Flink高级特性和新特性(八)v2
Maynor学长 发表于 2022/07/24 11:51:37 2022/07/24
【摘要】 双流 JOIN多个数据流 DataStream 之间进行 JOIN 操作双流 JOIN 分为两大类: Window 窗口的join, Interval 的 joinWindow窗口 分为 tumbling 窗口, sliding 窗口, session 窗口Interval 包括 下届, 上届需求订单明细表和商品表每 5 秒中进行一个窗口 JOIN , 将结果落地并打印输出开发步骤pack...
双流 JOIN
  • 多个数据流 DataStream 之间进行 JOIN 操作
  • 双流 JOIN 分为两大类: Window 窗口的join, Interval 的 join
  • Window窗口 分为 tumbling 窗口, sliding 窗口, session 窗口
  • Interval 包括 下届, 上届
    image-20210624093501057
  • 需求
    • 开发步骤
      package cn.itcast.flink.broadcast;
      import com.alibaba.fastjson.JSON;
      import lombok.Data;
      import org.apache.flink.api.common.eventtime.*;
      import org.apache.flink.configuration.Configuration;
      import org.apache.flink.streaming.api.datastream.DataStream;
      import org.apache.flink.streaming.api.datastream.DataStreamSource;
      import org.apache.flink.streaming.api.datastream.SingleOutputStreamOperator;
      import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
      import org.apache.flink.streaming.api.functions.source.RichSourceFunction;
      import org.apache.flink.streaming.api.windowing.assigners.TumblingEventTimeWindows;
      import org.apache.flink.streaming.api.windowing.time.Time;
      import java.math.BigDecimal;
      import java.util.ArrayList;
      import java.util.List;
      import java.util.Random;
      import java.util.UUID;
      import java.util.concurrent.TimeUnit;
       * Author itcast
       * Date 2021/6/24 9:40
       * Desc TODO
      public class JoinDemo {
          public static void main(String[] args) throws Exception {
              // 创建流执行环境
              StreamExecutionEnvironment env = StreamExecutionEnvironment.getExecutionEnvironment();
              env.setParallelism(1);
              // 构建商品数据流
              SingleOutputStreamOperator<Goods> goodsSource = env.addSource(new GoodsSource()).assignTimestampsAndWatermarks(new GoodsWatermark());
              // 构建订单明细数据流
              SingleOutputStreamOperator<OrderItem> orderItemSource = env.addSource(new OrderItemSource()).assignTimestampsAndWatermarks(new OrderItemWatermark());
              // 订单表 join 商品表 订单表.goodsId===商品表.goodsId
              DataStream<FactOrderItem> result = orderItemSource.join(goodsSource)
                      .where(o -> o.goodsId)
                      .equalTo(g -> g.goodsId)
                      /// 窗口为滚动窗口 5 秒
                      .window(TumblingEventTimeWindows.of(Time.seconds(5)))
                      /// apply 实现 (OrderItem first, Goods second) -> factOrderItem
                      .apply((OrderItem first, Goods second) -> {
                          FactOrderItem factOrderItem = new FactOrderItem();
                          factOrderItem.setGoodsId(first.goodsId);
                          factOrderItem.setGoodsName(second.goodsName);
                          factOrderItem.setCount(new BigDecimal(first.count));
                          factOrderItem.setTotalMoney(new BigDecimal(first.count).multiply(second.goodsPrice));
                          return factOrderItem;
              //打印输出
              result.print();
              //执行环境
              env.execute();
          //商品类实体类
          @Data
          public static class Goods {
              private String goodsId;
              private String goodsName;
              private BigDecimal goodsPrice;
              public static List<Goods> GOODS_LIST;
              public static Random r;
              static  {
                  r = new Random();
                  GOODS_LIST = new ArrayList<>();
                  GOODS_LIST.add(new Goods("1", "小米12", new BigDecimal(4890)));
                  GOODS_LIST.add(new Goods("2", "iphone12", new BigDecimal(12000)));
                  GOODS_LIST.add(new Goods("3", "MacBookPro", new BigDecimal(15000)));
                  GOODS_LIST.add(new Goods("4", "Thinkpad X1", new BigDecimal(9800)));
                  GOODS_LIST.add(new Goods("5", "MeiZu One", new BigDecimal(3200)));
                  GOODS_LIST.add(new Goods("6", "Mate 40", new BigDecimal(6500)));
              public static Goods randomGoods() {
                  int rIndex = r.nextInt(GOODS_LIST.size());
                  return GOODS_LIST.get(rIndex);
              public Goods() {
              public Goods(String goodsId, String goodsName, BigDecimal goodsPrice) {
                  this.goodsId = goodsId;
                  this.goodsName = goodsName;
                  this.goodsPrice = goodsPrice;
