大数据物流项目:主题及指标开发之即席查询引擎Impala(分布式内存计算)(十一.五)
Maynor学长 发表于 2022/06/29 20:38:39 2022/06/29
【摘要】 09-[掌握]-即席查询之Impala 服务启动及CLI使用物流项目中,Impala分析引擎使用CM进行安装(impala就是Cloudera开源框架),注意事项:1)、安装目录:/opt/cloudera/parcels/CDH/lib/impala2)、配置文件:/etc/impala/conf/3)、日志文件:/val/log启动Imapla服务,按照如下步骤:step1、启动HDF...
  • 1)、安装目录:/opt/cloudera/parcels/CDH/lib/impala
1616317495651
  • 2)、配置文件:/etc/impala/conf/
  • 3)、日志文件:/val/log
1616317631524
启动Imapla服务,按照如下步骤:
  • step1、启动HDFS分布式系统,实际项目中HDFS肯定HA高可用集群
1616317755659
  • step2、启动Hive MetaStore服务
1616317809588
  • step3、启动Impala框架服务
    • Impalad服务、State Stored服务和Catalogd服务
1616317916872
当上述所有服务启动完成以后,可以打开Impala框架中各个服务提供WEB UI界面
1616318015768
1616318058805
Impala分析引擎提供客户端给用户,方便编写SQL语句,进行查询分析数据
1613899685230
impala提供命令行:impala-shell
1616318298756
[root@node2 ~]# impala-shell --help
Usage: impala_shell.py [options]
Options:
  -h, --help            show this help message and exit
  -i IMPALAD, --impalad=IMPALAD
                        <host:port> of impalad to connect to
                        [default: node2.itcast.cn:21000]
  -b KERBEROS_HOST_FQDN, --kerberos_host_fqdn=KERBEROS_HOST_FQDN
                        If set, overrides the expected hostname of the
                        Impalad's kerberos service principal. impala-shell
                        will check that the server's principal matches this
                        hostname. This may be used when impalad is configured
                        to be accessed via a load-balancer, but it is desired
                        for impala-shell to talk to a specific impalad
                        directly. [default: none]
  -q QUERY, --query=QUERY
                        Execute a query without the shell [default: none]
  -f QUERY_FILE, --query_file=QUERY_FILE
                        Execute the queries in the query file, delimited by ;.
                        If the argument to -f is "-", then queries are read
                        from stdin and terminated with ctrl-d. [default: none]
  -k, --kerberos        Connect to a kerberized impalad [default: False]
  -o OUTPUT_FILE, --output_file=OUTPUT_FILE
                        If set, query results are written to the given file.
                        Results from multiple semicolon-terminated queries
                        will be appended to the same file [default: none]
  -B, --delimited       Output rows in delimited mode [default: False]
  --print_header        Print column names in delimited mode when pretty-
                        printed. [default: False]
  --output_delimiter=OUTPUT_DELIMITER
                        Field delimiter to use for output in delimited mode
                        [default: \t]
  -s KERBEROS_SERVICE_NAME, --kerberos_service_name=KERBEROS_SERVICE_NAME
                        Service name of a kerberized impalad [default: impala]
  -V, --verbose         Verbose output [default: True]
  -p, --show_profiles   Always display query profiles after execution
                        [default: False]
  --quiet               Disable verbose output [default: False]
  -v, --version         Print version information [default: False]
  -c, --ignore_query_failure
                        Continue on query failure [default: False]
  -d DEFAULT_DB, --database=DEFAULT_DB
                        Issues a use database command on startup
                        [default: none]
  -l, --ldap            Use LDAP to authenticate with Impala. Impala must be
                        configured to allow LDAP authentication.
