axios的配置对象说明(config)
十八岁讨厌编程 发表于 2022/08/05 22:34:04 2022/08/05
【摘要】 文章目录 axios的配置对象(config) axios的配置对象(config) 这些是用于发出请求的可用配置选项 { // `url` is the server URL th...
axios的配置对象(config)
这些是用于发出请求的可用配置选项
  // `url` is the server URL that will be used for the request
  url: '/user',
  // `method` is the request method to be used when making the request
  method: 'get', // default
  // `baseURL` will be prepended to `url` unless `url` is absolute.
  // It can be convenient to set `baseURL` for an instance of axios to pass relative URLs
  // to methods of that instance.
  baseURL: 'https://some-domain.com/api/',
  // `transformRequest` allows changes to the request data before it is sent to the server
  // This is only applicable for request methods 'PUT', 'POST', 'PATCH' and 'DELETE'
  // The last function in the array must return a string or an instance of Buffer, ArrayBuffer,
  // FormData or Stream
  // You may modify the headers object.
  transformRequest: [function (data, headers) {
    // Do whatever you want to transform the data
    return data;
  // `transformResponse` allows changes to the response data to be made before
  // it is passed to then/catch
  transformResponse: [function (data) {
    return data;
  // `headers` are custom headers to be sent
  headers: {'X-Requested-With': 'XMLHttpRequest'},
  // `params` are the URL parameters to be sent with the request
  // Must be a plain object or a URLSearchParams object
  params: {
  // `paramsSerializer` is an optional function in charge of serializing `params`
  // (e.g. https://www.npmjs.com/package/qs, http://api.jquery.com/jquery.param/)
  paramsSerializer: function (params) {
    return Qs.stringify(params, {arrayFormat: 'brackets'})
  // `data` is the data to be sent as the request body
  // Only applicable for request methods 'PUT', 'POST', 'DELETE , and 'PATCH'
  // When no `transformRequest` is set, must be of one of the following types:
  // - string, plain object, ArrayBuffer, ArrayBufferView, URLSearchParams
  // - Browser only: FormData, File, Blob
  // - Node only: Stream, Buffer
  data: {
    firstName: 'Fred'
  // syntax alternative to send data into the body
  // method post
  // only the value is sent, not the key
  data: 'Country=Brasil&City=Belo Horizonte',
  // `timeout` specifies the number of milliseconds before the request times out.
  // If the request takes longer than `timeout`, the request will be aborted.
  timeout: 1000, // default is `0` (no timeout)
  // `withCredentials` indicates whether or not cross-site Access-Control requests
  // should be made using credentials
  withCredentials: false, // default
  // `adapter` allows custom handling of requests which makes testing easier.
  // Return a promise and supply a valid response (see lib/adapters/README.md).
  adapter: function (config) {
  // `auth` indicates that HTTP Basic auth should be used, and supplies credentials.
  // This will set an `Authorization` header, overwriting any existing
  // `Authorization` custom headers you have set using `headers`.
  // Please note that only HTTP Basic auth is configurable through this parameter.
  // For Bearer tokens and such, use `Authorization` custom headers instead.
  auth: {
    username: 'janedoe',
    password: 's00pers3cret'
  // `responseType` indicates the type of data that the server will respond with
  // options are: 'arraybuffer', 'document', 'json', 'text', 'stream'
  //   browser only: 'blob'
  responseType: 'json', // default
  // `responseEncoding` indicates encoding to use for decoding responses (Node.js only)
  // Note: Ignored for `responseType` of 'stream' or client-side requests
  responseEncoding: 'utf8', // default
  // `xsrfCookieName` is the name of the cookie to use as a value for xsrf token
  xsrfCookieName: 'XSRF-TOKEN', // default
  // `xsrfHeaderName` is the name of the http header that carries the xsrf token value
  xsrfHeaderName: 'X-XSRF-TOKEN', // default
  // `onUploadProgress` allows handling of progress events for uploads
  // browser only
  onUploadProgress: function (progressEvent) {
    // Do whatever you want with the native progress event
  // `onDownloadProgress` allows handling of progress events for downloads
  // browser only
  onDownloadProgress: function (progressEvent) {
  // `maxContentLength` defines the max size of the http response content in bytes allowed in node.js
  maxContentLength: 2000,
  // `maxBodyLength` (Node only option) defines the max size of the http request content in bytes allowed
  maxBodyLength: 2000,
  // `validateStatus` defines whether to resolve or reject the promise for a given
  // HTTP response status code. If `validateStatus` returns `true` (or is set to `null`
  // or `undefined`), the promise will be resolved; otherwise, the promise will be
  // rejected.
  validateStatus: function (status) {
    return status >= 200 && status < 300; // default
  // `maxRedirects` defines the maximum number of redirects to follow in node.js.
  // If set to 0, no redirects will be followed.
  maxRedirects: 21, // default
  // `beforeRedirect` defines a function that will be called before redirect.
  // Use this to adjust the request options upon redirecting,
  // to inspect the latest response headers,
  // or to cancel the request by throwing an error
  // If maxRedirects is set to 0, `beforeRedirect` is not used.
  beforeRedirect: (options, { headers }) => {
    if (options.hostname === "example.com") {
      options.auth = "user:password";
  // `socketPath` defines a UNIX Socket to be used in node.js.
  // e.g. '/var/run/docker.sock' to send requests to the docker daemon.
  // Only either `socketPath` or `proxy` can be specified.