              @Override
              public String toString() {
                  return JSON.toJSONString(this);
          //订单明细实体类
          @Data
          public static class OrderItem {
              private String itemId;
              private Integer count;
              @Override
          //关联结果,落地表的实体表
          @Data
          public static class FactOrderItem {
              private BigDecimal count;
              private BigDecimal totalMoney;
              @Override
          //构建一个商品Stream源(这个好比就是维表)
          public static class GoodsSource extends RichSourceFunction<Goods> {
              private Boolean isCancel;
              @Override
              public void open(Configuration parameters) throws Exception {
                  isCancel = false;
              @Override
              public void run(SourceContext sourceContext) throws Exception {
                  while(!isCancel) {
                      Goods.GOODS_LIST.stream().forEach(goods -> sourceContext.collect(goods));
                      TimeUnit.SECONDS.sleep(1);
              @Override
              public void cancel() {
                  isCancel = true;
          //构建订单明细Stream源
          public static class OrderItemSource extends RichSourceFunction<OrderItem>
              private Random r;
              @Override
                  isCancel = false;
                  r = new Random();
              @Override
                  while(!isCancel) {
                      Goods goods = Goods.randomGoods();
                      OrderItem orderItem = new OrderItem();
                      orderItem.setGoodsId(goods.getGoodsId());
                      orderItem.setCount(r.nextInt(10) + 1);
                      orderItem.setItemId(UUID.randomUUID().toString());
                      sourceContext.collect(orderItem);
                      orderItem.setGoodsId("111");
              @Override
                  isCancel = true;
          //构建水印分配器(此处为了简单),直接使用系统时间了
          public static class GoodsWatermark implements WatermarkStrategy<Goods> {
              @Override
              public TimestampAssigner<Goods> createTimestampAssigner(TimestampAssignerSupplier.Context context) {
                  return (element, recordTimestamp) -> System.currentTimeMillis();
              @Override
              public WatermarkGenerator<Goods> createWatermarkGenerator(WatermarkGeneratorSupplier.Context context) {
                  return new WatermarkGenerator<Goods>() {
                      @Override
                      public void onEvent(Goods event, long eventTimestamp, WatermarkOutput output) {
                          output.emitWatermark(new Watermark(System.currentTimeMillis()));
                      @Override
                      public void onPeriodicEmit(WatermarkOutput output) {
          public static class OrderItemWatermark implements WatermarkStrategy<OrderItem> {
              @Override
              public TimestampAssigner<OrderItem> createTimestampAssigner(TimestampAssignerSupplier.Context context) {
              @Override
              public WatermarkGenerator<OrderItem> createWatermarkGenerator(WatermarkGeneratorSupplier.Context context) {
                  return new WatermarkGenerator<OrderItem>() {
                      @Override
                      public void onEvent(OrderItem event, long eventTimestamp, WatermarkOutput output) {
                      @Override
  • 需求
    将商品数据和订单明细数据进行关联,间隔,上届 0(不包含),下届 -1(包含),统计数据并落地
  • 开发步骤
    import lombok.Data;
    import org.apache.flink.api.common.typeinfo.TypeInformation;
    import org.apache.flink.streaming.api.functions.co.ProcessJoinFunction;
    import org.apache.flink.util.Collector;
     * Author itcast
     * Desc
    public class JoinDemo02 {
            // 构建商品数据流
            DataStream<Goods> goodsDS = env.addSource(new GoodsSource11(), TypeInformation.of(Goods.class)).assignTimestampsAndWatermarks(new GoodsWatermark());
            // 构建订单明细数据流
            DataStream<OrderItem> orderItemDS = env.addSource(new OrderItemSource(), TypeInformation.of(OrderItem.class)).assignTimestampsAndWatermarks(new OrderItemWatermark());
            // 进行关联查询
            SingleOutputStreamOperator<FactOrderItem> factOrderItemDS = orderItemDS.keyBy(item -> item.getGoodsId())
                    .intervalJoin(goodsDS.keyBy(goods -> goods.getGoodsId()))
                    .between(Time.seconds(-1), Time.seconds(0))
                    //上届的开区间,排除掉上届 [-1,0)
