phpexcel乱码解决
黄啊码 发表于 2022/06/28 23:52:40 2022/06/28
【摘要】 <?php include 'global.php'; $ids = $_GET['ids']; $sql = "select * from crm_cost_end where id in ( {$ids} )"; $result = $db->findAll($sql); //echo $result[1]['sn']...
<?php
//echo $result[1]['sn'];
//创建一个excel对象
$objPHPExcel = new PHPExcel();
// Set properties
$objPHPExcel->getProperties()->setCreator("ctos")
        ->setLastModifiedBy("ctos")
        ->setTitle("Office 2007 XLSX Test Document")
        ->setSubject("Office 2007 XLSX Test Document")
        ->setDescription("Test document for Office 2007 XLSX, generated using PHP classes.")
        ->setKeywords("office 2007 openxml php")
        ->setCategory("Test result file");
//set width
$objPHPExcel->getActiveSheet()->getColumnDimension('A')->setWidth(8);
$objPHPExcel->getActiveSheet()->getColumnDimension('B')->setWidth(10);
$objPHPExcel->getActiveSheet()->getColumnDimension('C')->setWidth(25);
$objPHPExcel->getActiveSheet()->getColumnDimension('D')->setWidth(12);
$objPHPExcel->getActiveSheet()->getColumnDimension('E')->setWidth(50);
$objPHPExcel->getActiveSheet()->getColumnDimension('F')->setWidth(10);
$objPHPExcel->getActiveSheet()->getColumnDimension('G')->setWidth(12);
$objPHPExcel->getActiveSheet()->getColumnDimension('H')->setWidth(12);
$objPHPExcel->getActiveSheet()->getColumnDimension('I')->setWidth(12);
$objPHPExcel->getActiveSheet()->getColumnDimension('J')->setWidth(30);
//设置行高度
$objPHPExcel->getActiveSheet()->getRowDimension('1')->setRowHeight(22);
$objPHPExcel->getActiveSheet()->getRowDimension('2')->setRowHeight(20);
//set font size bold
$objPHPExcel->getActiveSheet()->getDefaultStyle()->getFont()->setSize(10);
$objPHPExcel->getActiveSheet()->getStyle('A2:J2')->getFont()->setBold(true);
$objPHPExcel->getActiveSheet()->getStyle('A2:J2')->getAlignment()->setVertical(PHPExcel_Style_Alignment::VERTICAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('A2:J2')->getBorders()->getAllBorders()->setBorderStyle(PHPExcel_Style_Border::BORDER_THIN);
//设置水平居中
$objPHPExcel->getActiveSheet()->getStyle('A1')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_LEFT);
$objPHPExcel->getActiveSheet()->getStyle('A')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('B')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('D')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('F')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('G')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('H')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->getStyle('I')->getAlignment()->setHorizontal(PHPExcel_Style_Alignment::HORIZONTAL_CENTER);
$objPHPExcel->getActiveSheet()->mergeCells('A1:J1');
// set table header content
$objPHPExcel->setActiveSheetIndex(0)
        ->setCellValue('A1', '订单数据汇总  时间:' . date('Y-m-d H:i:s'))
        ->setCellValue('A2', '订单ID')
        ->setCellValue('B2', '下单人')
        ->setCellValue('C2', '客户名称')
        ->setCellValue('D2', '下单时间')
        ->setCellValue('E2', '需求机型')
        ->setCellValue('F2', '需求数量')
        ->setCellValue('G2', '需求交期')
        ->setCellValue('H2', '确认BOM料号')
        ->setCellValue('I2', 'PMC确认交期')
        ->setCellValue('J2', 'PMC交货备注');
// Miscellaneous glyphs, UTF-8
for ($i = 0; $i < count($result) - 1; $i++) {
    $objPHPExcel->getActiveSheet(0)->setCellValue('A' . ($i + 3), $result[$i]['id']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('B' . ($i + 3), $result[$i]['realname']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('C' . ($i + 3), $result[$i]['customer_name']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('D' . ($i + 3), $OrdersData[$i]['create_time']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('E' . ($i + 3), $result[$i]['require_product']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('F' . ($i + 3), $result[$i]['require_count']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('G' . ($i + 3), $result[$i]['require_time']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('H' . ($i + 3), $result[$i]['product_bom_encoding']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('I' . ($i + 3), $result[$i]['delivery_time']);
    $objPHPExcel->getActiveSheet(0)->setCellValue('J' . ($i + 3), $result[$i]['delivery_memo']);
    $objPHPExcel->getActiveSheet()->getStyle('A' . ($i + 3) . ':J' . ($i + 3))->getAlignment()->setVertical(PHPExcel_Style_Alignment::VERTICAL_CENTER);
    $objPHPExcel->getActiveSheet()->getStyle('A' . ($i + 3) . ':J' . ($i + 3))->getBorders()->getAllBorders()->setBorderStyle(PHPExcel_Style_Border::BORDER_THIN);
    $objPHPExcel->getActiveSheet()->getRowDimension($i + 3)->setRowHeight(16);
// Rename sheet
$objPHPExcel->getActiveSheet()->setTitle('订单汇总表');
// Set active sheet index to the first sheet, so Excel opens this as the first sheet
$objPHPExcel->setActiveSheetIndex(0);
// Redirect output to a client’s web browser (Excel5)
ob_end_clean();//清除缓冲区,避免乱码
header('Content-Type: application/vnd.ms-excel');
header('Content-Disposition: attachment;filename="订单汇总表(' . date('Ymd-His') . ').xls"');
header('Cache-Control: max-age=0');
$objWriter = PHPExcel_IOFactory::createWriter($objPHPExcel, 'Excel5');
$objWriter->save('php://output');
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/70916545
