接:zstar.blog.csdn.net/article/details/115945695
