Spring JdbcTemplate&声明式事务
共饮一杯无 发表于 2022/07/10 18:41:34 2022/07/10
【摘要】 JdbcTemplate基本使用 概述JdbcTemplate是spring框架中提供的一个对象,是对原始繁琐的Jdbc API对象的简单封装。spring框架为我们提供了很多的操作模板类。例如:操作关系型数据的JdbcTemplate和HibernateTemplate,操作nosql数据库的RedisTemplate,操作消息队列的JmsTemplate等等。 开发步骤①导入sprin...
JdbcTemplate基本使用
概述
开发步骤
①导入spring-jdbc和spring-tx坐标
②创建数据库表和实体
③创建JdbcTemplate对象
④执行数据库操作
快速入门代码实现
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <groupId>com.zjq</groupId>
  <artifactId>zjq_spring_jdbc</artifactId>
  <version>1.0-SNAPSHOT</version>
  <packaging>war</packaging>
  <name>zjq_spring_jdbc Maven Webapp</name>
  <!-- FIXME change it to the project's website -->
  <url>http://www.example.com</url>
  <dependencies>
    <dependency>
      <groupId>mysql</groupId>
      <artifactId>mysql-connector-java</artifactId>
      <version>5.1.32</version>
    </dependency>
    <dependency>
      <groupId>c3p0</groupId>
      <artifactId>c3p0</artifactId>
      <version>0.9.1.2</version>
    </dependency>
    <dependency>
      <groupId>com.alibaba</groupId>
      <artifactId>druid</artifactId>
      <version>1.1.10</version>
    </dependency>
    <dependency>
      <groupId>junit</groupId>
      <artifactId>junit</artifactId>
      <version>4.12</version>
    </dependency>
    <dependency>
      <groupId>org.springframework</groupId>
      <artifactId>spring-context</artifactId>
      <version>5.0.5.RELEASE</version>
    </dependency>
    <dependency>
      <artifactId>spring-test</artifactId>
    </dependency>
    <dependency>
      <artifactId>spring-web</artifactId>
    </dependency>
    <dependency>
      <artifactId>spring-webmvc</artifactId>
    </dependency>
    <dependency>
      <groupId>javax.servlet</groupId>
      <artifactId>javax.servlet-api</artifactId>
      <version>3.0.1</version>
      <scope>provided</scope>
    </dependency>
    <dependency>
      <groupId>javax.servlet.jsp</groupId>
      <artifactId>javax.servlet.jsp-api</artifactId>
      <version>2.2.1</version>
    </dependency>
    <dependency>
      <groupId>com.fasterxml.jackson.core</groupId>
      <artifactId>jackson-core</artifactId>
      <version>2.9.0</version>
    </dependency>
    <dependency>
      <artifactId>jackson-databind</artifactId>
    </dependency>
    <dependency>
      <artifactId>jackson-annotations</artifactId>
    </dependency>
    <dependency>
      <groupId>commons-fileupload</groupId>
      <artifactId>commons-fileupload</artifactId>
      <version>1.3.1</version>
    </dependency>
    <dependency>
      <groupId>commons-io</groupId>
      <artifactId>commons-io</artifactId>
      <version>2.3</version>
    </dependency>
    <dependency>
      <artifactId>spring-jdbc</artifactId>
    </dependency>
    <dependency>
      <artifactId>spring-tx</artifactId>
    </dependency>
  </dependencies>
</project>
创建数据库表和实体
package com.zjq.domain;
public class Account {
    private String name;
    private double money;
    public String getNa me() {
        return name;
    public void setName(String name) {
        this.name = name;
    public double getMoney() {
        return money;
    public void setMoney(double money) {
        this.money = money;
    @Override
    public String toString() {
        return "Account{" +
                "name='" + name + '\'' +
                ", money=" + money +
创建JdbcTemplate对象
执行数据库操作
@Test
    //测试JdbcTemplate开发步骤
    public void test1() throws PropertyVetoException {
        //创建数据源对象
        ComboPooledDataSource dataSource = new ComboPooledDataSource();
        dataSource.setDriverClass("com.mysql.jdbc.Driver");
        dataSource.setJdbcUrl("jdbc:mysql://localhost:3306/test");
        dataSource.setUser("root");
        dataSource.setPassword("root");
        JdbcTemplate jdbcTemplate = new JdbcTemplate();
        //设置数据源对象  知道数据库在哪
        jdbcTemplate.setDataSource(dataSource);
        //执行操作
        int row = jdbcTemplate.update("insert into account values(?,?)", "tom", 5000);
        System.out.println(row);
spring产生模板对象分析
我们可以将JdbcTemplate的创建权交给Spring,将数据源DataSource的创建权也交给Spring,在Spring容器内部将数据源DataSource注入到JdbcTemplate模版对象中,然后通过Spring容器获得JdbcTemplate对象来执行操作。
spring产生模板对象代码实现
配置如下:
<!--数据源对象-->
    <bean id="dataSource" class="com.mchange.v2.c3p0.ComboPooledDataSource">
        <property name="driverClass" value="com.mysql.jdbc.Driver"></property>
        <property name="jdbcUrl" value="jdbc:mysql:///test"></property>
        <property name="user" value="root"></property>
        <property name="password" value="root"></property>
    </bean>
