202207-1|兼容10个浏览器HTML头部配置
写程序的小王叔叔 发表于 2022/07/01 09:54:12 2022/07/01
【摘要】 兼容10个浏览器HTML头部配置
主页:小王叔叔的博客
支持:点赞👍关注✔️收藏💖
<!DOCTYPE html>
<!--[if IE 7]>    <html class="no-js ie7 ie" lang="en"> <![endif]-->
<!--[if IE 8]>    <html class="no-js ie8 ie" lang="en"> <![endif]-->
<!--[if IE 9]>    <html class="no-js ie9 ie" lang="en"> <![endif]-->
<!--[if gt IE 9]><!-->  <html class="no-js" lang="en">  <!--<![endif]-->
 <head>
  <title>首页</title>
  <meta charset="utf-8" />
  <meta name="viewport" content="width=device-width, initial-scale=1.0" />
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <!--IE10-->
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=8,IE=9,IE=10"/>
  <meta name=”renderer” content=”webkit|ie-comp|ie-stand”/>
  <!-- CSS styles -->
  <link rel="stylesheet" type="text/css" href="css/base.css" />
  <link rel="stylesheet" type="text/css" href="css/header.css"/>
  <link rel="stylesheet" type="text/css" href="css/index.css" />
  <link rel="stylesheet" type="text/css" href="css/footer.css"/>
  <link rel="stylesheet" href="common/jquery/css/jquery.ui.all.css">
  <script src="common/jquery/js/jquery-1.8.2.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.core.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.widget.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.button.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.position.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.menu.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.autocomplete.js" charset="utf-8"></script>
  <script src="common/jquery/js/jquery.ui.tooltip.js" charset="utf-8"></script>
  <link rel="stylesheet" href="common/jquery/jquery/css/demos.css">
  <link rel='stylesheet' type='text/css' href="common/form/css/form.css" />
  <!--JavaScript-->
  <script language="javascript" type="text/javascript" src="js/highcharts/highcharts.js"></script>
  <script type="text/javascript" src="js/My97DatePicker/WdatePicker.js"></script>
  <script language="javascript" type="text/javascript" src="js/misps/index.js"></script>
 </head>
转载声明:本文为博主原创文章,未经博主允许不得转载
⚠️注意 ~
💯本期内容就结束了,如果内容有误,麻烦大家评论区指出!
如有疑问❓可以在评论区💬或私信💬,尽我最大能力🏃‍♀️帮大家解决👨‍🏫!
如果我的文章有帮助到您,欢迎点赞+关注✔️鼓励博主🏃,您的鼓励是我分享的动力🏃🏃🏃~
