解决报错: YarnScheduler: Initial job has not accepted any resources
野猪佩奇996 发表于 2022/08/04 23:05:07 2022/08/04
【摘要】 文章目录 一、问题描述二、解决方案 一、问题描述 在运行某个Pyspark代码时报错如下: Warning: Ignoring non-Spark config property: de...
一、问题描述
Warning: Ignoring non-Spark config property: deploy-mode
Setting default log level to "WARN".
To adjust logging level use sc.setLogLevel(newLevel). For SparkR, use setLogLevel(newLevel).
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4040. Attempting port 4041.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4041. Attempting port 4042.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4042. Attempting port 4043.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4043. Attempting port 4044.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4044. Attempting port 4045.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4045. Attempting port 4046.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4046. Attempting port 4047.
22/08/02 11:35:34 WARN [Thread-4] Utils: Service 'SparkUI' could not bind on port 4047. Attempting port 4048.
22/08/02 11:35:35 WARN [Thread-4] Client: Neither spark.yarn.jars nor spark.yarn.archive is set, falling back to uploading libraries under SPARK_HOME.
二、解决方案
上面是因为在yarn上执行spark作业时,其他的app占用了集群资源,导致新的job无法使用足够的资源,可以Kill掉相应的job再试试:
lsof -i:4041
lsof -i:4042
kill -9 进程id
查了下其他的说法:spark-shell里面又单独的设置了spark的context,因为spark-shell里已经有一个context对象了,所以新建创建的数据无法使用。
文章来源: andyguo.blog.csdn.net,作者:山顶夕景,版权归原作者所有,如需转载,请联系作者。
原文链接:andyguo.blog.csdn.net/article/details/126128929
