金鱼哥RHCA回忆录:CL210管理OPENSTACK网络--开放虚拟网络(OVN)简介(课后练习)
金鱼哥 发表于 2022/07/31 09:22:23 2022/07/31
【摘要】 第六章 管理OPENSTACK网络--开放虚拟网络(OVN)简介(课后练习)
🎹 个人简介:大家好,我是 金鱼哥,CSDN运维领域新星创作者,华为云·云享专家,阿里云社区·专家博主
📚个人资质:CCNA、HCNP、CSNA(网络分析师),软考初级、中级网络工程师、RHCSA、RHCE、RHCA、RHCI、ITIL😜
💬格言:努力不一定成功,但要想成功就必须努力🔥
🎈支持我:可点赞👍、可收藏⭐️、可留言📝
📜课本练习
  • 部署具有公共访问权的实例。
  • 创建安全组规则并检查OpenFlow流以获取安全策略。
  • 检查DHCP的OpenFlow规则
  • 查看OpenFlow中的路由表。
[student@workstation ~]$ lab networking-ovn setup
Setting up workstation for lab exercise work:
 • Verifying project: finance..................................  SUCCESS
 • Creating user env file: developer1-finance-rc...............  SUCCESS
 • Creating keypair: example-keypair...........................  SUCCESS
 . Creating flavor: default....................................  SUCCESS
 . Creating image: rhel7.......................................  SUCCESS
 . Creating internal network: finance-network1.................  SUCCESS
 . Creating subnet: finance-subnet1............................  SUCCESS
 . Creating external network: provider-datacentre..............  SUCCESS
 . Creating router: finance-router1............................  SUCCESS
 . Creating security group: default............................  SUCCESS
 . Creating security group rule: SSH...........................  SUCCESS
 . Creating security group rule ICMP: icmp.....................  SUCCESS
📑1.作为developer1用户,确认finance-network1存在,并检查网络的安全组规则。
[student@workstation ~]$ source developer1-finance-rc
[student@workstation ~(developer1-finance)]$ openstack network list -c ID -c Name
| ID                                   | Name                |
| 7a6556ab-6083-403e-acfc-79caf3873660 | finance-network1    |
| d55f6d1e-c29e-4825-8de4-01dd95f8a220 | provider-storage    |
| fc5472ee-98d9-4f6b-9bc9-544ca18aefb3 | provider-datacentre |
[root@controller0 ~]# ovs-vsctl list open
_uuid               : 6c237e8b-5014-42f1-9ac4-cc7728797597
bridges             : [1d420f80-91e3-44ad-85ff-b311d90a7538, b1eb4d87-1b0b-4541-aca6-e9adefbe8172, b2474c7c-c50c-4a22-8826-f1f9233bf5ab, eb5acfd9-bc1c-444e-9045-8d48aa6d01c5, efed7252-c6fe-487c-a1bc-0b4e6ee9a6d3]
cur_cfg             : 46
datapath_types      : [netdev, system]
db_version          : "7.15.1"
external_ids        : {hostname="controller0.overcloud.example.com", ovn-bridge=br-int, ovn-bridge-mappings="datacentre:br-ex,vlanprovider1:br-eth3,vlanprovider2:br-eth4,storage:br-trunk", ovn-cms-options=enable-chassis-as-gw, ovn-encap-ip="172.24.2.1", ovn-encap-type=geneve, ovn-remote="tcp:172.24.1.50:6642", rundir="/var/run/openvswitch", system-id="85c87734-e866-4225-b305-471357c68b8a"}
iface_types         : [geneve, gre, internal, lisp, patch, stt, system, tap, vxlan]
[root@controller0 ~]# export OVN_SB_DB=tcp:172.24.1.50:6642
[root@controller0 ~]# export OVN_NB_DB=tcp:172.24.1.50:6641
[root@controller0 ~]# ovn-nbctl ls-list
153db687-27fe-4f90-a3f0-2958c373dcc2 (neutron-7a6556ab-6083-403e-acfc-79caf3873660)
aca840be-670a-4eb3-9b36-4246c0eabb6c (neutron-9838d8ed-3e64-4196-87f0-a4bc59059be9)
