FTXUI编译和使用(不含ROS1/2)Linux手机或平板版本
zhangrelay 发表于 2022/07/14 23:29:07 2022/07/14
【摘要】 电脑端编译和使用参考: FTXUI编译和使用(不含ROS1/2) linux手机类似: cmake .. make 效果如下: ssh端效果   vnc桌面效果:   过程如下: 需要cmake /  g++ 升级到对应新版cmake>=3.11,g++>=9...
电脑端编译和使用参考:
linux手机类似:
cmake ..
make
效果如下:
ssh端效果
vnc桌面效果:
过程如下:
需要cmake /  g++ 升级到对应新版cmake>=3.11,g++>=9.4!
phablet@ubuntu-phablet:~/Downloads/FTXUI/build$ cmake ..
-- The CXX compiler identification is GNU 9.4.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for C++ include pthread.h
-- Looking for C++ include pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- clang-tidy found: /usr/bin/clang-tidy
-- Found Doxygen: /usr/bin/doxygen (found version "1.8.11") found components: doxygen missing components: dot
-- Configuring done
-- Generating done
-- Build files have been written to: /home/phablet/Downloads/FTXUI/build
  1. phablet@ubuntu-phablet:~/Downloads/FTXUI/build$ make
  2. [ 1%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/box.cpp.o
  3. [ 1%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/color.cpp.o
  4. [ 2%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/color_info.cpp.o
  5. [ 2%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/screen.cpp.o
  6. [ 3%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/string.cpp.o
  7. [ 3%] Building CXX object CMakeFiles/screen.dir/src/ftxui/screen/terminal.cpp.o
  8. [ 4%] Linking CXX static library libftxui-screen.a
  9. [ 4%] Built target screen
  10. [ 4%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/automerge.cpp.o
  11. [ 5%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/blink.cpp.o
  12. [ 5%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/bold.cpp.o
  13. [ 6%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/border.cpp.o
  14. [ 6%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/box_helper.cpp.o
  15. [ 7%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/canvas.cpp.o
  16. [ 7%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/clear_under.cpp.o
  17. [ 8%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/color.cpp.o
  18. [ 8%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/composite_decorator.cpp.o
  19. [ 9%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/dbox.cpp.o
  20. [ 9%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/dim.cpp.o
  21. [ 10%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/flex.cpp.o
  22. [ 10%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/flexbox.cpp.o
  23. [ 11%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/flexbox_config.cpp.o
  24. [ 11%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/flexbox_helper.cpp.o
  25. [ 12%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/focus.cpp.o
  26. [ 12%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/frame.cpp.o
  27. [ 13%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/gauge.cpp.o
  28. [ 13%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/graph.cpp.o
  29. [ 14%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/gridbox.cpp.o
  30. [ 14%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/hbox.cpp.o
  31. [ 15%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/inverted.cpp.o
  32. [ 15%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/node.cpp.o
  33. [ 16%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/node_decorator.cpp.o
  34. [ 16%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/paragraph.cpp.o
  35. [ 17%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/reflect.cpp.o
  36. [ 17%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/scroll_indicator.cpp.o
  37. [ 18%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/separator.cpp.o
  38. [ 18%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/size.cpp.o
  39. [ 18%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/spinner.cpp.o
  40. [ 19%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/table.cpp.o
  41. [ 19%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/text.cpp.o
  42. [ 20%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/underlined.cpp.o
  43. [ 20%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/util.cpp.o
  44. [ 21%] Building CXX object CMakeFiles/dom.dir/src/ftxui/dom/vbox.cpp.o
  45. [ 21%] Linking CXX static library libftxui-dom.a
  46. [ 21%] Built target dom
