云原生(三十一) | Kubernetes篇之平台基本预装资源
Lansonli 发表于 2022/07/13 09:24:46 2022/07/13
【摘要】 Kubernetes平台基本预装资源kubernetes平台安装完成后需要安装基本资源, 本文适配 kubernetes-v1.21.1 版本一、metrics-serverGitHub - kubernetes-sigs/metrics-server: Scalable and efficient source of container resource metrics for Kuber...
Kubernetes平台基本预装资源
一、metrics-server
GitHub - kubernetes-sigs/metrics-server: Scalable and efficient source of container resource metrics for Kubernetes built-in autoscaling pipelines.
https://github.com/kubernetes-sigs/metrics-server k8s平台基本指标监控组件
apiVersion: v1
kind: ServiceAccount
metadata:
  labels:
    k8s-app: metrics-server
  namespace: kube-system
apiVersion: rbac.authorization.k8s.io/v1
kind: ClusterRole
metadata:
  labels:
    rbac.authorization.k8s.io/aggregate-to-admin: "true"
    rbac.authorization.k8s.io/aggregate-to-edit: "true"
    rbac.authorization.k8s.io/aggregate-to-view: "true"
rules:
- apiGroups:
  - metrics.k8s.io
  resources:
  - pods
  - nodes
  verbs:
  - get
  - list
  - watch
kind: ClusterRole
metadata:
  labels:
rules:
- apiGroups:
  resources:
  - pods
  - nodes
  - nodes/stats
  - namespaces
  - configmaps
  verbs:
  - get
  - list
  - watch
kind: RoleBinding
metadata:
  labels:
roleRef:
  apiGroup: rbac.authorization.k8s.io
  kind: Role
subjects:
- kind: ServiceAccount
kind: ClusterRoleBinding
metadata:
  labels:
roleRef:
  kind: ClusterRole
subjects:
metadata:
  labels:
roleRef:
  kind: ClusterRole
subjects:
apiVersion: v1
kind: Service
metadata:
  labels:
spec:
  ports:
  - name: https
    port: 443
    protocol: TCP
    targetPort: https
  selector:
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
spec:
  selector:
    matchLabels:
  strategy:
    rollingUpdate:
      maxUnavailable: 0
  template:
    metadata:
      labels:
    spec:
      containers:
      - args:
        - --v=6
        - --cert-dir=/tmp
        - --kubelet-insecure-tls
        - --secure-port=4443
        - --kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname
        - --kubelet-use-node-status-port
        image: registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/metrics-server:v0.4.3
        imagePullPolicy: IfNotPresent
        livenessProbe:
          failureThreshold: 3
          httpGet:
            path: /livez
            port: https
            scheme: HTTPS
          periodSeconds: 10
        ports:
        - containerPort: 4443
          protocol: TCP
        readinessProbe:
          failureThreshold: 3
          httpGet:
            path: /readyz
            port: https
            scheme: HTTPS
          periodSeconds: 10
        securityContext:
          readOnlyRootFilesystem: true
          runAsNonRoot: true
          runAsUser: 1000
        volumeMounts:
        - mountPath: /tmp
      nodeSelector:
        kubernetes.io/os: linux
      priorityClassName: system-cluster-critical
      serviceAccountName: metrics-server
      volumes:
      - emptyDir: {}
apiVersion: apiregistration.k8s.io/v1
kind: APIService
metadata:
  labels:
spec:
  group: metrics.k8s.io
  groupPriorityMinimum: 100
  insecureSkipTLSVerify: true
  service:
  version: v1beta1
  versionPriority: 100
二、ingress-nginx
kubernetes官方使用nginx做的组件
自建集群使用裸金属安装方式
使用
  • 给集群中需要暴露的nginx机器节点打上标签 node-role=ingress 如:
  • kubectl label node k8s-master3 node-role=ingress kubectl label node k8s-node1 node-role=ingress kubectl label node k8s-node2 node-role=ingress kubectl label node k8s-node3 node-role=ingress
  • 部署ingress的node节点会自动 开启 节点的 80和443 端口,保证这个机器端口不会被占用
  • 默认ingress-nginx在每个节点没有CPU、MEMORY最大配额限制;可以按照公司架构需求修改resoources.limits相关字段
apiVersion: v1