b2cc3860-13f9-4eeb-b328-10dbc1f1b131 (neutron-d55f6d1e-c29e-4825-8de4-01dd95f8a220)
c5b32043-cd23-41ac-9197-ea41917870bb (neutron-e14d713e-c1f5-4800-8543-713563d7e82e)
f0f71887-2544-4f29-b46c-04b0aa0b2e52 (neutron-fc5472ee-98d9-4f6b-9bc9-544ca18aefb3)
[root@controller0 ~]# ovn-nbctl acl-list neutron-7a6556ab-6083-403e-acfc-79caf3873660
📑2. 在workstation终端上,作为developer1用户,创建一个名为finance-server1的新实例。
使用rhel7 镜像、默认风格、默认安全组和finance-network1网络。
[student@workstation ~(developer1-finance)]$  openstack server create --flavor default --image rhel7 --nic net-id=finance-network1 --security-group default --wait finance-server1
| Field                       | Value
| OS-DCF:diskConfig           | MANUAL
| OS-EXT-AZ:availability_zone | nova
| OS-EXT-STS:power_state      | Running
| OS-EXT-STS:task_state       | None
| OS-EXT-STS:vm_state         | active
| OS-SRV-USG:launched_at      | 2020-10-27T15:30:29.000000
| OS-SRV-USG:terminated_at    | None
| accessIPv4                  |
| accessIPv6                  |
| addresses                   | finance-network1=192.168.1.5
| adminPass                   | 7we6VaXXezF7
| config_drive                |
| created                     | 2020-10-27T15:29:57Z
| flavor                      | default (e04380ed-b027-4a72-a697-4307bc014b6c)
| hostId                      | c439f7c83de10e6a305fc9bc9caefdef52c9f503e4aa5733eae8573c
| id                          | e997cf6c-67a7-4947-935f-d56abce814a9
| image                       | rhel7 (6b0128a9-4481-4ceb-b34e-ffe92e0dcfdd)
| key_name                    | None
| name                        | finance-server1
| progress                    | 0
| project_id                  | 3c003f65d8d64914a053f178fbbf953c
| properties                  |
| security_groups             | name='default'
| status                      | ACTIVE
| updated                     | 2020-10-27T15:30:29Z
| user_id                     | e4035d555f6b88cf42ca4cacb9fa9999dca9787392222d2eb0875e4e34e6d76f
| volumes_attached            |
📑3. 在controller0上,重新检查finance-network1网络交换机的安全策略。
在workstation上,列出与安全组规则相匹配的OpenFlow流的默认安全组的安全组规则。将inport和ourport参数匹配到各自的OpenStack实体
[student@workstation ~(developer1-finance)]$ openstack port list -c ID -c 'Fixed IP Addresses'
| ID                                   | Fixed IP Addresses
| 3ad5f966-f682-4bc7-9f1e-2662cc2d950d | ip_address='192.168.1.1', subnet_id='4836a9dd-e01f-4a33-a971-fa49dec9ffd5' |
| 42671818-08d4-4a99-bd80-99a452ee40b3 | ip_address='192.168.1.2', subnet_id='4836a9dd-e01f-4a33-a971-fa49dec9ffd5' |
| 71467c2e-0460-4514-a6ce-e5885e60ccb3 | ip_address='192.168.1.5', subnet_id='4836a9dd-e01f-4a33-a971-fa49dec9ffd5' |
from-lport  1002 (inport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4) allow-related
from-lport  1002 (inport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.dst == {255.255.255.255, 192.168.1.0/24} && udp && udp.src == 68 && udp.dst == 67) allow
from-lport  1002 (inport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip6) allow-related
from-lport  1001 (inport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip) drop
