The project uses Gradle 4.4 which is incompatible with Java 11 o
振华OPPO 发表于 2022/06/29 16:09:59 2022/06/29
【摘要】 报错信息Unable to start the daemon process.The project uses Gradle 4.4 which is incompatible with Java 11 or newer.Possible solution: - Upgrade Gradle wrapper to 4.8 version and re-import the project解决...
报错信息
Possible solution:
解决方法
File——>Settings,到Gradle配置界面,可以看到默认使用的是AS自带的JDK11。
修改为电脑安装的JDK1.8,然后Apply——>OK,重新同步项目即可。