  47. [ 21%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/animation.cpp.o
  48. [ 21%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/button.cpp.o
  49. [ 22%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/catch_event.cpp.o
  50. [ 22%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/checkbox.cpp.o
  51. [ 23%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/collapsible.cpp.o
  52. [ 23%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/component.cpp.o
  53. [ 24%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/component_options.cpp.o
  54. [ 24%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/container.cpp.o
  55. [ 25%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/dropdown.cpp.o
  56. [ 25%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/event.cpp.o
  57. [ 26%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/input.cpp.o
  58. [ 26%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/maybe.cpp.o
  59. [ 27%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/modal.cpp.o
  60. [ 27%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/menu.cpp.o
  61. [ 28%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/radiobox.cpp.o
  62. [ 28%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/renderer.cpp.o
  63. [ 29%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/resizable_split.cpp.o
  64. [ 29%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/screen_interactive.cpp.o
  65. [ 30%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/slider.cpp.o
  66. [ 30%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/terminal_input_parser.cpp.o
  67. [ 31%] Building CXX object CMakeFiles/component.dir/src/ftxui/component/util.cpp.o
  68. [ 31%] Linking CXX static library libftxui-component.a
  69. [ 31%] Built target component
  70. [ 32%] Building CXX object examples/component/CMakeFiles/ftxui_example_button.dir/button.cpp.o
  71. [ 32%] Linking CXX executable ftxui_example_button
  72. [ 32%] Built target ftxui_example_button
  73. [ 33%] Building CXX object examples/component/CMakeFiles/ftxui_example_button_animated.dir/button_animated.cpp.o
  74. [ 33%] Linking CXX executable ftxui_example_button_animated
  75. [ 33%] Built target ftxui_example_button_animated
  76. [ 34%] Building CXX object examples/component/CMakeFiles/ftxui_example_button_in_frame.dir/button_in_frame.cpp.o
  77. [ 34%] Linking CXX executable ftxui_example_button_in_frame
  78. [ 34%] Built target ftxui_example_button_in_frame
  79. [ 35%] Building CXX object examples/component/CMakeFiles/ftxui_example_button_style.dir/button_style.cpp.o
  80. [ 35%] Linking CXX executable ftxui_example_button_style
  81. [ 35%] Built target ftxui_example_button_style
  82. [ 36%] Building CXX object examples/component/CMakeFiles/ftxui_example_canvas_animated.dir/canvas_animated.cpp.o
  83. [ 36%] Linking CXX executable ftxui_example_canvas_animated
  84. [ 36%] Built target ftxui_example_canvas_animated
  85. [ 37%] Building CXX object examples/component/CMakeFiles/ftxui_example_checkbox.dir/checkbox.cpp.o
  86. [ 37%] Linking CXX executable ftxui_example_checkbox
  87. [ 37%] Built target ftxui_example_checkbox
  88. [ 38%] Building CXX object examples/component/CMakeFiles/ftxui_example_checkbox_in_frame.dir/checkbox_in_frame.cpp.o
  89. [ 38%] Linking CXX executable ftxui_example_checkbox_in_frame
  90. [ 38%] Built target ftxui_example_checkbox_in_frame
  91. [ 39%] Building CXX object examples/component/CMakeFiles/ftxui_example_collapsible.dir/collapsible.cpp.o
  92. [ 39%] Linking CXX executable ftxui_example_collapsible
  93. [ 39%] Built target ftxui_example_collapsible
  94. [ 40%] Building CXX object examples/component/CMakeFiles/ftxui_example_composition.dir/composition.cpp.o
  95. [ 40%] Linking CXX executable ftxui_example_composition
  96. [ 40%] Built target ftxui_example_composition
  97. [ 41%] Building CXX object examples/component/CMakeFiles/ftxui_example_dropdown.dir/dropdown.cpp.o
  98. [ 41%] Linking CXX executable ftxui_example_dropdown
  99. [ 41%] Built target ftxui_example_dropdown
  100. [ 42%] Building CXX object examples/component/CMakeFiles/ftxui_example_flexbox_gallery.dir/flexbox_gallery.cpp.o
  101. [ 42%] Linking CXX executable ftxui_example_flexbox_gallery
  102. [ 42%] Built target ftxui_example_flexbox_gallery