                        [default: False]
  -u USER, --user=USER  User to authenticate with. [default: root]
  --ssl                 Connect to Impala via SSL-secured connection
                        [default: False]
  --ca_cert=CA_CERT     Full path to certificate file used to authenticate
                        Impala's SSL certificate. May either be a copy of
                        Impala's certificate (for self-signed certs) or the
                        certificate of a trusted third-party CA. If not set,
                        but SSL is enabled, the shell will NOT verify Impala's
                        server certificate [default: none]
  --config_file=CONFIG_FILE
                        Specify the configuration file to load options. The
                        following sections are used: [impala],
                        [impala.query_options]. Section names are case
                        sensitive. Specifying this option within a config file
                        will have no effect. Only specify this as an option in
                        the commandline. [default: /root/.impalarc]
  --history_file=HISTORY_FILE
                        The file in which to store shell history. This may
                        also be configured using the IMPALA_HISTFILE
                        environment variable. [default: ~/.impalahistory]
  --live_summary        Print a query summary every 1s while the query is
                        running. [default: False]
  --live_progress       Print a query progress every 1s while the query is
  --auth_creds_ok_in_clear
                        If set, LDAP authentication may be used with an
                        insecure connection to Impala. WARNING: Authentication
                        credentials will therefore be sent unencrypted, and
                        may be vulnerable to attack. [default: none]
  --ldap_password_cmd=LDAP_PASSWORD_CMD
                        Shell command to run to retrieve the LDAP password
                        [default: none]
  --var=KEYVAL          Defines a variable to be used within the Impala
                        session. Can be used multiple times to set different
                        variables. It must follow the pattern "KEY=VALUE", KEY
                        starts with an alphabetic character and contains
                        alphanumeric characters or underscores. [default:
                        none]
  -Q QUERY_OPTIONS, --query_option=QUERY_OPTIONS
                        Sets the default for a query option. Can be used
                        multiple times to set different query options. It must
                        follow the pattern "KEY=VALUE", KEY must be a valid
                        query option. Valid query options  can be listed by
                        command 'set'. [default: none]
  -t CLIENT_CONNECT_TIMEOUT_MS, --client_connect_timeout_ms=CLIENT_CONNECT_TIMEOUT_MS
                        Timeout in milliseconds after which impala-shell will
                        time out if it fails to connect to Impala server. Set
                        to 0 to disable any timeout. [default: 60000]
发现impala-shell命令行执行python脚本:
[root@node2 ~]# impala-shell -i node2.itcast.cn:21000
Starting Impala Shell without Kerberos authentication
Opened TCP connection to node2.itcast.cn:21000
Connected to node2.itcast.cn:21000
Server version: impalad version 3.2.0-cdh6.2.1 RELEASE (build 525e372410dd2ce206e2ad0f21f57cae7380c0cb)
Welcome to the Impala shell.
(Impala Shell v3.2.0-cdh6.2.1 (525e372) built on Wed Sep 11 01:30:44 PDT 2019)
You can change the Impala daemon that you're connected to by using the CONNECT
command.To see how Impala will plan to run your query without actually executing
it, use the EXPLAIN command. You can change the level of detail in the EXPLAIN