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.src == $as_ip4_952467e9_b667_44ba_adb6_878c2e089308) allow-related
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.src == 0.0.0.0/0 && icmp4) allow-related
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 22) allow-related
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 443) allow-related
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 80) allow-related
  to-lport  1002 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip6 && ip6.src == $as_ip6_952467e9_b667_44ba_adb6_878c2e089308) allow-related
  to-lport  1001 (outport == "71467c2e-0460-4514-a6ce-e5885e60ccb3" && ip) drop
[student@workstation ~(developer1-finance)]$ openstack security group rule list -f json
    "IP Range": "0.0.0.0/0",
    "Security Group": "952467e9-b667-44ba-adb6-878c2e089308",
    "Port Range": "22:22",
    "IP Protocol": "tcp",
    "Remote Security Group": null,
    "ID": "212e6328-edc5-4e54-ac11-6c7e18254328"
    "IP Range": null,
    "Port Range": "",
    "IP Protocol": null,
    "ID": "24a91078-c261-4ec6-8f91-040044532cb1"
    "IP Range": null,
    "Port Range": "",
    "Remote Security Group": "952467e9-b667-44ba-adb6-878c2e089308",
    "ID": "40a2dbc0-2ec0-440d-b8df-ad69c6cedf0e"
    "Port Range": "443:443",
    "ID": "6b8aa744-cd3a-449f-bdca-dc75d70b1621"
    "Port Range": "80:80",
    "ID": "6de5bdd1-dc72-4c1c-af07-cd900c96ffa8"
    "IP Range": null,
    "Port Range": "",
    "ID": "a6587b8a-4c6b-4b7c-a809-fb8da6fb8602"
    "IP Range": null,
    "Port Range": "",
    "ID": "b125b62d-c9e0-44e6-a512-1b6da133f3cc"
    "Port Range": "",
    "IP Protocol": "icmp",
    "ID": "bcd0c999-dc5d-498c-8646-9c1faf9f5797"
📑4. 在finance-network1网络上创建第二个实例。在controller0节点上,列出安全规则流。
[student@workstation ~(developer1-finance)]$  openstack server create --flavor default --image rhel7 --nic net-id=finance-network1  --wait finance-server2
| Field                       | Value
| OS-SRV-USG:launched_at      | 2020-10-27T15:44:42.000000
| accessIPv4                  |
| accessIPv6                  |
| addresses                   | finance-network1=192.168.1.12
| adminPass                   | bsPAZRuFfA89
| config_drive                |
| created                     | 2020-10-27T15:43:59Z
| hostId                      | 3eb57302ddddc3af1fdc763eee541c699f0866f6458e3b5c9a722611
| id                          | 7a9ee0f5-1869-418f-9ae7-117d08a44499
| key_name                    | None
| name                        | finance-server2
| progress                    | 0
| properties                  |
| status                      | ACTIVE
| updated                     | 2020-10-27T15:44:42Z
| volumes_attached            |
| 9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1 | ip_address='192.168.1.12', subnet_id='4836a9dd-e01f-4a33-a971-fa49dec9ffd5' |
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip4 && ip4.src == $as_ip4_952467e9_b667_44ba_adb6_878c2e089308) allow-related
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip4 && ip4.src == 0.0.0.0/0 && icmp4) allow-related
