Unity报错之UnityException: Texture ‘XXX‘ is not readable
爱上游戏开发 发表于 2022/07/03 00:32:16 2022/07/03
【摘要】 问题 UnityException: Texture ‘img2’ is not readable, the texture memory can not be accessed from scri...
问题
UnityException: Texture ‘img2’ is not readable, the texture memory can not be accessed from scripts. You can make the texture readable in the Texture Import Settings.
解决
文章来源: unity3d.blog.csdn.net,作者:爱上游戏开发,版权归原作者所有,如需转载,请联系作者。
原文链接:unity3d.blog.csdn.net/article/details/120068221