output by setting the EXPLAIN_LEVEL query option.
[node2.itcast.cn:21000] default> show databases ;
Query: show databases
| name             | comment                                      |
| _impala_builtins | System database for Impala builtin functions |
| default          | Default Hive database                        |
| logistics        | ???????                                      |
Fetched 3 row(s) in 0.52s
[node2.itcast.cn:21000] default> use logistics ;
Query: use logistics
[node2.itcast.cn:21000] logistics>
[node2.itcast.cn:21000] logistics> show tables ;
Query: show tables
| name                           |
| tbl_address                    |
| tbl_areas                      |
| tbl_charge_standard            |
| tbl_codes                      |
| tbl_collect_package            |
| tbl_company                    |
| tbl_company_dot_map            |
| tbl_company_transport_route_ma |
| tbl_company_warehouse_map      |
| tbl_consumer_address_map       |
| tbl_consumer_sender_info       |
| tbl_courier                    |
| tbl_customer                   |
| tbl_customer_detail            |
| tbl_deliver_package            |
| tbl_deliver_region             |
| tbl_delivery_record            |
| tbl_department                 |
| tbl_dot                        |
| tbl_dot_transport_tool         |
| tbl_dot_transport_tool_detail  |
| tbl_driver                     |
| tbl_emp                        |
| tbl_emp_info_map               |
| tbl_example1                   |
| tbl_express_bill               |
| tbl_express_bill_detail        |
| tbl_express_package            |
| tbl_fixed_area                 |
| tbl_goods_rack                 |
| tbl_job                        |
| tbl_out_warehouse              |
| tbl_out_warehouse_detail       |
| tbl_pkg                        |
| tbl_postal_standard            |
| tbl_push_warehouse             |
| tbl_push_warehouse_detail      |
| tbl_route                      |
| tbl_service_evaluation         |
| tbl_store_grid                 |
| tbl_transport_tool             |
| tbl_vehicle_monitor            |
| tbl_warehouse                  |
| tbl_warehouse_emp              |
| tbl_warehouse_rack_map         |
| tbl_warehouse_receipt          |
| tbl_warehouse_receipt_detail   |
| tbl_warehouse_send_vehicle     |
| tbl_warehouse_transport_detail |
| tbl_warehouse_transport_tool   |
| tbl_warehouse_vehicle_map      |
| tbl_waybill                    |
| tbl_waybill_detail             |
| tbl_waybill_line               |
| tbl_waybill_state_record       |
| tbl_work_time                  |
| test                           |
Fetched 57 row(s) in 0.03s
[node2.itcast.cn:21000] logistics> select * from tbl_express_bill limit 10 ;
Query: select * from tbl_express_bill limit 10
Query submitted at: 2021-03-21 17:21:28 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=ed4ee096548edaa5:6380ed8300000000
10-[理解]-即席查询之使用Impala操作Kudu
Impala与Kudu集成,集成时,需要注意:启动相关服务组件和在Impala中创建表映射到Kudu表中。
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-c4iljpwb-1641192152644)(/img/1616318681670.png)]
首先使用impala-shell连接impalad服务,创建数据库:
The '-B' command line flag turns off pretty-printing for query results. Use this
flag to remove formatting from results you want to save for later, or to benchmark
Impala.
[node2.itcast.cn:21000] default> create database db_kudu ;
Query: create database db_kudu
| summary                    |
| Database has been created. |
Fetched 1 row(s) in 2.60s
[node2.itcast.cn:21000] default> use db_kudu ;
Query: use db_kudu
[node2.itcast.cn:21000] db_kudu>
接下来,Impala与Kudu表集成:
  • 1)、方式一、管理表集成
    • 相当Hive中管理表,删除表时,元数据和数据都被删除
    • impala中表删除,kudu中对应表也被删除
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-mvRHbLTa-1641192152645)(img/1613900209137.png)]
[node2.itcast.cn:21000] db_kudu> CREATE TABLE `my_first_table`
