List转换为tree-项目真实使用
知识浅谈 发表于 2022/06/29 00:12:22 2022/06/29
【摘要】 前提:数据库中查出来每一条数据构成链表,需要我们转换成树结构,id,pid(父节点的id) name 主要代码:public Node getRoot(List<Node> list) 0为...
0为根节点 1-9为次根节点 1.1-1.9 2.1-2.9 … 为次次根节点 看下方测试结果注意只有0的pid为-1
@RestController
public class AAA {
    @RequestMapping("/project/test")
    public Result get123(){
        Test test = new Test();
        List<Node> list = new ArrayList<>();
        list.add(new Node("0","-1","根节点"));
        list.add(new Node("9","0","9"));
        list.add(new Node("9.1","9","9.1"));
        list.add(new Node("1","0","1"));
        list.add(new Node("1.1","1","1.1"));
        list.add(new Node("2","0","2"));
        list.add(new Node("2.1","2","2.1"));
        list.add(new Node("3","0","3"));
        list.add(new Node("3.1","3","3.1"));
        list.add(new Node("3.1.2","3.1","3.1.2"));
        Node root = test.getRoot(list);
        Result<Object> result = new Result<>();
        System.out.println(root);
        result.setResult(root);
        return result;
class Node{
    String id;
    String pid;
    String name;
    List<Node> children;
    public Node(String id,String pid,String name){
        this.id=id;
        this.pid = pid;
        this.name = name;
        this.children = new ArrayList<>();
    public List<Node> getChildren() {
        return children;
    public void setChildren(List<Node> children) {
        this.children = children;
    public void setId(String id){
        this.id = id;
    public void setPid(String pid) {
        this.pid = pid;
    public void setName(String name){
        this.name = name;
    public String getId() {
        return id;
    public String getName() {
        return name;
    public String getPid() {
        return pid;
class Test{
    public Node getRoot(List<Node> list){
        Node root=null;
        Map<String,Node> map= new HashMap<String,Node>();
        for(Node n:list){
            String id = n.getId();
            Node node = map.get(id);
            if(node==null){
                node = n;
                map.put(id,n);
            }else{
                node = map.get(id);
                node.setPid(n.getPid());
                node.setName(n.getName());
            String pid = node.getPid();
            if(pid.equals("-1")) { //根结点的判断
                root = node;
                continue;
            Node node1 = map.get(pid);
            if(node1==null){
                node1 = new Node(pid,"-1","头节点");
                map.put(pid,node1);
            node1.getChildren().add(node);
        return  root;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
测试结果
  "success": true,
  "message": "操作成功!",
  "code": 0,
  "result": {
    "id": "0",
    "pid": "-1",
    "name": "根节点",
    "children": [
        "id": "9",
        "pid": "0",
        "name": "9",
        "children": [
            "id": "9.1",
            "pid": "9",
            "name": "9.1",
            "children": [
        "id": "1",
        "pid": "0",
        "name": "1",
        "children": [
            "id": "1.1",
            "pid": "1",
            "name": "1.1",
            "children": [
        "id": "2",
        "pid": "0",
        "name": "2",
        "children": [
            "id": "2.1",
            "pid": "2",
            "name": "2.1",
            "children": [
        "id": "3",
        "pid": "0",
        "name": "3",
        "children": [
            "id": "3.1",
            "pid": "3",
            "name": "3.1",
            "children": [
                "id": "3.1.2",
                "pid": "3.1",
                "name": "3.1.2",
                "children": [
  "timestamp": 1651161878529
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
解释:
  1. 每次先查看map中是不是有id对应的key,如果有的话,说明之前添加过但是添加的对象只有id和children,这时候就需要把对应value中的对象的其他变量赋值,这个为什么只有id一会看到下边就知道了。
    如果没有对应的key是id的话,添加key为id ,value为Node对象。
  2. 1中添加完id对应的Node之后,如果当前id节点的pid节点已存在,则把当前id节点添加到pid节点children数组中。如果不存在,需要先创建一个pid的新节点,并把新节点的id=pid,新节点添加到map中,并把1中的Node节点添加到新结点的children中(知道1中那个为什么只有id和children了吧)。
文章来源: englishcode.blog.csdn.net,作者:知识浅谈,版权归原作者所有,如需转载,请联系作者。
原文链接:englishcode.blog.csdn.net/article/details/124486600
