【C#】正序、逆序、最大值、最小值和平均值
南蓬幽 发表于 2022/07/27 17:04:02 2022/07/27
【摘要】 正序、逆序输入用空格分隔的五个整数,分别输出正序、逆序、平均值和最大值。首先输入整数将长度为5,即可以输入五个整数,并用空格隔开int[] myArray = new int[5]; string[] str =Console.ReadLine().Split(’ ');输出正序Array.Sort(myArray);Console.Write(“正序:”);for (int i = 0...
正序、逆序
首先输入整数
输出正序
for (int i = 0; i < 5; i++)
Console.Write(myArray[i]);
if (i != 4) Console.Write(",");
sum += myArray[i];
输出逆序
Array.Reverse(myArray);
Console.Write(“逆序:”);
输出平均数
double sum = 0;
double average;
            sum += myArray[i];
        average = sum / 5;
        string strAverage = average.ToString("0.0");
输出最大值
int max; Array.Sort(myArray); max = myArray[4];
代码
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ConsoleApp2
    class Program
        static void Main(string[] args)
            Console.WriteLine("请输入用空格分隔的5个整数:");
            string[] str = Console.ReadLine().Split(' ');
            try
                myArray[i] = int.Parse(str[i]);
            catch
                Console.WriteLine("输入错误!");
                return;
            double sum = 0;
            double average;
            int max;
            Console.Write("正序:");
                sum += myArray[i];
            max = myArray[4];
            average = sum / 5;
            Console.WriteLine();
            Console.Write("逆序:");
            Console.WriteLine("平均值:" + strAverage);
            Console.WriteLine("最大值:" + max);
            Console.ReadKey();
运行结果
最大值、最小值和平均值
代码
using System;
using System.Linq;
using System.Text;
namespace ConsoleApp5
    class Program
            double j = 1;
            int[] arr = new int[100];
            int sum = 0, maxl = 0, minl = 0;
            Console.WriteLine("请输入数字,输入-1结束输入");
            arr[0] = Int32.Parse(Console.ReadLine());
            sum += arr[0];
            maxl = arr[0];
            minl = arr[0];
            for (int i = 1; i < 100; i++)
                arr[i] = Int32.Parse(Console.ReadLine());
                if (arr[i] == -1)
                    break;
                sum += arr[i];
                maxl = Math.Max(maxl, arr[i]);
                minl = Math.Min(minl, arr[i]);
                ++j;
            double ave = (double)sum / j;
            Console.WriteLine("最大值"+maxl);
            Console.WriteLine("最小值"+minl);
            Console.WriteLine("平均值"+ave);
结果