kind: Namespace
metadata:
  labels:
    app.kubernetes.io/name: ingress-nginx
    app.kubernetes.io/instance: ingress-nginx
# Source: ingress-nginx/templates/controller-serviceaccount.yaml
apiVersion: v1
metadata:
  labels:
    helm.sh/chart: ingress-nginx-3.30.0
    app.kubernetes.io/version: 0.46.0
    app.kubernetes.io/managed-by: Helm
    app.kubernetes.io/component: controller
  namespace: ingress-nginx
automountServiceAccountToken: true
# Source: ingress-nginx/templates/controller-configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
  labels:
data:
# Source: ingress-nginx/templates/clusterrole.yaml
kind: ClusterRole
metadata:
  labels:
rules:
  - apiGroups:
    resources:
      - configmaps
      - endpoints
      - nodes
      - pods
      - secrets
    verbs:
      - list
      - watch
  - apiGroups:
    resources:
      - nodes
    verbs:
      - get
  - apiGroups:
    resources:
      - services
    verbs:
      - get
      - list
      - watch
  - apiGroups:
      - extensions
      - networking.k8s.io   # k8s 1.14+
    resources:
      - ingresses
    verbs:
      - get
      - list
      - watch
  - apiGroups:
    resources:
      - events
    verbs:
      - create
      - patch
  - apiGroups:
      - extensions
    resources:
      - ingresses/status
    verbs:
      - update
  - apiGroups:
    resources:
      - ingressclasses
    verbs:
      - get
      - list
      - watch
# Source: ingress-nginx/templates/clusterrolebinding.yaml
metadata:
  labels:
roleRef:
  kind: ClusterRole
subjects:
# Source: ingress-nginx/templates/controller-role.yaml
kind: Role
metadata:
  labels:
rules:
  - apiGroups:
    resources:
      - namespaces
    verbs:
      - get
  - apiGroups:
    resources:
      - configmaps
      - pods
      - secrets
      - endpoints
    verbs:
      - get
      - list
      - watch
  - apiGroups:
    resources:
      - services
    verbs:
      - get
      - list
      - watch
  - apiGroups:
      - extensions
    resources:
      - ingresses
    verbs:
      - get
      - list
      - watch
  - apiGroups:
      - extensions
    resources:
      - ingresses/status
    verbs:
      - update
  - apiGroups:
    resources:
      - ingressclasses
    verbs:
      - get
      - list
      - watch
  - apiGroups:
    resources:
      - configmaps
    resourceNames:
      - ingress-controller-leader-nginx
    verbs:
      - get
      - update
  - apiGroups:
    resources:
      - configmaps
    verbs:
      - create
  - apiGroups:
    resources:
      - events
    verbs:
      - create
      - patch
# Source: ingress-nginx/templates/controller-rolebinding.yaml
kind: RoleBinding
metadata:
  labels:
roleRef:
  kind: Role
subjects:
# Source: ingress-nginx/templates/controller-service-webhook.yaml
apiVersion: v1
kind: Service
metadata:
  labels:
spec:
  type: ClusterIP
  ports:
    - name: https-webhook
      port: 443
      targetPort: webhook
  selector:
# Source: ingress-nginx/templates/controller-service.yaml
apiVersion: v1
kind: Service
metadata:
  annotations:
  labels:
spec:
  type: ClusterIP  ## 改为clusterIP
  ports:
    - name: http
      port: 80
      protocol: TCP
      targetPort: http
    - name: https
      port: 443
      protocol: TCP
      targetPort: https
  selector:
# Source: ingress-nginx/templates/controller-deployment.yaml
apiVersion: apps/v1
kind: DaemonSet
metadata:
  labels:
spec:
  selector:
    matchLabels:
  revisionHistoryLimit: 10
  minReadySeconds: 0
  template:
    metadata:
      labels:
    spec:
      dnsPolicy: ClusterFirstWithHostNet   ## dns对应调整为主机网络
