unity之模糊背景(带你欣赏女人的朦胧美)
爱上游戏开发 发表于 2022/07/02 22:44:15 2022/07/02
【摘要】 最近项目用到了模糊背景效果。实现方法为:shader。代码来自百度。接下来给大家介绍一下模糊背景的实现过程。首先你需要一个先人已经写好的shader(当然,如果你有能力,也可以自己实现!) 没有的可以通过...
没有的可以通过以下链接下载材质球和对应的shader。
模糊背景shader
模糊背景材质球
shader如下:
Shader "FT/Blur/Back"
	Properties
		_Color ("Main Color", Color) = (1,1,1,1)
        _Size ("Size", Range(0, 20)) = 1
	Category {
        // We must be transparent, so other objects are drawn before this one.
        Tags {
			"Queue"="Transparent"
			"IgnoreProjector"="True"
			"RenderType"="Transparent"
			"PreviewType" = "Plane"
			"CanUseSpriteAtlas" = "True"
        SubShader {
            // Horizontal blur
            GrabPass
                Tags { "LightMode" = "Always" }
            Pass {
                Name "BackBlurHor"
                CGPROGRAM
                #pragma vertex vert
                #pragma fragment frag
                #pragma fragmentoption ARB_precision_hint_fastest
                #include "UnityCG.cginc"
                struct appdata_t {
                    float4 vertex : POSITION;
                    float2 texcoord : TEXCOORD0;
					float4 color    : COLOR;
                struct v2f {
                    float4 uvgrab : TEXCOORD0;
                v2f vert (appdata_t v) {
                    v2f o;
                    o.vertex = UnityObjectToClipPos(v.vertex);
                    #if UNITY_UV_STARTS_AT_TOP
                    float scale = -1.0;
                    #else
                    float scale = 1.0;
                    #endif
                    o.uvgrab.xy = (float2(o.vertex.x, o.vertex.y*scale) + o.vertex.w) * 0.5;
                    o.uvgrab.zw = o.vertex.zw;
					o.color = v.color;
                    return o;
                sampler2D _GrabTexture;
                float4 _GrabTexture_TexelSize;
			    float4 _MainTex_TexelSize;
                float _Size;
                uniform float4 _Color;
                half4 GrabPixel(v2f i, float weight, float kernel){
                    kernel = sign(sign(abs(i.uvgrab.x)) + sign(abs(i.uvgrab.y))) * kernel;
					return tex2Dproj(_GrabTexture, UNITY_PROJ_COORD(float4(i.uvgrab.x + _GrabTexture_TexelSize.x * kernel * _Size, i.uvgrab.y, i.uvgrab.z, i.uvgrab.w))) * weight;
                half4 frag( v2f i ) : COLOR {
                 	half4 sum = half4(0,0,0,0);
                    sum += GrabPixel(i, 0.05, -4.0);
                    sum += GrabPixel(i, 0.09, -3.0);
                    sum += GrabPixel(i, 0.12, -2.0);
                    sum += GrabPixel(i, 0.15, -1.0);
                    sum += GrabPixel(i, 0.18,  0.0);
                    sum += GrabPixel(i, 0.15, +1.0);
                    sum += GrabPixel(i, 0.12, +2.0);
                    sum += GrabPixel(i, 0.09, +3.0);
                    sum += GrabPixel(i, 0.05, +4.0);
                    float4 col5 = tex2Dproj(_GrabTexture, UNITY_PROJ_COORD(i.uvgrab));
					fixed decayFactor = sign(sign(abs(i.uvgrab.x)) + sign(abs(i.uvgrab.y)));
					sum = lerp(col5, sum, decayFactor) * i.color * _Color;
                    return sum;
                ENDCG
            // Vertical blur
            GrabPass {
            Pass {
                Name "BackBlurVer"
                CGPROGRAM
                #pragma vertex vert
                struct appdata_t {
                    float2 texcoord: TEXCOORD0;
                struct v2f {
                    v2f o;
                    float scale = -1.0;
                    #else
                    float scale = 1.0;
                    #endif
					o.color = v.color;
                    return o;
                float _Size;
                    return tex2Dproj( _GrabTexture, UNITY_PROJ_COORD(float4(i.uvgrab.x, i.uvgrab.y + _GrabTexture_TexelSize.y * kernel * _Size, i.uvgrab.z, i.uvgrab.w))) * weight;
                    return sum;
                ENDCG
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
unity中使用方法:
为工程导入下载的材质球和shader
通常我们新建Material文件夹存放材质球
创建Shader文件夹存放shader代码
新建背景Image,命名为bg,并为其赋上指定的图片资源,如下:
新建模糊材质背景Image,命名为mask,SourceImage指定任意值即可;Material指定下载的材质球
效果如下:
调节材质球的Size可以调节模糊程度。值越大,效果越模糊。
将size值拉到5效果如下:
文章来源: unity3d.blog.csdn.net,作者:爱上游戏开发,版权归原作者所有,如需转载,请联系作者。
原文链接:unity3d.blog.csdn.net/article/details/123226911
