云原生(三十三) | Kubernetes篇之平台存储系统部署
Lansonli 发表于 2022/07/13 08:53:28 2022/07/13
【摘要】 Kubernetes平台存储系统部署官方文档:Ceph Docs一、查看前提条件Raw devices (no partitions or formatted filesystems); 原始磁盘,无分区或者格式化Raw partitions (no formatted filesystem);原始分区,无格式化文件系统fdisk -l # 找到自己挂载的磁盘# 如: /dev/vdc# 查...
Kubernetes平台存储系统部署
官方文档:Ceph Docs
一、查看前提条件
  • Raw devices (no partitions or formatted filesystems); 原始磁盘,无分区或者格式化
  • Raw partitions (no formatted filesystem);原始分区,无格式化文件系统
fdisk -l
# 找到自己挂载的磁盘
# 如: /dev/vdc
# 查看满足要求的
lsblk -f
#云厂商都这么磁盘清0
dd if=/dev/zero of=/dev/vdc bs=1M status=progress
NAME FSTYPE LABEL UUID MOUNTPOINT vda └─vda1 LVM2_member >eSO50t-GkUV-YKTH-WsGq-hNJY-eKNf-3i07IB ├─ubuntu--vg-root ext4 c2366f76-6e21-4f10-a8f3-6776212e2fe4 / └─ubuntu--vg-swap_1 swap 9492a3dc-ad75-47cd-9596-678e8cf17ff9 [SWAP] vdb
vdb 是可用的
二、部署&修改operator
cd cluster/examples/kubernetes/ceph
kubectl create -f crds.yaml -f common.yaml -f operator.yaml #注意修改operator镜像
# verify the rook-ceph-operator is in the `Running` state before proceeding
kubectl -n rook-ceph get pod
修改operator.yaml 把以前的默认镜像换成能用的,如下
  # ROOK_CSI_CEPH_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/cephcsi:v3.3.1"
  # ROOK_CSI_REGISTRAR_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/csi-node-driver-registrar:v2.0.1"
  # ROOK_CSI_RESIZER_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/csi-resizer:v1.0.1"
  # ROOK_CSI_PROVISIONER_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/csi-provisioner:v2.0.4"
  # ROOK_CSI_SNAPSHOTTER_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/csi-snapshotter:v4.0.0"
  # ROOK_CSI_ATTACHER_IMAGE: "registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/csi-attacher:v3.0.2"
镜像: rook/ceph:v1.6.3 换成 registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/rook-ceph:v1.6.3
## 建议修改以下的东西。在operator.yaml里面
三、部署集群
修改cluster.yaml使用我们指定的磁盘当做存储节点即可
  storage: # cluster level storage configuration and selection
    useAllNodes: false
    useAllDevices: false
    config:
      osdsPerDevice: "3" #每个设备osd数量
    nodes:
    - name: "k8s-node3"
      devices:
      - name: "vdc"
    - name: "k8s-node1"
      devices:
      - name: "vdc"
    - name: "k8s-node2"
      devices:
      - name: "vdc"
镜像: ceph/ceph:v15.2.11 换成 registry.cn-hangzhou.aliyuncs.com/lfy_k8s_images/ceph-ceph:v15.2.11
四、部署dashboard
Ceph Docs
前面的步骤,已经自动部署了
kubectl -n rook-ceph get service
#查看service
#为了方便访问我们改为nodePort。应用nodePort文件
#获取访问密码
kubectl -n rook-ceph get secret rook-ceph-dashboard-password -o jsonpath="{['data']['password']}" | base64 --decode && echo
#默认账号 admin
4/qt]e5wad_HY:0&V.ba
MGR: 2;只有一个能用
Mon: 3; 全部可用
Osd: 全部可用
部署了高可用的mgr:提供页面。
  • 先部署nodePort,验证到底哪个mgr不能访问
  • 他是主备模式的高可用。kubectl get svc -n rook-ceph|grep dashboard
  • curl 访问dashboard确定哪个mgr不能访问
  • 自己做一个可访问到的service。如果哪天服务器故障mgr有问题。修改svc的selector即可
apiVersion: v1
kind: Service
metadata:
  labels:
    app: rook-ceph-mgr
    ceph_daemon_id: a
    rook_cluster: rook-ceph
  namespace: rook-ceph
spec:
  ports:
  - name: dashboard
    port: 8443
    protocol: TCP
    targetPort: 8443
  selector:  #service选择哪些Pod
    app: rook-ceph-mgr
    ceph_daemon_id: a
  sessionAffinity: None
  type: ClusterIP
  • 再部署如下的ingress
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  annotations:
