【轴承故障分离】基于matlab共振稀疏分解匹配追踪法轴承故障信号分离【含Matlab源码 1942期】
海神之光 发表于 2022/07/10 00:46:44 2022/07/10
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【轴承故障分离】基于matlab共振稀疏分解匹配追踪法轴承故障信号分离【含Matlab源码 1942期】 获取代码方式2: 通过订阅紫极神光...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function [proj,scale,translation,freq,phase]=select_best(signal_r,N,a_base,j_min,j_max,u_base,p_min,v_base,k_min,w_base,i_min,i_max);
%% this subroutine program(子程序)is to select in the dictionary the best atom suited the signal or the residual of the signal
% INPUT
% the signal_r: the signal or the residual of the signal to be decomposed
% the N: the length of the signal or of the residual of the signal or the length of the atoms
% parameters :the parameter to construct the dictionary , it has much influence on the speed of the decomposition
% a_base=2;
% j_min=0;
% j_max=log2(N);
% OUTPUT
% proj:the projection of the signal or the residual of the signal on the best atom
% scale:the scale of the best atom(s in the formula)
% translation:the translation of the best atom(u in the formula)
% freq:the freq of the best atom(v in the formula)
% phase:the phase of the best atom(w in the formula)
% proj_trans:to determine which projection is biggest
proj_trans=0;
proj=0;
% size_dic is one parameter to show the size of the over-complete dictionary used
size_dic=0;
% [hy,hx]=meshgrid(0:32-1,0:32-1);
% m=32;n=32;
for j=j_min:j_max
    for p=p_min:N*2^(-j+1)
        for k=k_min:2^(j+1)
            for i=i_min:i_max
              size_dic=size_dic+1;
              s=a_base^j;
              u=p*s*u_base;
              v=k*(1/s)*v_base;
              w=i*w_base;
              t=0:N-1;
              t=(t-u)/s;
              g=(1/sqrt(s))*exp(-pi*t.*t).*cos(v*t+w);
              g=g/sqrt(sum(g.*g));
              proj_trans=sum(signal_r.*g);
                if abs(proj_trans)>abs(proj)
                 proj=proj_trans;
                 scale=s;
                 translation=u;
                 freq=v;
                 phase=w;
                end
             end
         end
    end
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
3 备注
简介此部分摘自互联网,仅供参考,若侵权,联系删除
原文链接:qq912100926.blog.csdn.net/article/details/125685373