      hostNetwork: true  ## 直接让nginx占用本机80端口和443端口,所以使用主机网络
      containers:
        - name: controller
          image: registry.cn-hangzhou.aliyuncs.com/lanson_k8s_images/ingress-nginx-controller:v0.46.0
          lifecycle:
            preStop:
              exec:
                command:
                  - /wait-shutdown
          args:
            - /nginx-ingress-controller
            - --election-id=ingress-controller-leader
            - --ingress-class=nginx
            - --configmap=$(POD_NAMESPACE)/ingress-nginx-controller
            - --validating-webhook=:8443
            - --validating-webhook-certificate=/usr/local/certificates/cert
            - --validating-webhook-key=/usr/local/certificates/key
          securityContext:
            capabilities:
              drop:
                - ALL
              add:
                - NET_BIND_SERVICE
            runAsUser: 101
            allowPrivilegeEscalation: true
          env:
            - name: POD_NAME
              valueFrom:
                fieldRef:
                  fieldPath: metadata.name
            - name: POD_NAMESPACE
              valueFrom:
                fieldRef:
                  fieldPath: metadata.namespace
            - name: LD_PRELOAD
              value: /usr/local/lib/libmimalloc.so
          livenessProbe:
            httpGet:
              path: /healthz
              port: 10254
              scheme: HTTP
            initialDelaySeconds: 10
            periodSeconds: 10
            timeoutSeconds: 1
            successThreshold: 1
            failureThreshold: 5
          readinessProbe:
            httpGet:
              path: /healthz
              port: 10254
              scheme: HTTP
            periodSeconds: 10
            timeoutSeconds: 1
            successThreshold: 1
            failureThreshold: 3
          ports:
            - name: http
              containerPort: 80
              protocol: TCP
            - name: https
              containerPort: 443
              protocol: TCP
            - name: webhook
              containerPort: 8443
              protocol: TCP
          volumeMounts:
            - name: webhook-cert
              mountPath: /usr/local/certificates/
              readOnly: true
          resources:
            requests:
              cpu: 100m
              memory: 90Mi
            limits:
              cpu: 1000m
              memory: 800Mi
      nodeSelector:
        node-role: ingress
      serviceAccountName: ingress-nginx
      terminationGracePeriodSeconds: 300
      volumes:
          secret:
            secretName: ingress-nginx-admission
# Source: ingress-nginx/templates/admission-webhooks/validating-webhook.yaml
# before changing this value, check the required kubernetes version
# https://kubernetes.io/docs/reference/access-authn-authz/extensible-admission-controllers/#prerequisites
apiVersion: admissionregistration.k8s.io/v1
kind: ValidatingWebhookConfiguration
metadata:
  labels:
    app.kubernetes.io/component: admission-webhook
webhooks:
  - name: validate.nginx.ingress.kubernetes.io
    matchPolicy: Equivalent
    rules:
      - apiGroups:
          - networking.k8s.io
        apiVersions:
          - v1beta1
        operations:
          - CREATE
          - UPDATE
        resources:
          - ingresses
    failurePolicy: Fail
    sideEffects: None
    admissionReviewVersions:
      - v1
      - v1beta1
    clientConfig:
      service:
        path: /networking/v1beta1/ingresses
# Source: ingress-nginx/templates/admission-webhooks/job-patch/serviceaccount.yaml
apiVersion: v1
metadata:
