Swagger直接返回MybatisPlus的Page类文档不展开显示问题剖析
莫逸风 发表于 2022/07/20 12:56:51 2022/07/20
【摘要】 Swagger直接返回MybatisPlus的Page类文档不展开显示问题剖析
原写法
public RestResponse<Page<RefundPageResp>> refuntList(){
public class RestResponse<T> {
    private Integer restCode;
    private String restMsg;
    private T restContext;
Page是MybatisPlus的分页查询实体com.baomidou.mybatisplus.extension.plugins.pagination.Page
Swagger文档上是这样显示的,不能展开,显然不符合需求。
思路
因为Page是源码不方便修改,我们先抄一个。
public class MyPage<T> {
    private List<T> records = Collections.emptyList();
     * 总数
    private long total = 0;
     * 每页显示条数,默认 10
    private long size = 10;
     * 当前页
    private long current = 1;
     * <p>
     * SQL 排序 ASC 数组
     * </p>
    private String[] ascs;
     * <p>
     * SQL 排序 DESC 数组
     * </p>
    private String[] descs;
     * <p>
     * 自动优化 COUNT SQL
     * </p>
    private boolean optimizeCountSql = true;
     * <p>
     * 是否进行 count 查询
     * </p>
    private boolean isSearchCount = true;
    public MyPage(List<T> records, long total, long size, long current) {
        this.records = records;
        this.total = total;
        this.size = size;
        this.current = current;
    public List<T> getRecords() {
        return records;
    public void setRecords(List<T> records) {
    public long getTotal() {
        return total;
    public void setTotal(long total) {
        this.total = total;
    public long getSize() {
        return size;
    public void setSize(long size) {
        this.size = size;
    public long getCurrent() {
        return current;
    public void setCurrent(long current) {
    public String[] getAscs() {
        return ascs;
    public void setAscs(String[] ascs) {
        this.ascs = ascs;
    public String[] getDescs() {
        return descs;
    public void setDescs(String[] descs) {
        this.descs = descs;
    public boolean isOptimizeCountSql() {
        return optimizeCountSql;
    public void setOptimizeCountSql(boolean optimizeCountSql) {
        this.optimizeCountSql = optimizeCountSql;
    public boolean isSearchCount() {
        return isSearchCount;
    public void setSearchCount(boolean searchCount) {
        isSearchCount = searchCount;
    public static <T> MyPage<T> restPage(Page<T> page) {
        return new MyPage<>(page.getRecords(), page.getTotal(), page.getSize(), page.getCurrent());
调整后
public RestResponse<MyPage<RefundPageResp>> refuntList(){
无任何变化
我们看到isSearchCount字段应该考虑是否是其影响,is开头的属性字段是会影响字段值的存取的,我们可以看到,我自动生成的两个boolean类型的字段
原因
optimizeCountSql:字段类型为boolean,其get方法是isOptimizeCountSql()
然而
isSearchCount:按照原则其get方法应该为isIsSearchCount()
同理set方法应该为setIsSearchCount()
调整后
public boolean isIsSearchCount() {
public void setIsSearchCount(boolean searchCount) {
正常展开
最佳实践
Mybatis的查询对象Page其创建目的是为了构建查询SQL,很多字段是不需要传递给前端的,包括其他框架的分页对象也是不需要返回给前端的,我们可以构建一个自己的PageResult。
@Data
public final class PageResult<T> {
    private final Integer pageNum;
    private final Integer pageSize;
    private final Long total;
    private final List<T> list;
    private PageResult(@NotNull Integer pageNum, @NotNull Integer pageSize, @NotNull Long total, @Nullable List<T> list) {
        this.pageNum = pageNum;
        this.pageSize = pageSize;
        this.total = total;
        this.list = list;
    public static <T> PageResult<T> restPage(@NotNull Integer pageNum, @NotNull Integer pageSize, @NotNull Long total, @Nullable List<T> list) {
        return new PageResult<>(pageNum, pageSize, total, Optional.ofNullable(list).orElse(Collections.emptyList()));
     * 将MyBatis Plus 分页结果转化为通用结果
    public static <T> PageResult<T> restPage(@NotNull Page<T> page) {
        return new PageResult<>(page.getPageNum(), page.getPageSize(), page.getTotal(), page.getResult());
    public static <T> PageResult<T> restPage(@NotNull PageInfo<T> page) {
        return new PageResult<>(page.getPageNum(), page.getPageSize(), page.getTotal(), page.getList());
     * 将Jpa分页结果转化为通用结果
    public static <T> PageResult<T> restPage(@NotNull org.springframework.data.domain.Page<T> page) {
        return new PageResult<>(page.getNumber()+1, page.getSize(), page.getTotalElements(), page.getContent());
