linux下装apache踩过的坑
黄啊码 发表于 2022/06/29 00:31:35 2022/06/29
【摘要】 问:Another app is currently holding the yum lock? 答:rm -r /var/run/yum.pid 问:configure: error: ...No recognized SSL/TLS toolkit detected 答:yum install openssl openssl-...
答:yum install openssl openssl-devel(如果装完还出现这个错误,需要在apahce配置时加入--with-ssl=/usr/local/openssl)
问:checking whether to enable mod_deflate... configure: error: mod_deflate has been requested but c
答:yum install zlib-devel
问:configure: error: APR not found. Please read the documentation.
问:Cannot use an external APR with the bundled APR-util
答:安装apache,加入参数(--with-apr=/usr/local/apr --with-apr-util=/usr/local/apr-util)
[root@web1 httpd-2.2.19]# ./configure --prefix=/opt/apache --enable-deflate --enable-expires --enable-headers --enable-modules=most --enable-so --with-mpm=worker --enable-rewrite --with-apr=/usr/local/apr --with-apr-util=/usr/local/apr-util
1.下载所需软件包:
wget http://archive.apache.org/dist/apr/apr-1.4.5.tar.gz
wget http://archive.apache.org/dist/apr/apr-util-1.3.12.tar.gz
wget http://jaist.dl.sourceforge.net/project/pcre/pcre/8.10/pcre-8.10.zip
具体步骤如下:
 a:解决apr not found问题>>>>>>
   [root@xt test]# tar -zxf apr-1.4.5.tar.gz
   [root@xt test]# cd  apr-1.4.5
   [root@xt apr-1.4.5]# ./configure --prefix=/usr/local/apr
   [root@xt apr-1.4.5]# make && make install
 b:解决APR-util not found问题>>>>
   [root@xt test]# tar -zxf apr-util-1.3.12.tar.gz
   [root@xt test]# cd apr-util-1.3.12
   [root@xt apr-util-1.3.12]# ./configure --prefix=/usr/local/apr-util --with-apr=/usr/local/apr
   [root@xt apr-util-1.3.12]# make && make install
 c:解决pcre问题>>>>>>>>>
   [root@xt test]#unzip -o pcre-8.10.zip
   [root@xt test]#cd pcre-8.10
   [root@xt pcre-8.10]#./configure --prefix=/usr/local/pcre
   [root@xt pcre-8.10]#make && make install
(可能出现g++: command not found,Centos下执行  yum -y update gcc yum -y install gcc+ gcc-c++ ,安装完之后在执行上一步./configure...)
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/76690326
