Little Girl and Maximum XOR(区间最大异或值--技巧)-------------C语言——菜鸟级
Fivecc 发表于 2022/08/06 00:43:37 2022/08/06
【摘要】 A little girl loves problems on bitwise operations very much. Here’s one of them. You are given two i...
You are given two integers l and r. Let’s consider the values of for all pairs of integers a and b (l ≤ a ≤ b ≤ r). Your task is to find the maximum value among all considered ones.
Expression means applying bitwise excluding or operation to integers x and y. The given operation exists in all modern programming languages, for example, in languages C++ and Java it is represented as “^”, in Pascal — as «xor».
Input
The single line contains space-separated integers l and r (1 ≤ l ≤ r ≤ 1018).
Please, do not use the %lld specifier to read or write 64-bit integers in С++. It is preferred to use the cin, cout streams or the %I64d specifier.
Output
In a single line print a single integer — the maximum value of for all pairs of integers a, b (l ≤ a ≤ b ≤ r).
Example
Input
1 2
Output
3
Input
8 16
Output
31
Input
1 1
Output
0
【题解】
首先,异或值要为1,那么两个数的对应二进制位要不同,而异或值要最大,则二进制的高位要尽可能的为1,所以这就是切入点,从给定的区间上下限入手(l和R),从l和r二进制的最高位开始比较,如果出现对应位异或值位1,就从该处开始,低位都置为1,此时其表示的数就是最大异或值了。
#include<stdio.h>
int  main()
 long long l,r,t,w;
 while(scanf("%lld%lld",&l,&r)!=EOF)
   if(r==l)printf("0\n");
   else
   {w=0;
       while(r!=l&&r!=0)//相等或最大值为0 结束                101011
       {                //相等则证明 此位之前的异或不可能为1  101110
          w++;
          l=l>>1;//从右向左移动
          r=r>>1;
        t=1;
       while(w--)t=t*2;
       printf("%lld\n",t-1);
   return 0;
文章来源: fivecc.blog.csdn.net,作者:Five-菜鸟级,版权归原作者所有,如需转载,请联系作者。
原文链接:fivecc.blog.csdn.net/article/details/80294348