    <!--jdbc模板对象-->
    <bean id="jdbcTemplate" class="org.springframework.jdbc.core.JdbcTemplate">
        <property name="dataSource" ref="dataSource"/>
    </bean>
测试代码
 @Test
    //测试Spring产生jdbcTemplate对象
    public void test2() throws PropertyVetoException {
        ApplicationContext app = new ClassPathXmlApplicationContext("applicationContext.xml");
        JdbcTemplate jdbcTemplate = app.getBean(JdbcTemplate.class);
        int row = jdbcTemplate.update("insert into account values(?,?)", "lisi", 5000);
spring产生模板对象代码实现(抽取jdbc.properties)
将数据库的连接信息抽取到外部配置文件中,和spring的配置文件分离开,有利于后期维护
jdbc.driver=com.mysql.jdbc.Driver
jdbc.url=jdbc:mysql://localhost:3306/test
jdbc.username=root
jdbc.password=root
配置文件修改为:
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:context="http://www.springframework.org/schema/context"
       http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
       http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd
    <!--加载jdbc.properties-->
    <context:property-placeholder location="classpath:jdbc.properties"/>
    <!--数据源对象-->
        <property name="driverClass" value="${jdbc.driver}"/>
        <property name="jdbcUrl" value="${jdbc.url}"/>
        <property name="user" value="${jdbc.username}"/>
        <property name="password" value="${jdbc.password}"/>
    </bean>
    <!--jdbc模板对象-->
    </bean>
</beans>
常用操作-更新操作
package com.zjq.test;
import com.zjq.domain.Account;
import org.junit.Test;
import org.junit.runner.RunWith;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.jdbc.core.BeanPropertyRowMapper;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.test.context.ContextConfiguration;
import org.springframework.test.context.junit4.SpringJUnit4ClassRunner;
import java.util.List;
@RunWith(SpringJUnit4ClassRunner.class)
@ContextConfiguration("classpath:applicationContext.xml")
public class JdbcTemplateCRUDTest {
    @Autowired
    private JdbcTemplate jdbcTemplate;
	//修改更新
    @Test
    public void testUpdate(){
        jdbcTemplate.update("update account set money=? where name=?",10000,"tom");
	//删除
    @Test
    public void testDelete(){
        jdbcTemplate.update("delete from account where name=?","tom");
常用操作-查询操作
    @Autowired
	//聚合查询
    @Test
    public void testQueryCount(){
        Long count = jdbcTemplate.queryForObject("select count(*) from account", Long.class);
        System.out.println(count);
	//查询一个
    @Test
    public void testQueryOne(){
        Account account = jdbcTemplate.queryForObject("select * from account where name=?", new BeanPropertyRowMapper<Account>(Account.class), "tom");
        System.out.println(account);
	//查询所有
    @Test
    public void testQueryAll(){
        List<Account> accountList = jdbcTemplate.query("select * from account", new BeanPropertyRowMapper<Account>(Account.class));
        System.out.println(accountList);
知识要点
②创建数据库表和实体
③创建JdbcTemplate对象
④执行数据库操作
更新操作:
    jdbcTemplate.update (sql,params)
查询操作:
    jdbcTemplate.query (sql,Mapper,params)
jdbcTemplate.queryForObject(sql,Mapper,params)
声明式事务控制
编程式事务控制相关对象
PlatformTransactionManager
PlatformTransactionManager 接口是 spring 的事务管理器,它里面提供了我们常用的操作事务的方法。
注意:
PlatformTransactionManager 是接口类型,不同的 Dao 层技术则有不同的实现类,例如:Dao 层技术是jdbc 或 mybatis 时:org.springframework.jdbc.datasource.DataSourceTransactionManager
Dao 层技术是hibernate时:org.springframework.orm.hibernate5.HibernateTransactionManager
TransactionDefinition
TransactionDefinition 是事务的定义信息对象,里面有如下方法:
事务隔离级别
设置隔离级别,可以解决事务并发产生的问题,如脏读、不可重复读和虚读。
  • ISOLATION_DEFAULT
  • ISOLATION_READ_UNCOMMITTED
  • ISOLATION_READ_COMMITTED
  • ISOLATION_REPEATABLE_READ
  • ISOLATION_SERIALIZABLE
事务传播行为
  • REQUIRED:如果当前没有事务,就新建一个事务,如果已经存在一个事务中,加入到这个事务中。一般的选择(默认值)
  • SUPPORTS:支持当前事务,如果当前没有事务,就以非事务方式执行(没有事务)
  • MANDATORY:使用当前的事务,如果当前没有事务,就抛出异常
  • REQUERS_NEW:新建事务,如果当前在事务中,把当前事务挂起。
  • NOT_SUPPORTED:以非事务方式执行操作,如果当前存在事务,就把当前事务挂起
  • NEVER:以非事务方式运行,如果当前存在事务,抛出异常
  • NESTED:如果当前存在事务,则在嵌套事务内执行。如果当前没有事务,则执行 REQUIRED 类似的操作
  • 超时时间:默认值是-1,没有超时限制。如果有,以秒为单位进行设置
  • 是否只读:建议查询时设置为只读
TransactionStatus
TransactionStatus 接口提供的是事务具体的运行状态,方法介绍如下。
知识要点
编程式事务控制三大对象
  • PlatformTransactionManager
  • TransactionDefinition
  • TransactionStatus
基于 XML 的声明式事务控制
什么是声明式事务控制
Spring 的声明式事务顾名思义就是采用声明的方式来处理事务。这里所说的声明,就是指在配置文件中声明,用在 Spring 配置文件中声明式的处理事务来代替代码式的处理事务。
声明式事务处理的作用
  • 事务管理不侵入开发的组件。具体来说,业务逻辑对象就不会意识到正在事务管理之中,事实上也应该如此,因为事务管理是属于系统层面的服务,而不是业务逻辑的一部分,如果想要改变事务管理策划的话,也只需要在定义文件中重新配置即可
  • 在不需要事务管理的时候,只要在设定文件上修改一下,即可移去事务管理服务,无需改变代码重新编译,这样维护起来极其方便
注意:Spring 声明式事务控制底层就是AOP。
声明式事务控制的实现
声明式事务控制明确事项:
  • 谁是切点?
