Oracle 死锁测试
snowofsummer 发表于 2022/07/01 15:53:36 2022/07/01
【摘要】 1,建立测试表create table l (id int);insert into l values(1);insert into l values(2);2,执行锁测试需要打开2个会话.会话1会话2select * from l where id=1 for update;  select * from l where id=2 for update;select * from l wh...
1,建立测试表
2,执行锁测试
需要打开2个会话.
会话1 会话2
----等待会话2提交。
----等待会话1提交。
SQL> select * from l where id=2 for update;
ERROR at line 1:
ORA-00060: deadlock detected while waiting for resource
//需要执行commit,rollback.会话2才能正常执行。
3,PG锁测试
会话1 会话2
begin; begin;
#会话等待2
#会话2报错,会话rollback;
postgres=*# select * from l where id=1 for update;
ERROR:  deadlock detected
DETAIL:  Process 26109 waits for ShareLock on transaction 585; blocked by process 26104.
Process 26104 waits for ShareLock on transaction 586; blocked by process 26109.
HINT:  See server log for query details.
CONTEXT:  while locking tuple (0,1) in relation "l"
postgres=!# select * from l where id=2 for update;
ERROR:  current transaction is aborted, commands ignored until end of transaction block
postgres=!# commit;
ROLLBACK
 #会话1正常执行。可以正常commit