  // If both are specified, `socketPath` is used.
  socketPath: null, // default
  // `httpAgent` and `httpsAgent` define a custom agent to be used when performing http
  // and https requests, respectively, in node.js. This allows options to be added like
  // `keepAlive` that are not enabled by default.
  httpAgent: new http.Agent({ keepAlive: true }),
  httpsAgent: new https.Agent({ keepAlive: true }),
  // `proxy` defines the hostname, port, and protocol of the proxy server.
  // You can also define your proxy using the conventional `http_proxy` and
  // `https_proxy` environment variables. If you are using environment variables
  // for your proxy configuration, you can also define a `no_proxy` environment
  // variable as a comma-separated list of domains that should not be proxied.
  // Use `false` to disable proxies, ignoring environment variables.
  // `auth` indicates that HTTP Basic auth should be used to connect to the proxy, and
  // supplies credentials.
  // This will set an `Proxy-Authorization` header, overwriting any existing
  // `Proxy-Authorization` custom headers you have set using `headers`.
  // If the proxy server uses HTTPS, then you must set the protocol to `https`.
  proxy: {
    protocol: 'https',
    host: '127.0.0.1',
    port: 9000,
    auth: {
      username: 'mikeymike',
      password: 'rapunz3l'
  // `cancelToken` specifies a cancel token that can be used to cancel the request
  // (see Cancellation section below for details)
  cancelToken: new CancelToken(function (cancel) {
  // an alternative way to cancel Axios requests using AbortController
  signal: new AbortController().signal,
  // `decompress` indicates whether or not the response body should be decompressed
  // automatically. If set to `true` will also remove the 'content-encoding' header
  // from the responses objects of all decompressed responses
  // - Node only (XHR cannot turn off decompression)
  decompress: true // default
  // `insecureHTTPParser` boolean.
  // Indicates where to use an insecure HTTP parser that accepts invalid HTTP headers.
  // This may allow interoperability with non-conformant HTTP implementations.
  // Using the insecure parser should be avoided.
  // see options https://nodejs.org/dist/latest-v12.x/docs/api/http.html#http_http_request_url_options_callback
  // see also https://nodejs.org/en/blog/vulnerability/february-2020-security-releases/#strict-http-header-parsing-none
  insecureHTTPParser: undefined // default
  // transitional options for backward compatibility that may be removed in the newer versions
  transitional: {
    // silent JSON parsing mode
    // `true`  - ignore JSON parsing errors and set response.data to null if parsing failed (old behaviour)
    // `false` - throw SyntaxError if JSON parsing failed (Note: responseType must be set to 'json')
    silentJSONParsing: true, // default value for the current Axios version
    // try to parse the response string as JSON even if `responseType` is not 'json'
    forcedJSONParsing: true,
    // throw ETIMEDOUT error instead of generic ECONNABORTED on request timeouts
    clarifyTimeoutError: false,
  env: {
    // The FormData class to be used to automatically serialize the payload into a FormData object
    FormData: window?.FormData || global?.FormData
其中有几个注意点:
  • baseURL是一个URL的基础结构,axios内部会自动将baseURL与url进行一个结合,形成最终的url结果。例如你可以将域名和协议写在baseURL中,而在url中直接写路径
  • transformRequest可以对请求的数据进行一个处理,处理完之后,再将处理的结果发送给服务器。(对请求参数进行一个预处理)
  • transformResponse可以对相应的数据进行处理,改变完之后我们再用自定义的回调去处理这个结果。(对响应参数进行一个预处理)
  • headers对请求头信息进行一个配置
  • params对url参数(准确的说是url里面的查询字符串)进行设置
例如:
axios({
       url: '/post',
      //post?a=100&b=200
        params: {
            a:100,
            b:200
  • paramsSerializer是一个参数序列化的配置对象(用的相对较少),作用:对请求的参数进行一个序列化,转化成一个字符串。根据服务器端接口的要求,对这个对象进行处理,与服务器进行一个统一
例如:
/post?a=100&b=2 00
//  /post/a/100/b/200
//  /post/a.100/b.200
  • data是请求体设置,有两种形式:对象形式和字符串形式。如果是对象形式,axios会将其转化为json形式字符串;如果是字符串形式,那么axios会直接传递
  • timeout为超时时间,发送请求时如果超过时间则这个请求就会被取消。单位为毫秒
  • withCredentials在跨域请求时对cookie的携带作一个设置。false为不携带,true则在跨域请求时可以携带cookie。
  • adapter对请求的适配器进行设置
  • responseType响应体结果的格式做一个设置,默认值是json
  • responseEncoding响应结果的编码设置
  • xsrfCookieName、xsrfHeaderName跨站请求的标识,对cookie的名字和头信息进行设置
  • onUploadProgress在上传的时候做出的回调
  • onDownloadProgress在下载的时候做出的回调
  • maxContentLength设置http响应的最大尺寸,单位:字节
  • maxBodyLength设置请求体的最大尺寸,单位:字节
  • validateStatus对响应结果的成功进行一个设置。也就是说什么情况下才认定他是成功的。默认值为响应代码大于200,小于300.(status >= 200 && status < 300)
  • maxRedirects设置最大跳转次数
  • socketPath设定socket文件的位置。作用:向docker的守护进程发送请求。
  • httpAgent、 httpsAgent对客户端的信息进行设置
  • proxy设置代理
  • cancelToken对AJAX请求做一个取消的设置
  • decompress设置对响应结果是不是做一个解压。默认:解压
文章来源: blog.csdn.net,作者:十八岁讨厌编程,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/zyb18507175502/article/details/124065253
