[Android] Notification和广播的简单使用
开心星人 发表于 2022/06/29 17:19:38 2022/06/29
【摘要】 @toc 🌳效果展示点击发送广播,会弹出通知点击清除通知图标会删除通知 🌳分析动态注册广播接收器 MyReceiver myReceiver=new MyReceiver(); IntentFilter intentFilter=new IntentFilter(); intentFilter.addAction("cn.edu.henu.sendMessage"); //这个Acti...
@toc
🌳效果展示
点击发送广播,会弹出通知
点击清除通知图标会删除通知
🌳分析
动态注册广播接收器
 //这个Action自己选择一个字符串,最好带上包名,不容易重复
 registerReceiver(myReceiver,intentFilter);
intent发送广播
Intent intent=new Intent("cn.edu.henu.sendMessage");
//这里的action要和注册广播接收器那里的action一致
intent.putExtra("info","动态注册");
sendBroadcast(intent);
广播接收器接收到广播后,自动调用MyReceiver的OnReceive方法
在该方法中写弹出通知的逻辑代码
//        创建NotificationManager
        NotificationManager manager = (NotificationManager) context.getSystemService(Context.NOTIFICATION_SERVICE);
        String channelID = "my_channel_ID";
        String channelNAME = "my_channel_NAME";
        int level = NotificationManager.IMPORTANCE_HIGH;
//            8.0以上必须先创建通道
        if (android.os.Build.VERSION.SDK_INT >= android.os.Build.VERSION_CODES.O) {
            NotificationChannel channel = new NotificationChannel(channelID, channelNAME, level);
            manager.createNotificationChannel(channel);
        NotificationCompat.Builder builder =
                new NotificationCompat.Builder(context, channelID)
                        .setSmallIcon(R.drawable.ic_launcher_foreground)
                        .setContentTitle("Notification")
                        .setContentText("我是通知")
                        .setPriority(NotificationCompat.PRIORITY_HIGH)
                        .setCategory(NotificationCompat.CATEGORY_CALL)
                        .setAutoCancel(true);
        manager.notify(101, builder.build());
删除通知
NotificationManager notificationManager = (NotificationManager)getSystemService(Context.NOTIFICATION_SERVICE);
notificationManager.cancel(101);
//注意上面notify的时候id也是101
🌳全部代码
MainActivity.java
public class MainActivity extends AppCompatActivity {
    private Button send;
    private Button clear;
    public Context context;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        send=findViewById(R.id.send);
        send.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View view) {
        clear=findViewById(R.id.clear);
        clear.setOnClickListener(new View.OnClickListener() {
            @Override
MyReceiver.java
public class MyReceiver extends BroadcastReceiver {
    private static final String TAG = "MyReceiver";
    @Override
    public void onReceive(Context context, Intent intent) {
        String msg=intent.getStringExtra("info");
        Toast.makeText(context,msg,Toast.LENGTH_LONG).show();
//            8.0以上必须先创建通道
                        .setContentText("2012080097_张开斌")
activity_main.xml
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context=".MainActivity"
    android:orientation="vertical">
   <Button
       android:id="@+id/send"
       android:layout_width="wrap_content"
       android:layout_height="wrap_content"
       android:text="发送广播消息"
    <Button
        android:id="@+id/clear"
        android:text="清除通知图标"
        android:layout_height="wrap_content"/>
</LinearLayout>
