【愚公系列】2022年06月 .NET架构班 083-微服务专题 Abp vNext基本CRUD实现
愚公搬代码 发表于 2022/06/30 20:22:40 2022/06/30
【摘要】 一、ABP 1.创建启动模板abp new Acme.BookStore -t app 2.创建Book实体在Acme.BookStore.Domain项目中创建一个 Books 文件夹(命名空间),并在其中添加名为 Book 的类,如下所示:public class Book : AuditedAggregateRoot<Guid>{ public string Name { ge...
一、ABP
1.创建启动模板
2.创建Book实体
    public string Name { get; set; }
    public BookType Type { get; set; }
    public DateTime PublishDate { get; set; }
    public float Price { get; set; }
3.BookType枚举
在Acme.BookStore.Domain.Shared项目中创建Books文件夹(命名空间),并在其中添加BookType:
public enum BookType
    Undefined,
    Adventure,
    Biography,
    Dystopia,
    Fantastic,
    Horror,
    Science,
    ScienceFiction,
    Poetry
4.将Book实体添加到DbContext中
EF Core需要你将实体和 DbContext 建立关联.最简单的做法是在Acme.BookStore.EntityFrameworkCore项目的BookStoreDbContext类中添加DbSet属性.如下所示:
5.将Book实体映射到数据库表
打开BookStoreDbContext类的OnModelCreating方法,为Book实体添加映射代码:
protected override void OnModelCreating(ModelBuilder builder)
        base.OnModelCreating(builder);
        /* Include modules to your migration db context */
        builder.ConfigurePermissionManagement();
        builder.ConfigureSettingManagement();
        builder.ConfigureBackgroundJobs();
        builder.ConfigureAuditLogging();
        builder.ConfigureIdentity();
        builder.ConfigureIdentityServer();
        builder.ConfigureFeatureManagement();
        builder.ConfigureTenantManagement();
        builder.Entity<Book>(b =>
            b.ToTable(BookStoreConsts.DbTablePrefix + "Books",
                BookStoreConsts.DbSchema);
            b.ConfigureByConvention(); //auto configure for the base class props
            b.Property(x => x.Name).IsRequired().HasMaxLength(128);
        /* Configure your own tables/entities inside here */
        //builder.Entity<YourEntity>(b =>
        //    b.ToTable(BookStoreConsts.DbTablePrefix + "YourEntities", BookStoreConsts.DbSchema);
        //    b.ConfigureByConvention(); //auto configure for the base class props
6.添加数据迁移
在 Acme.BookStore.EntityFrameworkCore 目录打开命令行终端输入以下命令:
dotnet ef migrations add Created_Book_Entity
7.添加种子数据
在 *.Domain 项目下创建BookStoreDataSeederContributor
public class BookStoreDataSeederContributor
        : IDataSeedContributor, ITransientDependency
        private readonly IRepository<Book, Guid> _bookRepository;
        public BookStoreDataSeederContributor(IRepository<Book, Guid> bookRepository)
            _bookRepository = bookRepository;
        public async Task SeedAsync(DataSeedContext context)
            if (await _bookRepository.GetCountAsync() <= 0)
                await _bookRepository.InsertAsync(
                    new Book
                        Name = "1984",
                        Type = BookType.Dystopia,
                        PublishDate = new DateTime(1949, 6, 8),
                        Price = 19.84f
                    autoSave: true
                    new Book
                        Name = "The Hitchhiker's Guide to the Galaxy",
                        Type = BookType.ScienceFiction,
                        PublishDate = new DateTime(1995, 9, 27),
                        Price = 42.0f
                    autoSave: true
8.更新数据库
运行 Acme.BookStore.DbMigrator 应用程序来更新数据库:
9.创建BookDto
在 Acme.BookStore.Application.Contracts 项目中创建 Books 文件夹(命名空间), 并在其中添加名为 BookDto 的DTO类:
public class BookDto : AuditedEntityDto<Guid>
在Acme.BookStore.Application项目的BookStoreApplicationAutoMapperProfile类中定义映射:
CreateMap<Book, BookDto>();
10.创建CreateUpdateBookDto
在Acme.BookStore.Application.Contracts项目中创建 Books 文件夹(命名空间),并在其中添加名为 CreateUpdateBookDto 的DTO类:
public class CreateUpdateBookDto
        [Required]
        [StringLength(128)]
        [Required]
        public BookType Type { get; set; } = BookType.Undefined;
        [Required]
        [DataType(DataType.Date)]
        public DateTime PublishDate { get; set; } = DateTime.Now;
        [Required]
CreateMap<CreateUpdateBookDto, Book>();
11.IBookAppService
在Acme.BookStore.Application.Contracts项目创建 Books 文件夹(命名空间),并在其中添加名为IBookAppService的接口:
public interface IBookAppService :
        ICrudAppService< //Defines CRUD methods
            BookDto, //Used to show books
            Guid, //Primary key of the book entity
            PagedAndSortedResultRequestDto, //Used for paging/sorting
            CreateUpdateBookDto> //Used to create/update a book
12.BookAppService
在Acme.BookStore.Application项目中创建 Books 文件夹(命名空间),并在其中添加名为 BookAppService 的类:
public class BookAppService :
        CrudAppService<
            Book, //The Book entity
            CreateUpdateBookDto>, //Used to create/update a book
        IBookAppService //implement the IBookAppService
        public BookAppService(IRepository<Book, Guid> repository)
            : base(repository)
13.运行程序
访问swagger文档:https://localhost:44350/swagger/index.html
