『Kubernetes』在k8s中部署Dashboard可视化面板
老陈聊架构 发表于 2022/07/26 13:20:59 2022/07/26
【摘要】 📣读完这篇文章里你能收获到 - 保姆级的K8S安装Dashboard - 可视化管理Kubernetes
请添加图片描述
📣读完这篇文章里你能收获到
  • 保姆级的K8S安装Dashboard
  • 可视化管理Kubernetes
请添加图片描述
一、前提
  1. 本实例 Kubernetes 版本为 v1.22.5,对应Dashboard版本v2.5.0
  2. 对应K8S版本与Dashboard版本的兼容 点击此查看-kubernetes/dashboard · GitHub
请添加图片描述
二、安装Dashboard
1. 直接运行
  • kubectl apply -f https://raw.githubusercontent.com/kubernetes/dashboard/v2.5.0/aio/deploy/recommended.yaml
2. 无法访问raw.githubusercontent.com域名
请添加图片描述
三、更新SVC访问模式
1. 查看POD状态,确保Pod状态都为Running
kubectl get pods -n kubernetes-dashboard
2. 查看SVC
kubectl get svc -n kubernetes-dashboard
3. 修改SVC访问模式
kubectl edit svc kubernetes-dashboard -n kubernetes-dashboard
  • 将ClusterIP改为NodePort
请添加图片描述
四、浏览器访问
  • 我这里是https://localhost:30429
请添加图片描述
五、生成Token
kubectl get secret -n kubernetes-dashboard
kubectl describe secret kubernetes-dashboard-token-tfpdf -n kubernetes-dashboard
  • 复制Token到浏览器输入即可打开
请添加图片描述
附件
1. recommended.yaml
# Copyright 2017 The Kubernetes Authors.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
apiVersion: v1
kind: Namespace
metadata:
apiVersion: v1
kind: ServiceAccount
metadata:
  labels:
    k8s-app: kubernetes-dashboard
  namespace: kubernetes-dashboard
kind: Service
apiVersion: v1
metadata:
  labels:
spec:
  ports:
    - port: 443
      targetPort: 8443
  selector:
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
data:
  csrf: ""
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
kind: ConfigMap
apiVersion: v1
metadata:
  labels:
kind: Role
apiVersion: rbac.authorization.k8s.io/v1
metadata:
  labels:
rules:
  # Allow Dashboard to get, update and delete Dashboard exclusive secrets.
  - apiGroups: [""]
    resources: ["secrets"]
    resourceNames: ["kubernetes-dashboard-key-holder", "kubernetes-dashboard-certs", "kubernetes-dashboard-csrf"]
    verbs: ["get", "update", "delete"]
    # Allow Dashboard to get and update 'kubernetes-dashboard-settings' config map.
  - apiGroups: [""]
    resources: ["configmaps"]
    resourceNames: ["kubernetes-dashboard-settings"]
    verbs: ["get", "update"]
    # Allow Dashboard to get metrics.
  - apiGroups: [""]
    resources: ["services"]
    resourceNames: ["heapster", "dashboard-metrics-scraper"]
    verbs: ["proxy"]
  - apiGroups: [""]
    resources: ["services/proxy"]
    resourceNames: ["heapster", "http:heapster:", "https:heapster:", "dashboard-metrics-scraper", "http:dashboard-metrics-scraper"]
    verbs: ["get"]
kind: ClusterRole
metadata:
  labels:
rules:
  # Allow Metrics Scraper to get metrics from the Metrics server
  - apiGroups: ["metrics.k8s.io"]
    resources: ["pods", "nodes"]
    verbs: ["get", "list", "watch"]
kind: RoleBinding
metadata:
  labels:
roleRef:
  apiGroup: rbac.authorization.k8s.io
  kind: Role
subjects:
  - kind: ServiceAccount
kind: ClusterRoleBinding
metadata:
roleRef:
  kind: ClusterRole
subjects:
kind: Deployment
apiVersion: apps/v1
metadata:
  labels:
spec:
  replicas: 1
  revisionHistoryLimit: 10
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      securityContext:
        seccompProfile:
          type: RuntimeDefault
      containers:
        - name: kubernetes-dashboard
          image: kubernetesui/dashboard:v2.5.0
          imagePullPolicy: Always
          ports:
            - containerPort: 8443
              protocol: TCP
          args:
            - --auto-generate-certificates
            - --namespace=kubernetes-dashboard
            # Uncomment the following line to manually specify Kubernetes API server Host
            # If not specified, Dashboard will attempt to auto discover the API server and connect
            # to it. Uncomment only if the default does not work.
            # - --apiserver-host=http://my-address:port
          volumeMounts:
            - name: kubernetes-dashboard-certs
              mountPath: /certs
              # Create on-disk volume to store exec logs
            - mountPath: /tmp
          livenessProbe:
            httpGet:
              scheme: HTTPS
              path: /
              port: 8443
            initialDelaySeconds: 30
            timeoutSeconds: 30
          securityContext:
            allowPrivilegeEscalation: false
            readOnlyRootFilesystem: true
            runAsUser: 1001
            runAsGroup: 2001
      volumes:
          secret:
            secretName: kubernetes-dashboard-certs
        - name: tmp-volume
          emptyDir: {}
      serviceAccountName: kubernetes-dashboard
      nodeSelector:
        "kubernetes.io/os": linux
      # Comment the following tolerations if Dashboard must not be deployed on master
      tolerations:
        - key: node-role.kubernetes.io/master
          effect: NoSchedule
kind: Service
apiVersion: v1
metadata:
  labels:
    k8s-app: dashboard-metrics-scraper
spec:
  ports:
    - port: 8000
      targetPort: 8000
  selector:
kind: Deployment
apiVersion: apps/v1
metadata:
  labels:
spec:
  replicas: 1
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      securityContext:
        seccompProfile:
      containers:
        - name: dashboard-metrics-scraper
          image: kubernetesui/metrics-scraper:v1.0.7
          ports:
            - containerPort: 8000
              protocol: TCP
          livenessProbe:
            httpGet:
              scheme: HTTP
              path: /
              port: 8000
            timeoutSeconds: 30
          volumeMounts:
          - mountPath: /tmp
          securityContext:
            runAsUser: 1001
            runAsGroup: 2001
      nodeSelector:
      tolerations:
          effect: NoSchedule
      volumes:
        - name: tmp-volume
          emptyDir: {}
