PostgreSQL服务端编程CTE
xcc-2022 发表于 2022/07/04 21:09:47 2022/07/04
【摘要】 背景1:当我们需要查询很多客户的,离当前时间最近订单时参考网址:http://bonesmoses.org/2014/05/08/trumping-the-postgresql-query-planner/创建测试表CREATE TABLE test_order( client_id INT NOT NULL, order_date TIMESTAMP NOT NU...
背景1:
参考网址:
创建测试表
  order_date  TIMESTAMP  NOT NULL,
  filler      TEXT       NOT NULL
插入测试数据
INSERT INTO test_order
SELECT s1.id,
       (CURRENT_DATE - INTERVAL '1000 days')::DATE
           + generate_series(1, s1.id%1000),
       repeat(' ', 20)
  FROM generate_series(1, 10000) s1 (id);
CREATE INDEX idx_test_order_client_id_order_date
    ON test_order (client_id, order_date DESC);
执行普通SQL
不走索引
EXPLAIN ANALYZE
SELECT client_id, max(order_date)
  FROM test_order
 GROUP BY client_id;
"Execution time: 5741.682 ms"
使用索引
EXPLAIN ANALYZE SELECT DISTINCT ON (client_id) client_id, order_date FROM test_order ORDER BY client_id, order_date DESC;
"Execution time: 4628.510 ms"
优化后SQL
EXPLAIN ANALYZE
WITH RECURSIVE skip AS
  (SELECT client_id, order_date
    FROM test_order
   LIMIT 1)
  UNION ALL
  (SELECT (SELECT min(client_id)
             FROM test_order
            WHERE client_id > skip.client_id
          ) AS client_id,
          (SELECT max(order_date)
             FROM test_order
            WHERE client_id = (
                      FROM test_order
          ) AS order_date
    FROM skip
   WHERE skip.client_id IS NOT NULL)
SELECT *
  FROM skip;
"Execution time: 865.889 ms"
查询结果
client_id; order_date
1;"2014-03-09 00:00:00"
2;"2014-03-10 00:00:00"
3;"2014-03-11 00:00:00"
4;"2014-03-12 00:00:00"
5;"2014-03-13 00:00:00"
6;"2014-03-14 00:00:00"
7;"2014-03-15 00:00:00"
8;"2014-03-16 00:00:00"
9;"2014-03-17 00:00:00"
10;"2014-03-18 00:00:00"
11;"2014-03-19 00:00:00"
12;"2014-03-20 00:00:00"
13;"2014-03-21 00:00:00"
14;"2014-03-22 00:00:00"
15;"2014-03-23 00:00:00"
16;"2014-03-24 00:00:00"
17;"2014-03-25 00:00:00"
18;"2014-03-26 00:00:00"
19;"2014-03-27 00:00:00"
20;"2014-03-28 00:00:00"
21;"2014-03-29 00:00:00"
22;"2014-03-30 00:00:00"
23;"2014-03-31 00:00:00"
24;"2014-04-01 00:00:00"
背景2:
参考网址:
https://yq.aliyun.com/articles/65202?spm=5176.8091938.0.0.tZZBTS
有一个这样的场景,一张小表A,里面存储了一些ID,大约几百个。
(比如说巡逻车辆ID,环卫车辆的ID,公交车,微公交的ID)。
另外有一张日志表B,每条记录中的ID是来自前面那张小表的,但不是每个ID都出现在这张日志表中,比如说一天可能只有几十个ID会出现在这个日志表的当天的数据中。
(比如车辆的行车轨迹数据,每秒上报轨迹,数据量就非常庞大)。
那么我怎么快速的找出今天没有出现的ID呢。
(哪些巡逻车辆没有出现在这个片区,是不是偷懒了?哪些环卫车辆没有出行,哪些公交或微公交没有出行)?
select id from A where id not in (select id from B where time between ? and ?);
这个QUERY会很慢,有什么优化方法呢。
当然,你还可以让车辆签到的方式来解决这个问题,但是总有未签到的,或者没有这种设计的时候,那么怎么解决呢?
