【愚公系列】2022年06月 .NET架构班 079-分布式中间件 ScheduleMaster的集群原理
愚公搬代码 发表于 2022/06/30 20:07:15 2022/06/30
【摘要】 一、ScheduleMaster的集群原理当worker1宕机,任务会自动切换到worker2上面运行,当worker2宕机,任务会自动切换到worker1上面运行,主要依靠什么什么做到的?核心:健康检测,故障转移1、进入到Hos.ScheduleMaster.Web项目中,找到SystemSchedulerRegistry类2、然后SystemSchedulerRegistry找到Wor...
2、然后SystemSchedulerRegistry找到WorkerCheckJob类
internal class WorkerCheckJob : IJob
        /// <summary>
        /// 执行计划
        /// </summary>
        public void Execute()
            using (var scope = ConfigurationCache.RootServiceProvider.CreateScope())
                Core.Interface.INodeService service = scope.ServiceProvider.GetService<Core.Interface.INodeService>();
                AutowiredServiceProvider provider = new AutowiredServiceProvider();
                provider.PropertyActivate(service, scope.ServiceProvider);
                service.WorkerHealthCheck();
3、然后在WorkerCheckJob类中找到NodeService,进入到Hos.ScheduleMaster.Core项目
4、然后进入到NodeService类中,找到WorkerHealthCheck方法
/// <summary>
        /// worker健康检查
        /// </summary>
        public void WorkerHealthCheck()
            var workers = _repositoryFactory.ServerNodes.Where(x => x.NodeType == "worker" && x.Status != 0).ToList();
            if (!workers.Any())
                return;
            //允许最大失败次数
            int allowMaxFailed = ConfigurationCache.GetField<int>("System_WorkerUnHealthTimes");
            if (allowMaxFailed <= 0) allowMaxFailed = 3;
            //遍历处理
            workers.ForEach(async (w) =>
                using (var scope = new Core.ScopeDbContext())
                    var db = scope.GetDbContext();
                    _serverClient.Server = w;
                    //初始化计数器
                    ConfigurationCache.WorkerUnHealthCounter.TryAdd(w.NodeName, 0);
                    var success = await _serverClient.HealthCheck();
                    if (success)
                        w.LastUpdateTime = DateTime.Now;
                        db.ServerNodes.Update(w);
                        await db.SaveChangesAsync();
                        ConfigurationCache.WorkerUnHealthCounter[w.NodeName] = 0;
                    else
                        //获取已失败次数
                        int failedCount = ConfigurationCache.WorkerUnHealthCounter[w.NodeName];
                        System.Threading.Interlocked.Increment(ref failedCount);
                        if (failedCount >= allowMaxFailed)
                            w.Status = 0;//标记下线,实际上可能存在因为网络抖动等原因导致检查失败但worker进程还在运行的情况
                            //释放该节点占据的锁
                            var locks = db.ScheduleLocks.Where(x => x.LockedNode == w.NodeName && x.Status == 1).ToList();
                            locks.ForEach(x =>
                                x.Status = 0;
                                x.LockedNode = null;
                                x.LockedTime = null;
                            db.ScheduleLocks.UpdateRange(locks);
                            //重置计数器
                        else
                            ConfigurationCache.WorkerUnHealthCounter[w.NodeName] = failedCount;
5、然后在WorkerHealthCheck方法中,找到ServerClient类
6、然后在ServerClient类中,找到HealthCheck方法
public async Task<bool> HealthCheck()
            HttpClient client = CreateClient();
            try
                var response = await client.GetAsync("/health");
                return await ClientResponse(response);
            catch (Exception ex)
                Log.LogHelper.Warn($"请求地址:{client.BaseAddress.ToString()}/health,响应消息:{(ex.InnerException ?? ex).Message}");
                return false;
7、在Hos.ScheduleMaster.QuartzHost项目中,找到Startup类
然后在Startup类中,进入ConfigureServices方法中,找到AddHealthChecks方法
然后在Startup类中,进入Configure方法中,找到MapHealthChecks方法