  103. [ 43%] Building CXX object examples/component/CMakeFiles/ftxui_example_focus.dir/focus.cpp.o
  104. [ 43%] Linking CXX executable ftxui_example_focus
  105. [ 43%] Built target ftxui_example_focus
  106. [ 44%] Building CXX object examples/component/CMakeFiles/ftxui_example_gallery.dir/gallery.cpp.o
  107. [ 44%] Linking CXX executable ftxui_example_gallery
  108. [ 44%] Built target ftxui_example_gallery
  109. [ 44%] Building CXX object examples/component/CMakeFiles/ftxui_example_homescreen.dir/homescreen.cpp.o
  110. [ 45%] Linking CXX executable ftxui_example_homescreen
  111. [ 45%] Built target ftxui_example_homescreen
  112. [ 45%] Building CXX object examples/component/CMakeFiles/ftxui_example_input.dir/input.cpp.o
  113. [ 46%] Linking CXX executable ftxui_example_input
  114. [ 46%] Built target ftxui_example_input
  115. [ 46%] Building CXX object examples/component/CMakeFiles/ftxui_example_maybe.dir/maybe.cpp.o
  116. [ 47%] Linking CXX executable ftxui_example_maybe
  117. [ 47%] Built target ftxui_example_maybe
  118. [ 47%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu.dir/menu.cpp.o
  119. [ 48%] Linking CXX executable ftxui_example_menu
  120. [ 48%] Built target ftxui_example_menu
  121. [ 48%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu2.dir/menu2.cpp.o
  122. [ 49%] Linking CXX executable ftxui_example_menu2
  123. [ 49%] Built target ftxui_example_menu2
  124. [ 49%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_entries.dir/menu_entries.cpp.o
  125. [ 50%] Linking CXX executable ftxui_example_menu_entries
  126. [ 50%] Built target ftxui_example_menu_entries
  127. [ 50%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_entries_animated.dir/menu_entries_animated.cpp.o
  128. [ 51%] Linking CXX executable ftxui_example_menu_entries_animated
  129. [ 51%] Built target ftxui_example_menu_entries_animated
  130. [ 51%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_in_frame.dir/menu_in_frame.cpp.o
  131. [ 52%] Linking CXX executable ftxui_example_menu_in_frame
  132. [ 52%] Built target ftxui_example_menu_in_frame
  133. [ 52%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_multiple.dir/menu_multiple.cpp.o
  134. [ 53%] Linking CXX executable ftxui_example_menu_multiple
  135. [ 53%] Built target ftxui_example_menu_multiple
  136. [ 53%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_style.dir/menu_style.cpp.o
  137. [ 54%] Linking CXX executable ftxui_example_menu_style
  138. [ 54%] Built target ftxui_example_menu_style
  139. [ 54%] Building CXX object examples/component/CMakeFiles/ftxui_example_menu_underline_animated_gallery.dir/menu_underline_animated_gallery.cpp.o
  140. [ 55%] Linking CXX executable ftxui_example_menu_underline_animated_gallery
  141. [ 55%] Built target ftxui_example_menu_underline_animated_gallery
  142. [ 55%] Building CXX object examples/component/CMakeFiles/ftxui_example_modal_dialog.dir/modal_dialog.cpp.o
  143. [ 56%] Linking CXX executable ftxui_example_modal_dialog
  144. [ 56%] Built target ftxui_example_modal_dialog
  145. [ 56%] Building CXX object examples/component/CMakeFiles/ftxui_example_modal_dialog_custom.dir/modal_dialog_custom.cpp.o
  146. [ 57%] Linking CXX executable ftxui_example_modal_dialog_custom
  147. [ 57%] Built target ftxui_example_modal_dialog_custom
  148. [ 57%] Building CXX object examples/component/CMakeFiles/ftxui_example_nested_screen.dir/nested_screen.cpp.o
  149. [ 58%] Linking CXX executable ftxui_example_nested_screen
  150. [ 58%] Built target ftxui_example_nested_screen
  151. [ 58%] Building CXX object examples/component/CMakeFiles/ftxui_example_print_key_press.dir/print_key_press.cpp.o
  152. [ 59%] Linking CXX executable ftxui_example_print_key_press
  153. [ 59%] Built target ftxui_example_print_key_press
  154. [ 59%] Building CXX object examples/component/CMakeFiles/ftxui_example_radiobox.dir/radiobox.cpp.o
  155. [ 60%] Linking CXX executable ftxui_example_radiobox
  156. [ 60%] Built target ftxui_example_radiobox
  157. [ 60%] Building CXX object examples/component/CMakeFiles/ftxui_example_radiobox_in_frame.dir/radiobox_in_frame.cpp.o
  158. [ 61%] Linking CXX executable ftxui_example_radiobox_in_frame
  159. [ 61%] Built target ftxui_example_radiobox_in_frame