  • 谁是通知?
  • 配置切面?
①引入tx命名空间
       xmlns:aop="http://www.springframework.org/schema/aop"
       xmlns:tx="http://www.springframework.org/schema/tx"
        http://www.springframework.org/schema/aop/spring-aop.xsd
        http://www.springframework.org/schema/tx/spring-tx.xsd
        http://www.springframework.org/schema/beans/spring-beans.xsd">
②配置事务增强
<!--平台事务管理器-->
<bean id="transactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
    <property name="dataSource" ref="dataSource"></property>
</bean>
<!--事务增强配置-->
<tx:advice id="txAdvice" transaction-manager="transactionManager">
    <tx:attributes>
        <tx:method name="*"/>
    </tx:attributes>
</tx:advice>
③配置事务 AOP 织入
<!--事务的aop增强-->
<aop:config>
    <aop:pointcut id="myPointcut" expression="execution(* com.zjq.service.impl.*.*(..))"/>
    <aop:advisor advice-ref="txAdvice" pointcut-ref="myPointcut"></aop:advisor>
</aop:config>
④测试事务控制转账业务代码
@Override
public void transfer(String outMan, String inMan, double money) {
    accountDao.out(outMan,money);
    int i = 1/0;
    accountDao.in(inMan,money);
切点方法的事务参数的配置
<!--事务增强配置-->
    <tx:attributes>
    </tx:attributes>
</tx:advice>
其中,tx:method 代表切点方法的事务参数的配置,例如:
<tx:method name="transfer" isolation="REPEATABLE_READ" propagation="REQUIRED" timeout="-1" read-only="false"/>
  • name:切点方法名称
  • isolation:事务的隔离级别
  • propogation:事务的传播行为
  • timeout:超时时间
  • read-only:是否只读
知识要点
声明式事务控制的配置要点
  • 平台事务管理器配置
  • 事务通知的配置
  • 事务aop织入的配置
基于注解的声明式事务控制
使用注解配置声明式事务控制
  1. 编写 AccoutDao
@Repository("accountDao")
public class AccountDaoImpl implements AccountDao {
    @Autowired
    public void out(String outMan, double money) {
        jdbcTemplate.update("update account set money=money-? where name=?",money,outMan);
    public void in(String inMan, double money) {
        jdbcTemplate.update("update account set money=money+? where name=?",money,inMan);
  1. 编写 AccoutService
@Service("accountService")
@Transactional
public class AccountServiceImpl implements AccountService {
    @Autowired
    private AccountDao accountDao;
    @Transactional(isolation = Isolation.READ_COMMITTED,propagation = Propagation.REQUIRED)
        int i = 1/0;
  1. 编写 applicationContext.xml 配置文件
<!—之前省略datsSource、jdbcTemplate、平台事务管理器的配置-->
<!--组件扫描-->
<context:component-scan base-package="com.zjq"/>
<!--事务的注解驱动-->
<tx:annotation-driven/>
注解配置声明式事务控制解析
①使用 @Transactional 在需要进行事务控制的类或是方法上修饰,注解可用的属性同 xml 配置方式,例如隔离级别、传播行为等。
②注解使用在类上,那么该类下的所有方法都使用同一套注解参数配置。
③使用在方法上,不同的方法可以采用不同的事务参数配置。
④Xml配置文件中要开启事务的注解驱动<tx:annotation-driven />
知识要点
注解声明式事务控制的配置要点
  • 平台事务管理器配置(xml方式)
  • 事务通知的配置(@Transactional注解配置)
  • 事务注解驱动的配置 tx:annotation-driven/
本文内容到此结束了,
如有收获欢迎点赞👍收藏💖关注✔️,您的鼓励是我最大的动力。
如有错误❌疑问💬欢迎各位大佬指出。
保持热爱,奔赴下一场山海。🏃🏃🏃