                               > id BIGINT,
                               > name STRING,
                               > PRIMARY KEY(id)
                               > PARTITION BY HASH PARTITIONS 16
                               > STORED AS KUDU
                               > TBLPROPERTIES (
                               > 'kudu.num_tablet_replicas' = '1'
Query: CREATE TABLE `my_first_table`
id BIGINT,
name STRING,
PRIMARY KEY(id)
STORED AS KUDU
TBLPROPERTIES (
| summary                 |
| Table has been created. |
Fetched 1 row(s) in 5.73s
[node2.itcast.cn:21000] db_kudu> show tables ;
Query: show tables
| name           |
| my_first_table |
Fetched 1 row(s) in 0.04s
[node2.itcast.cn:21000] db_kudu> drop table if exists my_first_table;
Query: drop table if exists my_first_table
| summary                 |
| Table has been dropped. |
Fetched 1 row(s) in 7.10s
Query: show tables
Fetched 0 row(s) in 0.07s
  • 2)、方式二、外部表集成
    • 相当Hive中外部表,删除表示,仅仅删除元数据
    • impala中表删除,kudu中表没有被删除
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-oyZxEt1E-1641192152645)(img/1613900499712.png)]
[node2.itcast.cn:21000] db_kudu> CREATE EXTERNAL TABLE `tbl_emp` STORED AS KUDU
                               > TBLPROPERTIES(
                               >     'kudu.table_name' = 'tbl_emp',
                               >     'kudu.master_addresses' = 'node2.itcast.cn:7051') ;
Query: CREATE EXTERNAL TABLE `tbl_emp` STORED AS KUDU
TBLPROPERTIES(
| summary                 |
Fetched 1 row(s) in 0.55s
Query: show tables
| name    |
| tbl_emp |
Fetched 1 row(s) in 0.01s
[node2.itcast.cn:21000] db_kudu> select * from tbl_emp limit 10 ;
Query: select * from tbl_emp limit 10
Query submitted at: 2021-03-21 17:31:49 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=bc42a1cbb7be5cb6:aeee39e400000000
| id | cdt                 | empbirathday        | empgender | empname | empnumber | remark | state | udt                 |
| 1  | 2016-03-11 03:07:36 | 1975-03-30 04:48:53 | 1         | 肥项禹  | 98537     | NULL   | 1     | 2016-03-11 03:07:37 |
| 8  | 2016-03-11 03:07:36 | 2006-03-12 06:38:08 | 1         | 昔又香  | 87686     | NULL   | 1     | 2016-03-11 03:07:37 |
| 10 | 2016-03-11 03:07:36 | 2004-11-11 15:00:22 | 1         | 哀以松  | 18487     | NULL   | 1     | 2016-03-11 03:07:37 |
| 11 | 2016-03-11 03:07:36 | 2009-06-22 08:07:23 | 1         | 聊浦和  | 24470     | NULL   | 1     | 2016-03-11 03:07:37 |
| 14 | 2016-03-11 03:07:36 | 2020-01-15 06:42:09 | 1         | 洋冬萱  | 25579     | NULL   | 1     | 2016-03-11 03:07:37 |
| 16 | 2016-03-11 03:07:36 | 2001-04-08 00:53:17 | 1         | 席慧云  | 64030     | NULL   | 1     | 2016-03-11 03:07:37 |
| 17 | 2016-03-11 03:07:36 | 2017-09-19 19:59:52 | 1         | 干月灵  | 46621     | NULL   | 1     | 2016-03-11 03:07:37 |
| 19 | 2016-03-11 03:07:36 | 2010-12-21 16:35:40 | 1         | 钮幻桃  | 35884     | NULL   | 1     | 2016-03-11 03:07:37 |
| 27 | 2016-03-11 03:07:36 | 2008-12-06 02:37:57 | 1         | 才雪容  | 76262     | NULL   | 1     | 2016-03-11 03:07:37 |
| 29 | 2016-03-11 03:07:36 | 2009-12-27 04:27:34 | 1         | 禹涵桃  | 63525     | NULL   | 1     | 2016-03-11 03:07:37 |
Fetched 10 row(s) in 26.04s
[node2.itcast.cn:21000] db_kudu> drop table tbl_emp ;
Query: drop table tbl_emp
| summary                 |
Fetched 1 row(s) in 7.22s
Query: show tables
Fetched 0 row(s) in 0.02s
经过测试发现,当impala与kudu集成时,建议使用外部表方式,当删除impla中表数据,kudu表没有删除。
Impala DML操作,包含数据插入、数据更新和数据删除以及数据查询分析。
id BIGINT,
name STRING,
PRIMARY KEY(id)
STORED AS KUDU
TBLPROPERTIES (
INSERT INTO my_first_table VALUES (50, "zhangsan");
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-5HlXBUyT-1641192152646)(/img/1616319412797.png)]
[node2.itcast.cn:21000] db_kudu> INSERT INTO my_first_table VALUES (1, "john"), (2, "jane"), (3, "jim");
Query: INSERT INTO my_first_table VALUES (1, "john"), (2, "jane"), (3, "jim")