  annotations:
    helm.sh/hook: pre-install,pre-upgrade,post-install,post-upgrade
    helm.sh/hook-delete-policy: before-hook-creation,hook-succeeded
  labels:
# Source: ingress-nginx/templates/admission-webhooks/job-patch/clusterrole.yaml
kind: ClusterRole
metadata:
  annotations:
  labels:
rules:
  - apiGroups:
      - admissionregistration.k8s.io
    resources:
      - validatingwebhookconfigurations
    verbs:
      - get
      - update
# Source: ingress-nginx/templates/admission-webhooks/job-patch/clusterrolebinding.yaml
metadata:
  annotations:
  labels:
roleRef:
  kind: ClusterRole
subjects:
# Source: ingress-nginx/templates/admission-webhooks/job-patch/role.yaml
kind: Role
metadata:
  annotations:
  labels:
rules:
  - apiGroups:
    resources:
      - secrets
    verbs:
      - get
      - create
# Source: ingress-nginx/templates/admission-webhooks/job-patch/rolebinding.yaml
kind: RoleBinding
metadata:
  annotations:
  labels:
roleRef:
  kind: Role
subjects:
# Source: ingress-nginx/templates/admission-webhooks/job-patch/job-createSecret.yaml
apiVersion: batch/v1
kind: Job
metadata:
  annotations:
  labels:
spec:
  template:
    metadata:
      labels:
    spec:
      containers:
        - name: create
          image: docker.io/jettech/kube-webhook-certgen:v1.5.1
          args:
            - create
            - --host=ingress-nginx-controller-admission,ingress-nginx-controller-admission.$(POD_NAMESPACE).svc
            - --namespace=$(POD_NAMESPACE)
            - --secret-name=ingress-nginx-admission
          env:
              valueFrom:
                fieldRef:
      restartPolicy: OnFailure
      serviceAccountName: ingress-nginx-admission
      securityContext:
        runAsNonRoot: true
        runAsUser: 2000
# Source: ingress-nginx/templates/admission-webhooks/job-patch/job-patchWebhook.yaml
kind: Job
metadata:
  annotations:
    helm.sh/hook: post-install,post-upgrade
  labels:
spec:
  template:
    metadata:
      labels:
    spec:
      containers:
        - name: patch
          args:
            - patch
            - --webhook-name=ingress-nginx-admission
            - --patch-mutating=false
            - --patch-failure-policy=Fail
          env:
              valueFrom:
                fieldRef:
      securityContext:
        runAsNonRoot: true
        runAsUser: 2000
三、dashboard
可以安装k8s的默认可视化平台
GitHub - kubernetes/dashboard: General-purpose web UI for Kubernetes clusters
注意:官方下载来的默认没有指定授权,使用下面创建过授权的配置
# 获取dashboard访问令牌
kubectl -n kubernetes-dashboard describe secret $(kubectl -n kubernetes-dashboard get secret | grep admin-user | awk '{print $1}')
apiVersion: v1
kind: Namespace
metadata:
apiVersion: v1
metadata:
  labels:
    k8s-app: kubernetes-dashboard
  namespace: kubernetes-dashboard
kind: Service
apiVersion: v1
metadata:
  labels:
spec:
  ports:
    - port: 443
      targetPort: 8443
  selector:
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
data:
  csrf: ""
apiVersion: v1
kind: Secret
metadata:
  labels:
type: Opaque
kind: ConfigMap
apiVersion: v1
metadata:
  labels:
kind: Role
metadata:
  labels:
rules:
  # Allow Dashboard to get, update and delete Dashboard exclusive secrets.
  - apiGroups: [""]
    resources: ["secrets"]
    resourceNames: ["kubernetes-dashboard-key-holder", "kubernetes-dashboard-certs", "kubernetes-dashboard-csrf"]
    verbs: ["get", "update", "delete"]
    # Allow Dashboard to get and update 'kubernetes-dashboard-settings' config map.
  - apiGroups: [""]
    resources: ["configmaps"]
    resourceNames: ["kubernetes-dashboard-settings"]
    verbs: ["get", "update"]