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 22) allow-related
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 443) allow-related
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip4 && ip4.src == 0.0.0.0/0 && tcp && tcp.dst == 80) allow-related
  to-lport  1002 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip6 && ip6.src == $as_ip6_952467e9_b667_44ba_adb6_878c2e089308) allow-related
  to-lport  1001 (outport == "9ce01db2-7b5d-4d3f-ac08-9541d7d8fbf1" && ip) drop
📑5. 在workstation上,在provider-datacentre网络上创建一个浮动IP地址。将浮动IP连接到finance-server1。
使用openstack server list命令验证添加了浮动IP地址。
| ID                                   | Name                | Subnets
| 7a6556ab-6083-403e-acfc-79caf3873660 | finance-network1    | 4836a9dd-e01f-4a33-a971-fa49dec9ffd5 |
| d55f6d1e-c29e-4825-8de4-01dd95f8a220 | provider-storage    | 6e5af9b0-67ef-4e1e-9eda-7d6633091d11 |
| fc5472ee-98d9-4f6b-9bc9-544ca18aefb3 | provider-datacentre | 30c03fa5-0897-426a-8c81-75cf9cc333f1 |
[student@workstation ~(developer1-finance)]$ openstack floating ip create provider-datacentre
| Field               | Value                                |
| created_at          | 2020-10-27T15:51:12Z                 |
| description         |                                      |
| fixed_ip_address    | None                                 |
| floating_ip_address | 172.25.250.107                       |
| floating_network_id | fc5472ee-98d9-4f6b-9bc9-544ca18aefb3 |
| id                  | 00799d8c-56cb-4c62-b238-1f5396231f66 |
| name                | 172.25.250.107                       |
| port_id             | None                                 |
| project_id          | 3c003f65d8d64914a053f178fbbf953c     |
| qos_policy_id       | None                                 |
| revision_number     | 0                                    |
| router_id           | None                                 |
| status              | DOWN                                 |
| subnet_id           | None                                 |
| updated_at          | 2020-10-27T15:51:12Z                 |
[student@workstation ~(developer1-finance)]$ openstack server add floating ip  finance-server1 172.25.250.107
[student@workstation ~(developer1-finance)]$ openstack server list -c ID -c Name -c Networks
| ID                                   | Name            | Networks
| 7a9ee0f5-1869-418f-9ae7-117d08a44499 | finance-server2 | finance-network1=192.168.1.12
| e997cf6c-67a7-4947-935f-d56abce814a9 | finance-server1 | finance-network1=192.168.1.5, 172.25.250.107
📑6. 在controller0上,列出用于路由的OpenFlow流,并查看finance-network1网络交换机的路由表。
在controller0上,使用ovn-nbctl show命令来显示向北数据库内容的简要概述。。
在controller0上,使用ovn-sbctl lflow-list命令列出流。找到finance-server1的SNAT和DNAT流。找到路由流的最简单方法是将ovn-sbctl命令的输出重定向到一个文件。打开文件并使用搜索功能。请注意,浮动IP地址和内部IP地址都有OpenFlow规则。
[root@controller0 ~]# ovn-sbctl lflow-list > flow.txt
[root@controller0 ~]# less flow.txt
  table=3 (lr_in_unsnat       ), priority=100  , match=(ip && ip4.dst == 172.25.250.106 && inport == "l
rp-c88f518d-fac0-448f-9876-a40f469b00e9" && is_chassis_resident("cr-lrp-c88f518d-fac0-448f-9876-a40f469