Query submitted at: 2021-03-21 17:37:07 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=974337f26ef055a2:3509d1b900000000
Modified 3 row(s), 0 row error(s) in 0.26s
[node2.itcast.cn:21000] db_kudu> select * from my_first_table ;
Query: select * from my_first_table
Query submitted at: 2021-03-21 17:37:09 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=6a4608a12ee92237:9110732f00000000
| id | name     |
| 50 | zhangsan |
| 2  | jane     |
| 3  | jim      |
| 1  | john     |
Fetched 4 row(s) in 0.27s
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-etuNkpLa-1641192152646)(/img/1616319469934.png)]
Impala与Kudu集成时,插入数据方式:
1、insert单条记录
2、insert多条记录
3、子查询插入
更新数据:update语句
[node2.itcast.cn:21000] db_kudu> UPDATE my_first_table SET name="xiaowang" where id =1 ;
Query: UPDATE my_first_table SET name="xiaowang" where id =1
Query submitted at: 2021-03-21 17:38:11 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=314c908c835d71e3:bb0e700c00000000
Modified 1 row(s), 0 row error(s) in 0.53s
Query submitted at: 2021-03-21 17:38:14 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=c949987ff8a003f6:db504d1a00000000
| id | name     |
| 50 | zhangsan |
| 2  | jane     |
| 3  | jim      |
| 1  | xiaowang |
Fetched 4 row(s) in 0.15s
删除数据:delete语句
[node2.itcast.cn:21000] db_kudu> delete from my_first_table where id =2;
Query: delete from my_first_table where id =2
Query submitted at: 2021-03-21 17:39:35 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=5b48f7834e5ca05c:72db5f8f00000000
Modified 1 row(s), 0 row error(s) in 0.42s
Query submitted at: 2021-03-21 17:39:37 (Coordinator: http://node2.itcast.cn:25000)
Query progress can be monitored at: http://node2.itcast.cn:25000/query_plan?query_id=d04152da32a15d13:3397d4fa00000000
| id | name     |
| 50 | zhangsan |
| 3  | jim      |
| 1  | xiaowang |
Fetched 3 row(s) in 0.13s
11-[理解]-即席查询之Hue集成Impala
Hue与Impala集成,为客户提供可视化WEB UI界面,编写SQL语句分析数据,企业中常用方式。
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-V7sBIkhK-1641192152646)(/img/1616319782217.png)]
Hue安装采用CM进行安装,Hue框架也是Cloudera公司开源,页面启动Hue服务。
==Hue安装就可以配置与impala集成,以及其他框架集成,启动时比较慢。==
CDH 6.2.1版本中,Hue服务启动2个服务:HueServer、LoadBalancer
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-NxPnXZTx-1641192152646)(/img/1616319892724.png)]
当Hue服务启动以后,可以访问地址:http://node2.itcast.cn:8888/、http://node2.itcast.cn:8889/,admin/admin
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-5ZCrkoZr-1641192152647)(/img/1616320101950.png)]
登录进入Hue界面以后,可以选择底层分析引擎:要么是impala(内存)、要么是hive
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-EmzyDVod-1641192152647)(/img/1616320741553.png)]
当选择impala引擎以后:
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-oNds4HCY-1641192152647)(/img/1616320830250.png)]
点击查询按钮【向右箭头】即可。
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-RBtHDc9z-1641192152648)(/img/1616320928054.png)]
可以对编写SQL查给一个名称和描述,下次可以直接 运行SQL即可。
Hue配置与大数据框架集成时,页面地址:http://node2.itcast.cn:7180/cmf/services/29/config
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-rqQkhYS8-1641192152648)(/img/1616321021806.png)]
12-[理解]-即席查询之JDBC Client 连接
使用Impala分析数据时,可以使用如下三种方式:Hue界面、impala-shell命令行和JDBC/ODBC连接(BI工具)
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-z3KzOmOt-1641192152648)(/img/1614041952644.png)]
可以通过JDBC方式连接Impalad服务,端口号:21050
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-BG45m2Ay-1641192152648)(/img/1616376602336.png)]
使用数据库Client工具:DBeave连接Impala,需要JDBC驱动:
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-2ceFtPEG-1641192152649)(/img/1616376670241.png)]
在DBeave中创建Impala连接:
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-tYZNfSz8-1641192152649)(/img/1616376773788.png)]
使用DBeave连接Impalad服务以后,进行查询分析数据
[外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传(img-6KcPlDMb-1641192152649)(/img/1616376882974.png)]