-- A
create table a(id int primary key, info text);
-- B
create table b(id int primary key, aid int, crt_time timestamp);
create index b_aid on b(aid);
-- a表插入1000条
insert into a select generate_series(1,1000), md5(random()::text);
-- b表插入500万条,只包含aid的500个id。
insert into b select generate_series(1,5000000), generate_series(1,500), clock_timestamp();
优化前:
select * from a where id not in (select aid from b);
执行时间:大于1min
优化后:
select * from a where id not in (with recursive skip as (
    select min(aid) aid from b where aid is not null
  union all
    select (select min(aid) aid from b where b.aid > s.aid and b.aid is not null)
      from skip s where s.aid is not null
  )  -- 这里的where s.aid is not null 一定要加,否则就死循环了.
select aid from skip where aid is not null);
执行时间:46 msec
情景3:
生成树形结构
参考网址:
http://blog.databasepatterns.com/2014/02/trees-paths-recursive-cte-postgresql.html
create table subregions (
  id smallint primary key,
  name text not null,
  parent_id smallint null references subregions(id)
insert into subregions values
(1,'World',null),
(2,'Africa',1),
(5,'South America',419),
(9,'Oceania',1),
(11,'Western Africa',2),
(13,'Central America',419),
(14,'Eastern Africa',2),
(15,'Northern Africa',2),
(17,'Middle Africa',2),
(18,'Southern Africa',2),
(19,'Americas',1),
(21,'Northern America',19),
(29,'Caribbean',419),
(30,'Eastern Asia',142),
(34,'Southern Asia',142),
(35,'South-Eastern Asia',142),
(39,'Southern Europe',150),
(53,'Australia and New Zealand',9),
(54,'Melanesia',9),
(57,'Micronesia',9),
(61,'Polynesia',9),
(142,'Asia',1),
(143,'Central Asia',142),
(145,'Western Asia',142),
(150,'Europe',1),
(151,'Eastern Europe',150),
(154,'Northern Europe',150),
(155,'Western Europe',150),
(419,'Latin America and the Caribbean',19);
And you wanted to make a pretty tree like this:
World
   Africa
      Eastern Africa
      Middle Africa
      Northern Africa
      Southern Africa
      Western Africa
   Americas
         Caribbean
         Central America
         South America
      Northern America
   Asia
      Central Asia
      Eastern Asia
      South-Eastern Asia
      Southern Asia
      Western Asia
   Europe
      Eastern Europe
      Northern Europe
      Southern Europe
      Western Europe
   Oceania
      Melanesia
      Micronesia
      Polynesia
Here's how you'd do it:
with recursive my_expression as (
  --start with the "anchor", i.e. all of the nodes whose parent_id is null:
  select
    id,
    name as path,
    name as tree,
    0 as level
  from subregions
  where
    parent_id is null
  union all
  --then the recursive part:
  select
    current.id as id,
    previous.path || ' > ' || current.name as path,
    repeat('   ', previous.level + 1) || current.name as tree,
    previous.level + 1 as level
  from subregions current
  join my_expression as previous on current.parent_id = previous.id
select
  tree
from my_expression
order by
  path
路径间加入父节点和分割
select
  path
from my_expression
order by
  path
输出结果:
World
World > Africa
World > Africa > Eastern Africa
World > Africa > Middle Africa
World > Africa > Northern Africa
World > Africa > Southern Africa
World > Africa > Western Africa
World > Americas
World > Americas > Latin America and the Caribbean
World > Americas > Latin America and the Caribbean > Caribbean
World > Americas > Latin America and the Caribbean > Central America
World > Americas > Latin America and the Caribbean > South America
World > Americas > Northern America
World > Asia
World > Asia > Central Asia
World > Asia > Eastern Asia
World > Asia > South-Eastern Asia
World > Asia > Southern Asia
World > Asia > Western Asia
World > Europe
World > Europe > Eastern Europe
World > Europe > Northern Europe
World > Europe > Southern Europe
World > Europe > Western Europe
World > Oceania
World > Oceania > Australia and New Zealand
World > Oceania > Melanesia
World > Oceania > Micronesia
World > Oceania > Polynesia
