openvino安装踩坑笔记
风吹稻花香 发表于 2022/07/27 00:27:07 2022/07/27
【摘要】 目录 python版安装: c++版安装: openvino python报错(ImportError: DLL load failed while importing ie_api) python版安装: 安装2021.04版本: pip install openvino-dev==2021.04 pip inst...
目录
python版安装:
c++版安装:
python版安装:
安装2021.04版本:
pip install openvino==2021.4.0
在python3.6版本下安装,报错:
  1.  running build_rust
  2.   error: can't find Rust compiler
  3.   If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel
文章来源: blog.csdn.net,作者:AI视觉网奇,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/jacke121/article/details/125986088