b00e9")), action=(ct_snat;)
  table=3 (lr_in_unsnat       ), priority=100  , match=(ip && ip4.dst == 172.25.250.107 && inport == "l
rp-c88f518d-fac0-448f-9876-a40f469b00e9"), action=(ct_snat;)
  table=4 (lr_in_dnat         ), priority=100  , match=(ip && ip4.dst == 172.25.250.107 && inport == "l
rp-c88f518d-fac0-448f-9876-a40f469b00e9"), action=(ct_dnat(192.168.1.5);)
  table=4 (lr_in_dnat         ), priority=50   , match=(ip && ip4.dst == 172.25.250.107), action=(reg9[
0] = 1; next;)
  table=4 (lr_in_dnat         ), priority=0    , match=(1), action=(next;)
table=0 (lr_out_undnat      ), priority=100  , match=(ip && ip4.src == 192.168.1.5 && outport == "lrp
-c88f518d-fac0-448f-9876-a40f469b00e9"), action=(eth.src = fa:16:3e:85:3b:1b; ct_dnat;)
  table=0 (lr_out_undnat      ), priority=0    , match=(1), action=(next;)
  table=1 (lr_out_snat        ), priority=33   , match=(ip && ip4.src == 192.168.1.5 && outport == "lrp
-c88f518d-fac0-448f-9876-a40f469b00e9"), action=(eth.src = fa:16:3e:85:3b:1b; ct_snat(172.25.250.107);)
从上一步使用的SNAT或DNAT提取中,注意finance-server1使用的lrp inport和outport。在controller0上,使用ovn-nbctl show命令列出向北的数据库的内容。
[root@controller0 ~]# ovn-nbctl show
switch f0f71887-2544-4f29-b46c-04b0aa0b2e52 (neutron-fc5472ee-98d9-4f6b-9bc9-544ca18aefb3) (aka provider-datacentre)
    port provnet-fc5472ee-98d9-4f6b-9bc9-544ca18aefb3
        type: localnet
        addresses: ["unknown"]
    port c88f518d-fac0-448f-9876-a40f469b00e9
        type: router
        router-port: lrp-c88f518d-fac0-448f-9876-a40f469b00e9
    port d3a97fff-95de-447c-a962-01b43e0299de
        type: localport
        addresses: ["fa:16:3e:dc:ab:47"]
📑7. 显示finance-router1的路由表。
[student@workstation ~(developer1-finance)]$ openstack router list -c ID -c Name
| ID                                   | Name            |
| e05522ef-8a15-4b7d-87d5-50506144b76b | finance-router1 |
[root@controller0 ~]# ovn-nbctl lr-list
adedf86a-aa9d-443d-9b2b-14698a3cf9fa (neutron-e05522ef-8a15-4b7d-87d5-50506144b76b)
[root@controller0 ~]# ovn-nbctl lr-nat-list neutron-e05522ef-8a15-4b7d-87d5-50506144b76b
TYPE             EXTERNAL_IP        LOGICAL_IP            EXTERNAL_MAC         LOGICAL_PORT
dnat_and_snat    172.25.250.107     192.168.1.5           fa:16:3e:85:3b:1b    71467c2e-0460-4514-a6ce-e5885e60ccb3
snat             172.25.250.106     192.168.1.0/24
📑8. 在controller0上,使用ovn-sbctl命令列出逻辑流。将输出重定向到一个名为dhcp. txt文件。
查找ls_in_dhcp_options、ls_in_dhcp_response和put_dhcp_opts选择finance-server1的选项。
[root@controller0 ~]# ovn-sbctl lflow-list > dhcp.txt
[root@controller0 ~]# egrep 'ls_in_dhcp_options|ls_in_dhcp_response|put_dhcp_opts|192.168.1.5' dhcp.txt
📑清除实验
[student@workstation ~]$ lab networking-ovn cleanup
💡总结
RHCA认证需要经历5门的学习与考试,还是需要花不少时间去学习与备考的,好好加油,可以噶🤪。
以上就是【金鱼哥】对 第六章 管理OPENSTACK网络–开放虚拟网络(OVN)简介 的简述和讲解。希望能对看到此文章的小伙伴有所帮助。
💾红帽认证专栏系列:
RHCSA专栏:戏说 RHCSA 认证
RHCE专栏:戏说 RHCE 认证
此文章收录在RHCA专栏:RHCA 回忆录
如果这篇【文章】有帮助到你,希望可以给【金鱼哥】点个赞👍,创作不易,相比官方的陈述,我更喜欢用【通俗易懂】的文笔去讲解每一个知识点。
如果有对【运维技术】感兴趣,也欢迎关注❤️❤️❤️ 【金鱼哥】❤️❤️❤️,我将会给你带来巨大的【收获与惊喜】💕💕!
评论(0