  160. [ 61%] Building CXX object examples/component/CMakeFiles/ftxui_example_renderer.dir/renderer.cpp.o
  161. [ 62%] Linking CXX executable ftxui_example_renderer
  162. [ 62%] Built target ftxui_example_renderer
  163. [ 62%] Building CXX object examples/component/CMakeFiles/ftxui_example_resizable_split.dir/resizable_split.cpp.o
  164. [ 62%] Linking CXX executable ftxui_example_resizable_split
  165. [ 62%] Built target ftxui_example_resizable_split
  166. [ 63%] Building CXX object examples/component/CMakeFiles/ftxui_example_slider.dir/slider.cpp.o
  167. [ 63%] Linking CXX executable ftxui_example_slider
  168. [ 63%] Built target ftxui_example_slider
  169. [ 64%] Building CXX object examples/component/CMakeFiles/ftxui_example_slider_rgb.dir/slider_rgb.cpp.o
  170. [ 64%] Linking CXX executable ftxui_example_slider_rgb
  171. [ 64%] Built target ftxui_example_slider_rgb
  172. [ 65%] Building CXX object examples/component/CMakeFiles/ftxui_example_tab_horizontal.dir/tab_horizontal.cpp.o
  173. [ 65%] Linking CXX executable ftxui_example_tab_horizontal
  174. [ 65%] Built target ftxui_example_tab_horizontal
  175. [ 66%] Building CXX object examples/component/CMakeFiles/ftxui_example_tab_vertical.dir/tab_vertical.cpp.o
  176. [ 66%] Linking CXX executable ftxui_example_tab_vertical
  177. [ 66%] Built target ftxui_example_tab_vertical
  178. [ 67%] Building CXX object examples/component/CMakeFiles/ftxui_example_toggle.dir/toggle.cpp.o
  179. [ 67%] Linking CXX executable ftxui_example_toggle
  180. [ 67%] Built target ftxui_example_toggle
  181. [ 68%] Building CXX object examples/component/CMakeFiles/ftxui_example_with_restored_io.dir/with_restored_io.cpp.o
  182. [ 68%] Linking CXX executable ftxui_example_with_restored_io
  183. [ 68%] Built target ftxui_example_with_restored_io
  184. [ 69%] Building CXX object examples/dom/CMakeFiles/ftxui_example_border.dir/border.cpp.o
  185. [ 69%] Linking CXX executable ftxui_example_border
  186. [ 69%] Built target ftxui_example_border
  187. [ 70%] Building CXX object examples/dom/CMakeFiles/ftxui_example_border_style.dir/border_style.cpp.o
  188. [ 70%] Linking CXX executable ftxui_example_border_style
  189. [ 70%] Built target ftxui_example_border_style
  190. [ 71%] Building CXX object examples/dom/CMakeFiles/ftxui_example_color_gallery.dir/color_gallery.cpp.o
  191. [ 71%] Linking CXX executable ftxui_example_color_gallery
  192. [ 71%] Built target ftxui_example_color_gallery
  193. [ 72%] Building CXX object examples/dom/CMakeFiles/ftxui_example_color_info_palette256.dir/color_info_palette256.cpp.o
  194. [ 72%] Linking CXX executable ftxui_example_color_info_palette256
  195. [ 72%] Built target ftxui_example_color_info_palette256
  196. [ 73%] Building CXX object examples/dom/CMakeFiles/ftxui_example_color_truecolor_HSV.dir/color_truecolor_HSV.cpp.o
  197. [ 73%] Linking CXX executable ftxui_example_color_truecolor_HSV
  198. [ 73%] Built target ftxui_example_color_truecolor_HSV
  199. [ 74%] Building CXX object examples/dom/CMakeFiles/ftxui_example_color_truecolor_RGB.dir/color_truecolor_RGB.cpp.o
  200. [ 74%] Linking CXX executable ftxui_example_color_truecolor_RGB
  201. [ 74%] Built target ftxui_example_color_truecolor_RGB
  202. [ 75%] Building CXX object examples/dom/CMakeFiles/ftxui_example_dbox.dir/dbox.cpp.o
  203. [ 75%] Linking CXX executable ftxui_example_dbox
  204. [ 75%] Built target ftxui_example_dbox
  205. [ 76%] Building CXX object examples/dom/CMakeFiles/ftxui_example_canvas.dir/canvas.cpp.o
  206. [ 76%] Linking CXX executable ftxui_example_canvas
  207. [ 76%] Built target ftxui_example_canvas
  208. [ 77%] Building CXX object examples/dom/CMakeFiles/ftxui_example_gauge.dir/gauge.cpp.o
  209. [ 77%] Linking CXX executable ftxui_example_gauge
  210. [ 77%] Built target ftxui_example_gauge
  211. [ 77%] Building CXX object examples/dom/CMakeFiles/ftxui_example_gauge_direction.dir/gauge_direction.cpp.o
  212. [ 78%] Linking CXX executable ftxui_example_gauge_direction
  213. [ 78%] Built target ftxui_example_gauge_direction
  214. [ 78%] Building CXX object examples/dom/CMakeFiles/ftxui_example_graph.dir/graph.cpp.o
  215. [ 79%] Linking CXX executable ftxui_example_graph
  216. [ 79%] Built target ftxui_example_graph
