PHP生成条形码(barcode)
黄啊码 发表于 2022/06/28 22:38:25 2022/06/28
【摘要】      require_once('./barcode/class/BCGColor.php');       require_once('./barcode/class/BCGDrawing.php');     ...
  1.      require_once('./barcode/class/BCGColor.php');
  2.      require_once('./barcode/class/BCGDrawing.php');
  3.      require_once('./barcode/class/BCGcode128.barcode.php');
  4.       $colorFront = new \BCGColor(0, 0, 0);
  5.       $colorBack = new \BCGColor(255, 255, 255);
  6.
  7.       // Barcode Part
  8.       $font = new \BCGFontFile('./barcode/font/Arial.ttf', 14);
  9.       $code = new \BCGcode128();
  10.       $code->setScale(2);
  11.       $code->setFont($font);
  12.       $code->setColor($colorFront, $colorBack);
  13.       $code->parse(I('code','error'));
  14.
  15.       // Drawing Part
  16.       $drawing = new \BCGDrawing('', $colorBack);
  17.       $drawing->setBarcode($code);
  18.       $drawing->draw();
  19.
  20.       header('Content-Type: image/png');
  21.
  22.       $drawing->finish(\BCGDrawing::IMG_FORMAT_PNG);
  23. 所需库下载地址:
  24. https://www.barcodebakery.com/en/resources/api/php/databarexpanded
  25. 个人打包的资源地址:
  26. https://download.csdn.net/download/tiaozhanji_xian/10445456
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/80499148
