SAP 电商云 Spartacus UI 和 Accelerator UI 里的 ASM 模块
汪子熙 发表于 2022/07/31 11:26:14 2022/07/31
【摘要】 https://spartacus-demo.eastus.cloudapp.azure.com/electronics-spa/en/USD/?asm=trueurl 后面加了 ?asm=true 之后,在登录界面上方也会多出一个 Start Session 的按钮:选择当前 site 上一个客户,比如 Jerry Wang:从源代码分析,Spartacus UI 上确实没有显示 Plac...
从源代码分析,Spartacus UI 上确实没有显示 Placed by 字段:
只有 Placed on 字段:
Placed by 字段只用在 B2B 里:
https://localhost:9002/acceleratorservices/sop-mock/process
从 Accelerator 里看到上面这个请求的响应值:
Request URL: https://localhost:9002/acceleratorservices/sop-mock/process
直接访问是 405 Method Not Allowed
我试下直接 checkout,不走 ASM,会怎样。在 Backoffice Administration 面板能看到 Placed By 字段。
我们用来登录 ASM 的 asagent 是一个 employee:
在 ASM 模式下,输入客户名 Jerry,返回若干个匹配结果:
选中正确的那个 Jerry Wang:
electronics.local’s server IP address could not be found.
https://electronics.local:9002/yacceleratorstorefront/electronics/en/checkout/multi/sop/response
https://answers.sap.com/questions/12761210/unable-to-place-order-in-electronics-site.html
https://hybrisdiary.wordpress.com/2015/08/07/the-server-at-electronics-local-cant-be-found-because-the-dns-look-up-failed/
Your account has been locked. Please contact your system administrator.