  217. [ 79%] Building CXX object examples/dom/CMakeFiles/ftxui_example_gridbox.dir/gridbox.cpp.o
  218. [ 80%] Linking CXX executable ftxui_example_gridbox
  219. [ 80%] Built target ftxui_example_gridbox
  220. [ 80%] Building CXX object examples/dom/CMakeFiles/ftxui_example_hflow.dir/hflow.cpp.o
  221. [ 81%] Linking CXX executable ftxui_example_hflow
  222. [ 81%] Built target ftxui_example_hflow
  223. [ 81%] Building CXX object examples/dom/CMakeFiles/ftxui_example_html_like.dir/html_like.cpp.o
  224. [ 82%] Linking CXX executable ftxui_example_html_like
  225. [ 82%] Built target ftxui_example_html_like
  226. [ 82%] Building CXX object examples/dom/CMakeFiles/ftxui_example_package_manager.dir/package_manager.cpp.o
  227. [ 83%] Linking CXX executable ftxui_example_package_manager
  228. [ 83%] Built target ftxui_example_package_manager
  229. [ 83%] Building CXX object examples/dom/CMakeFiles/ftxui_example_paragraph.dir/paragraph.cpp.o
  230. [ 84%] Linking CXX executable ftxui_example_paragraph
  231. [ 84%] Built target ftxui_example_paragraph
  232. [ 85%] Building CXX object examples/dom/CMakeFiles/ftxui_example_separator.dir/separator.cpp.o
  233. [ 85%] Linking CXX executable ftxui_example_separator
  234. [ 85%] Built target ftxui_example_separator
  235. [ 86%] Building CXX object examples/dom/CMakeFiles/ftxui_example_separator_style.dir/separator_style.cpp.o
  236. [ 86%] Linking CXX executable ftxui_example_separator_style
  237. [ 86%] Built target ftxui_example_separator_style
  238. [ 87%] Building CXX object examples/dom/CMakeFiles/ftxui_example_size.dir/size.cpp.o
  239. [ 87%] Linking CXX executable ftxui_example_size
  240. [ 87%] Built target ftxui_example_size
  241. [ 88%] Building CXX object examples/dom/CMakeFiles/ftxui_example_spinner.dir/spinner.cpp.o
  242. [ 88%] Linking CXX executable ftxui_example_spinner
  243. [ 88%] Built target ftxui_example_spinner
  244. [ 89%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_blink.dir/style_blink.cpp.o
  245. [ 89%] Linking CXX executable ftxui_example_style_blink
  246. [ 89%] Built target ftxui_example_style_blink
  247. [ 90%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_bold.dir/style_bold.cpp.o
  248. [ 90%] Linking CXX executable ftxui_example_style_bold
  249. [ 90%] Built target ftxui_example_style_bold
  250. [ 91%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_color.dir/style_color.cpp.o
  251. [ 91%] Linking CXX executable ftxui_example_style_color
  252. [ 91%] Built target ftxui_example_style_color
  253. [ 92%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_dim.dir/style_dim.cpp.o
  254. [ 92%] Linking CXX executable ftxui_example_style_dim
  255. [ 92%] Built target ftxui_example_style_dim
  256. [ 93%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_gallery.dir/style_gallery.cpp.o
  257. [ 93%] Linking CXX executable ftxui_example_style_gallery
  258. [ 93%] Built target ftxui_example_style_gallery
  259. [ 94%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_inverted.dir/style_inverted.cpp.o
  260. [ 94%] Linking CXX executable ftxui_example_style_inverted
  261. [ 94%] Built target ftxui_example_style_inverted
  262. [ 95%] Building CXX object examples/dom/CMakeFiles/ftxui_example_style_underlined.dir/style_underlined.cpp.o
  263. [ 95%] Linking CXX executable ftxui_example_style_underlined
  264. [ 95%] Built target ftxui_example_style_underlined
  265. [ 96%] Building CXX object examples/dom/CMakeFiles/ftxui_example_table.dir/table.cpp.o
  266. [ 96%] Linking CXX executable ftxui_example_table
  267. [ 96%] Built target ftxui_example_table
  268. [ 97%] Building CXX object examples/dom/CMakeFiles/ftxui_example_vbox_hbox.dir/vbox_hbox.cpp.o
  269. [ 97%] Linking CXX executable ftxui_example_vbox_hbox
  270. [ 97%] Built target ftxui_example_vbox_hbox
  271. [ 98%] Building CXX object examples/dom/CMakeFiles/ftxui_example_vflow.dir/vflow.cpp.o
  272. [ 98%] Linking CXX executable ftxui_example_vflow
  273. [ 98%] Built target ftxui_example_vflow
  274. [100%] Building CXX object examples/dom/CMakeFiles/ftxui_example_window.dir/window.cpp.o
  275. [100%] Linking CXX executable ftxui_example_window
  276. [100%] Built target ftxui_example_window
  277. phablet@ubuntu-phablet:~/Downloads/FTXUI/build$
原文链接:zhangrelay.blog.csdn.net/article/details/125773071