    nginx.ingress.kubernetes.io/backend-protocol: "HTTPS"
    nginx.ingress.kubernetes.io/server-snippet: |
      proxy_ssl_verify off;
spec:
  # tls:  不用每个名称空间都配置证书信息
  # - hosts:
  #     - itdachang.com
  #     -  未来的
  #   secretName: testsecret-tls
  rules:
  - host: rook.itdachang.com
    http:
      paths:
      - path: /
        pathType: Prefix
        backend:
          service:
            port:
              number: 8443
五、神坑
#部署完成的最终结果一定要有这些组件
NAME                                                 READY   STATUS      RESTARTS   AGE
csi-cephfsplugin-provisioner-d77bb49c6-n5tgs         5/5     Running     0          140s
csi-cephfsplugin-provisioner-d77bb49c6-v9rvn         5/5     Running     0          140s
csi-cephfsplugin-rthrp                               3/3     Running     0          140s
csi-rbdplugin-hbsm7                                  3/3     Running     0          140s
csi-rbdplugin-provisioner-5b5cd64fd-nvk6c            6/6     Running     0          140s
csi-rbdplugin-provisioner-5b5cd64fd-q7bxl            6/6     Running     0          140s
rook-ceph-crashcollector-minikube-5b57b7c5d4-hfldl   1/1     Running     0          105s
rook-ceph-mgr-a-64cd7cdf54-j8b5p                     1/1     Running     0          77s
rook-ceph-mon-a-694bb7987d-fp9w7                     1/1     Running     0          105s
rook-ceph-mon-b-856fdd5cb9-5h2qk                     1/1     Running     0          94s
rook-ceph-mon-c-57545897fc-j576h                     1/1     Running     0          85s
rook-ceph-operator-85f5b946bd-s8grz                  1/1     Running     0          92m
rook-ceph-osd-0-6bb747b6c5-lnvb6                     1/1     Running     0          23s
rook-ceph-osd-1-7f67f9646d-44p7v                     1/1     Running     0          24s
rook-ceph-osd-2-6cd4b776ff-v4d68                     1/1     Running     0          25s
rook-ceph-osd-prepare-node1-vx2rz                    0/2     Completed   0          60s
rook-ceph-osd-prepare-node2-ab3fd                    0/2     Completed   0          60s
rook-ceph-osd-prepare-node3-w4xyz                    0/2     Completed   0          60s
#解决方案。
#找到自己的operator,删除这个pod,让重新执行
kubectl delete pod rook-ceph-operator-65965c66b5-cxrl8 -n rook-ceph
#rbd:是ceph用来做块存储的
#cephfs:是用来做共享文件系统的
六、卸载
# rook集群的清除,
##1、 delete -f 之前的yaml
##2、 再执行如下命令
kubectl -n rook-ceph get cephcluster
kubectl -n rook-ceph patch cephclusters.ceph.rook.io rook-ceph -p '{"metadata":{"finalizers": []}}' --type=merge
##3、 清除每个节点的 /var/lib/rook 目录
## 顽固的自定义资源删除;
kubectl -n rook-ceph patch cephblockpool.ceph.rook.io replicapool -p '{"metadata":{"finalizers": []}}' --type=merge
Rook+Ceph;
  • Rook帮我们创建好 StorageClass
    • pvc只需要指定存储类,Rook自动调用 StorageClass 里面的 Provisioner供应商,接下来对ceph集群操作
  • Ceph
    • Block:块存储。RWO(ReadWriteOnce)单节点读写【一个Pod操作一个自己专属的读写区】,适用于(有状态副本集)
    • Share FS:共享存储。RWX(ReadWriteMany)多节点读写【多个Pod操作同一个存储区,可读可写】,适用于无状态应用。(文件系统 )
    • 总结: 无状态应用随意复制多少份,一定用到RWX能力。有状态应用复制任意份,每份都只是读写自己的存储,用到RWO(优先)或者RWX。
  • 直接通过Rook可以使用到任意能力的存储。
CRI、CNI、CSI
CRI:Container Runtime Interface:容器运行时接口(k8s集群整合容器运行时环境)
CNI:Container Network Interface:容器网络接口(k8s集群整合网络组件的接口)
CSI:Container Storage Interface:容器存储接口(k8s集群整合存储组件的接口)
kubelet启动一个Pod。CRI、CNI、CSI 起作用的顺序