                    .upperBoundExclusive()
                    .process(new ProcessJoinFunction<OrderItem, Goods, FactOrderItem>() {
                        @Override
                        public void processElement(OrderItem left, Goods right, Context ctx, Collector<FactOrderItem> out) throws Exception {
                            factOrderItem.setGoodsId(right.getGoodsId());
                            factOrderItem.setGoodsName(right.getGoodsName());
                            factOrderItem.setCount(new BigDecimal(left.getCount()));
                            factOrderItem.setTotalMoney(right.getGoodsPrice().multiply(new BigDecimal(left.getCount())));
                            out.collect(factOrderItem);
            factOrderItemDS.print();
            env.execute("Interval JOIN");
        //商品类
        @Data
            static  {
                r = new Random();
            public Goods() {
            @Override
        //订单明细类
        @Data
            @Override
        //关联结果
        @Data
            @Override
        public static class GoodsSource11 extends RichSourceFunction {
            @Override
                isCancel = false;
            @Override
                while(!isCancel) {
            @Override
                isCancel = true;
        //构建订单明细Stream源
        public static class OrderItemSource extends RichSourceFunction {
            private Random r;
            @Override
                isCancel = false;
                r = new Random();
            @Override
                while(!isCancel) {
            @Override
                isCancel = true;
            @Override
            @Override
                    @Override
                    @Override
            @Override
            @Override
                    @Override
                    @Override
Streaming File Sink
  • Sink 落地
  • Sink 分类
    1. sink MySQL
    2. sink Kafka
    3. sink Redis
    4. sink 控制台
  • Sink 落地到分布式文件系统上 HDFS 上
  • Sink 到文件系统 Streaming File Sink 落地使用应用场景
    1. 实时数据仓库
    2. 小时级的数据分析 等
    3. 抽取数据
  • 需求
    通过在 socket 数据流中将数据定时 2秒钟写入到 hdfs 上。
  • 开发步骤
import org.apache.flink.api.common.serialization.SimpleStringEncoder;
import org.apache.flink.api.common.time.Time;
import org.apache.flink.core.fs.Path;
import org.apache.flink.runtime.state.filesystem.FsStateBackend;
import org.apache.flink.streaming.api.functions.sink.filesystem.OutputFileConfig;
import org.apache.flink.streaming.api.functions.sink.filesystem.StreamingFileSink;
import org.apache.flink.streaming.api.functions.sink.filesystem.bucketassigners.DateTimeBucketAssigner;
import org.apache.flink.streaming.api.functions.sink.filesystem.rollingpolicies.DefaultRollingPolicy;
 * Author itcast
 * Date 2021/6/24 10:52
 * Desc TODO
public class StreamingFileSinkDemo {
        //1.初始化流计算运行环境
        //2.设置Checkpoint(10s)周期性启动 和 stateBackend 存储路径
        // Sink保证仅一次语义使用 checkpoint 和 二段提交
        env.enableCheckpointing(10000);
        env.setStateBackend(new FsStateBackend("file:///d:/chk/"));
        //4.接入socket数据源,获取数据
        DataStreamSource<String> source = env.socketTextStream("node1", 9999);
        //5.创建Streamingfilesink对象
        OutputFileConfig config = OutputFileConfig
                .builder()
                .withPartPrefix("crm")
                .withPartSuffix(".txt")
                .build();
        //5-1. 创建输出文件配置,指定输出路径 /FlinkStreamFileSink/parquet
        StreamingFileSink sink = StreamingFileSink.forRowFormat(new Path("hdfs://node1:8020/FlinkStreamFileSink/parquet"),
                new SimpleStringEncoder<String>("UTF-8"))
                // sink-kafka new FlinkKafkaProducer
                //5-2.StreamingFileSink 行格式化 , withBucketAssigner->DateTimeBucketAssigner
                .withBucketAssigner(new DateTimeBucketAssigner())
                //withRollingPolicy -> 默认滚筒策略
                .withRollingPolicy(DefaultRollingPolicy.builder()
                        .withMaxPartSize(128 * 1024 * 1024)
                        .withRolloverInterval(Time.seconds(2).toMilliseconds())
                        .withInactivityInterval(Time.seconds(2).toMilliseconds())
                        .build())
        //withOutputFileConfig -> 输出文件的配置
                .withOutputFileConfig(config)
                .build();
        //6.设置输出 sink
        source.print();
        source.addSink(sink).setParallelism(1);
        //7.执行任务
        env.execute();
.build())
.build();
//6.设置输出 sink
source.print();
//7.执行任务
env.execute();
