android多语言切换
黄啊码 发表于 2022/06/29 01:04:54 2022/06/29
【摘要】 string.xml英文<?xml version="1.0" encoding="utf-8"?><resources> <string name="TextView1">ONE</string> <string name="TextView2">TWO<...
  1. string.xml英文
  2. <?xml version="1.0" encoding="utf-8"?>
  3. <resources>
  4. <string name="TextView1">ONE</string>
  5. <string name="TextView2">TWO</string>
  6. </resources>
  7. string.xml中文
  8. <?xml version="1.0" encoding="utf-8"?>
  9. <resources>
  10.     <string name="TextView1">第一个</string>
  11.     <string name="TextView2">第二个</string>
  12. </resources>
  13. </span>
MainActivity.xml
  1. package com.sec.lifeactivity;
  2. import java.util.Locale;
  3. import android.os.Bundle;
  4. import android.widget.TextView;
  5. import android.app.Activity;
  6. import android.content.res.Configuration;
  7. public class MainActivity extends Activity {
  8. TextView textView1;
  9. TextView textView2;
  10. @Override
  11. protected void onCreate(Bundle savedInstanceState) {
  12. super.onCreate(savedInstanceState);// 总是先调用上级类方法
  13. setContentView(R.layout.activity_main);
  14. //默认英文
  15. textView2 = (TextView) findViewById(R.id.textView2);
  16. textView2.setText(R.string.TextView2);
  17. Configuration configuration = getResources().getConfiguration();// 获取系统的配置
  18. configuration.locale = Locale.CHINA;
  19. getResources().updateConfiguration(configuration,
  20. getResources().getDisplayMetrics());
  21. textView1 = (TextView) findViewById(R.id.textView1);
  22. textView1.setText(R.string.TextView1);
  23. }
  24. }
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/50756012
