Echsop后台修改
黄啊码 发表于 2022/06/29 01:18:03 2022/06/29
【摘要】 ECShop是一款B2C独立网店系统,适合企业及个人快速构建个性化网上商店。系统开源但不免费,是基于PHP语言及MYSQL数据库构架开发的跨平台开源程序。目前最新版本为2.7.3 0708版。 1、首先,去掉TITLE中的“Powered by ECShop” (请注意,请勿用记事本编辑程序,可推荐使用EDITPLUS,小巧好用!) ...
打开文件:includes/lib_main.php
查找:$page_title = $GLOBALS[’_CFG’][’shop_title’] . ‘ - ‘ . ‘Powered by ECShop’;
将其改为
$page_title = $GLOBALS[’_CFG’][’shop_title’];
3、修改文件代码头部的Generator标记,可防止其他程序识别为ECSHOP
<meta name="Generator" content="ECSHOP v2.7.3" />
修改文件:includes/cls_ecshop.php
查找:
define('APPNAME', 'ECSHOP');
修改为:
define('APPNAME', '自定义的网站代号');
4、修改文件:js/common.js
查找:onload = function() 代码段,以下全部删除
onload = function()
 var link_arr = document.getElementsByTagName(String.fromCharCode(65));
 var link_str;
 var link_text;
 var regg, cc;
 var rmd, rmd_s, rmd_e, link_eorr = 0;
 var e = new Array(97, 98, 99,
 100, 101, 102, 103, 104, 105, 106, 107, 108, 109,
 110, 111, 112, 113, 114, 115, 116, 117, 118, 119,
 120, 121, 122
 try
 for(var i = 0; i < link_arr.length; i++)
 link_str = link_arr[i].href;
 if (link_str.indexOf(String.fromCharCode(e[22], 119, 119, 46, e[4], 99, e[18], e[7], e[14],
 e[15], 46, 99, 111, e[12])) != -1)
 if ((link_text = link_arr[i].innerText) == undefined)
 throw "noIE";
 regg = new RegExp(String.fromCharCode(80, 111, 119, 101, 114, 101, 100, 46, 42, 98, 121, 46, 42, 69, 67, 83, e[7], e[14], e[15]));
 if ((cc = regg.exec(link_text)) != null)
 if (link_arr[i].offsetHeight == 0)
 break;
 link_eorr = 1;
 break;
 else
 link_eorr = link_eorr ? 0 : link_eorr;
 continue;
 } // IE
 catch(exc)
 if (link_str.indexOf(String.fromCharCode(e[22], 119, 119, 46, e[4], 99, 115, 104, e[14],
 link_text = link_arr[i].textContent;
 break;
 link_eorr = 1;
 break;
 else
 continue;
 } // FF
 try
 rmd = Math.random();
 rmd_s = Math.floor(rmd * 10);
 if (link_eorr != 1)
 rmd_e = i - rmd_s;
 link_arr[rmd_e].href = String.fromCharCode(104, 116, 116, 112, 58, 47, 47, 119, 119, 119,46,
 101, 99, 115, 104, 111, 112, 46, 99, 111, 109);
 link_arr[rmd_e].innerHTML = String.fromCharCode(
 80, 111, 119, 101, 114, 101, 100,38, 110, 98, 115, 112, 59, 98,
 121,38, 110, 98, 115, 112, 59,60, 115, 116, 114, 111, 110, 103,
 62, 60,115, 112, 97, 110, 32, 115, 116, 121,108,101, 61, 34, 99,
 111, 108, 111, 114, 58, 32, 35, 51, 51, 54, 54, 70, 70, 34, 62,
 69, 67, 83, 104, 111, 112, 60, 47, 115, 112, 97, 110, 62,60, 47,
 115, 116, 114, 111, 110, 103, 62);
 catch(ex)
(2)去掉ECSHOP官方的后门检测程序。代码
1、修改文件:admin/shop_config.php
查找:$spt .= '"></script>';
在之后添加一行:
$spt = '';或者直接注释掉;
2、修改文件:admin/templates/index.htm
查找:
 <frameset rows="0, 0" framespacing="0" border="0">
 <frame src="http://api.ecshop.com/record.php?mod=login&url={$shop_url}" id="hidd-frame" name="hidd-frame" frameborder="no" scrolling="no">
 </frameset>
删除或注释
3、在MYSQL数据库的数据表:shop_config中查找字段code值为 certi 的记录,其值为:http://service.shopex.cn/openapi/api.php ,修改为一个错误的网址!