    # Allow Dashboard to get metrics.
  - apiGroups: [""]
    resources: ["services"]
    resourceNames: ["heapster", "dashboard-metrics-scraper"]
    verbs: ["proxy"]
  - apiGroups: [""]
    resources: ["services/proxy"]
    resourceNames: ["heapster", "http:heapster:", "https:heapster:", "dashboard-metrics-scraper", "http:dashboard-metrics-scraper"]
    verbs: ["get"]
kind: ClusterRole
metadata:
  labels:
rules:
  # Allow Metrics Scraper to get metrics from the Metrics server
  - apiGroups: ["metrics.k8s.io"]
    resources: ["pods", "nodes"]
    verbs: ["get", "list", "watch"]
kind: RoleBinding
metadata:
  labels:
roleRef:
  kind: Role
subjects:
kind: Deployment
apiVersion: apps/v1
metadata:
  labels:
spec:
  replicas: 1
  selector:
    matchLabels:
  template:
    metadata:
      labels:
    spec:
      containers:
        - name: kubernetes-dashboard
          image: kubernetesui/dashboard:v2.2.0
          imagePullPolicy: Always
          ports:
            - containerPort: 8443
              protocol: TCP
          args:
            - --auto-generate-certificates
            - --namespace=kubernetes-dashboard
            # Uncomment the following line to manually specify Kubernetes API server Host
            # If not specified, Dashboard will attempt to auto discover the API server and connect
            # to it. Uncomment only if the default does not work.
            # - --apiserver-host=http://my-address:port
          volumeMounts:
            - name: kubernetes-dashboard-certs
              mountPath: /certs
              # Create on-disk volume to store exec logs
            - mountPath: /tmp
          livenessProbe:
            httpGet:
              scheme: HTTPS
              path: /
              port: 8443
            initialDelaySeconds: 30
            timeoutSeconds: 30
          securityContext:
            allowPrivilegeEscalation: false
            runAsUser: 1001
            runAsGroup: 2001
      volumes:
          secret:
            secretName: kubernetes-dashboard-certs
        - name: tmp-volume
          emptyDir: {}
      serviceAccountName: kubernetes-dashboard
      nodeSelector:
        "kubernetes.io/os": linux
      # Comment the following tolerations if Dashboard must not be deployed on master
      tolerations:
        - key: node-role.kubernetes.io/master
          effect: NoSchedule
kind: Service
apiVersion: v1
metadata:
  labels:
    k8s-app: dashboard-metrics-scraper
spec:
  ports:
    - port: 8000
      targetPort: 8000
  selector:
kind: Deployment
apiVersion: apps/v1
metadata:
  labels:
spec:
  replicas: 1
  selector:
    matchLabels:
  template:
    metadata:
      labels:
      annotations:
        seccomp.security.alpha.kubernetes.io/pod: 'runtime/default'
    spec:
      containers:
        - name: dashboard-metrics-scraper
          image: kubernetesui/metrics-scraper:v1.0.6
          ports:
            - containerPort: 8000
              protocol: TCP
          livenessProbe:
            httpGet:
              scheme: HTTP
              path: /
              port: 8000
            timeoutSeconds: 30
          volumeMounts:
          - mountPath: /tmp
          securityContext:
            runAsUser: 1001
            runAsGroup: 2001
      nodeSelector:
      tolerations:
          effect: NoSchedule
      volumes:
        - name: tmp-volume
          emptyDir: {}
metadata:
roleRef:
  kind: ClusterRole
subjects:
四、helm应用商店
curl https://raw.githubusercontent.com/helm/helm/master/scripts/get-helm-3 | bash
# helm国内源,但是版本很久没更新 http://mirror.azure.cn/kubernetes/charts/
详细的安装介绍可以参数我上一篇文章
有兴趣的同学可以点下面链接:
云原生(三十) | Kubernetes篇之应用商店-Helm_Lansonli的博客-CSDN博客