如:http://service.wmphp.com/openapi/api.php
4、修改文件:admin/templates/top.htm
查找:
Ajax.call('index.php?is_ajax=1&act=license','', start_sendmail_Response, 'GET', 'JSON');
注释或删除掉
5、修改文件:admin/templates/menu.htm
查找:
<script language="JavaScript" src="http://api.ecshop.com/menu_ext.php?charset={$charset}&lang={$help_lang}"></script>
注释或删除掉
6、修改文件:admin/templates/start.htm
查找:
<ul style="padding:0; margin: 0; list-style-type:none; color: #CC0000;">
 <!-- <script type="text/javascript" src="http://bbs.ecshop.com/notice.php?v=1&n=8&f=ul"></script>-->
</ul>
注释或删除掉
7、修改文件:admin/index.php
查找:
 $t = new transport;
 $api_comment = $t->request('http://api.ecshop.com/checkver.php', $apiget);
 $api_str = $api_comment["body"];
 echo $api_str;
注释或删除掉
8、删除后台所有默认的友情链接以及默认LOGO
9、修改后台管理中相关文字
打开language/zh_cn/admin/common.php
$_LANG['cp_home'] = 'ECSHOP 管理中心';
$_LANG['copyright'] = '版权所有 © 2005-2009 上海商派网络科技有限公司,并保留所有权利。';
其他后门修改,如下所示:
1、删除【云服务中心】
删除/admin/cloud.php
删除/languages/zh_cn/admin/cloud.php
/admin/templates/menu.htm中删除以下代码
Ajax.call('cloud.php?is_ajax=1&act=menu_api','', start_menu_api, 'GET', 'JSON');
删除/admin/templates/start.htm中以下代码
Ajax.call('cloud.php?is_ajax=1>act=cloud_remind','', cloud_api, 'GET', 'JSON');
function cloud_close(id)
Ajax.call('cloud.php?is_ajax=1>act=close_remind>remind_id='+id,'', cloud_api, 'GET', 'JSON');
注:有关cloud.php语句删除
2、删除【数据库管理】-【转换数据】
删除/admin/convert.php
删除/admin/templates/convert_main.htm
删除/languages/zh_cn/convert目录及目录下的所有文件
删除/languages/zh_cn/admin/convert.php
/admin/includes/inc_menu.php中删除以下代码
$modules['13_backup']['convert'] = 'convert.php?act=main';
/admin/includes/inc_priv.php中删除以下代码
$purview['convert'] = 'convert';
/languages/zh_cn/admin/priv_action.php中删除以下代码
$_LANG['convert'] = '转换数据';
3、删除【系统设置】-【授权证书】
删除/admin/license.php
删除admin/templates/license.htm
删除/admin/includes/inc_menu.php中以下代码
$modules['11_system']['shop_authorized'] = 'license.php?act=list_edit';
删除/languages/zh_cn/admin/priv_action.php中以下代码
$_LANG['shop_authorized'] = '授权证书';
4、删除后台右上角【帮助】和【关于ECSHOP】
删除/admin/templates/top.htm中以下代码
<li><a href="/knowledge/used.html?act=about_us" target="main-frame">{$lang.about}</a></li>
<li><a href="javascript:web_address();">{$lang.help}</a></li>
END,完成所有修改。
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/52857243
