【黄啊码】PHP在线解密工具,Goto解密工具
黄啊码 发表于 2022/06/29 01:00:29 2022/06/29
【摘要】 黄啊码,一般都是比较简单粗暴的,直接上例子 <?phpdefined("IN_IA") or exit("Access Denied");class yzxcpt_sunModuleWxapp extends WeModuleWxapp{ public function doPagecoupontlist() { ...
  1. <?php
  2. defined("IN_IA") or exit("Access Denied");
  3. class yzxcpt_sunModuleWxapp extends WeModuleWxapp
  4. {
  5. public function doPagecoupontlist()
  6. {
  7. goto RJq8z;
  8. RJq8z:
  9. global $_GPC, $_W;
  10. goto Fd00u;
  11. Fd00u:
  12. $sid = $_GPC["\x73\x69\144"];
  13. goto zEa5k;
  14. zEa5k:
  15. $page = max(1, intval($_GPC["\160\x61\x67\145"]));
  16. goto h9fAf;
  17. h9fAf:
  18. $size = intval($_GPC["\x6c\x65\156\x67\164\x68"]) ? intval($_GPC["\x6c\145\x6e\147\x74\x68"]) : 10;
  19. goto pZcKj;
  20. pZcKj:
  21. $coupon = pdo_fetchall("\163\x65\x6c\x65\x63\x74\40\141\x2e\x2a\40\x66\x72\x6f\x6d\40" . tablename("\x79\x7a\x78\143\x70\164\x5f\163\x75\x6e\137\143\157\x75\x70\x6f\x6e") . "\x61\x20\x6c\x65\x66\164\x20\x6a\157\x69\x6e\40" . tablename("\171\172\170\143\160\x74\137\x73\165\156\137\x73\x68\157\x70\x5f\x63\x6f\x75\160\x6f\x6e") . "\142\x20\x6f\x6e\x20\142\x2e\143\x69\x64\x20\x3d\x20\141\x2e\151\x64\40\167\150\x65\x72\x65\40\142\x2e\163\151\144\x20\75\40{$sid}\x20\141\156\x64\40\141\56\x73\x74\x61\x74\165\x73\x3d\61\40\141\x6e\x64\40\x61\56\x63\x68\145\143\153\x73\x20\x3d\x20\61\x20\141\x6e\144\x20\141\x2e\163\x74\141\164\x65\41\75\61\x20\141\156\144\x20\141\56\x75\x6e\x69\141\143\151\x64\40\75\40" . $_W["\x75\x6e\x69\141\x63\x69\x64"] . "\40\141\156\x64\40\142\56\x75\x6e\x69\x61\x63\x69\144\x20\x3d\40" . $_W["\x75\156\151\141\143\151\144"] . "\x20\154\151\x6d\151\164\40" . ($page - 1) * $size . "\x2c" . $size);
  22. goto vffZo;
  23. vffZo:
  24. foreach ($coupon as $key => $value) {
  25. goto H8EAI;
  26. H8EAI:
  27. if ($value["\163\164\141\164\x65"] == 1) {
  28. goto Yn0N_;
  29. }
  30. goto sCZQr;
  31. sCZQr:
  32. if ($value["\x73\x74\141\x74\x65"] == 2) {
  33. goto h23aY;
  34. }
  35. goto UDLmI;
  36. UDLmI:
  37. $coupon[$key]["\x73\150\x6f\160"]["\x6e\x61\155\145"] = "\xe9\200\x9a\347\x94\250";
  38. goto aaTT8;
  39. aaTT8:
  40. goto KEerh;
  41. goto OdbV7;
  42. OdbV7:
  43. Yn0N_:
  44. goto dMffH;
  45. dMffH:
  46. $coupon[$key]["\x73\150\157\x70"] = pdo_get("\x79\x7a\x78\143\160\164\137\x73\165\156\137\163\150\157\160", array("\165\x6e\151\x61\x63\x69\144" => $_W["\x75\x6e\151\x61\x63\151\x64"], "\x69\x64" => $value["\163\x69\x64"]), array("\x6e\141\155\x65", "\151\163\143\157\x75\x70\x6f\156"));
  47. goto x3KQl;
  48. x3KQl:
  49. goto KEerh;
  50. goto weAfu;
  51. weAfu:
  52. h23aY:
  53. goto s8Iqg;
  54. s8Iqg:
  55. $coupon[$key]["\x73\x68\157\x70"]["\x6e\x61\x6d\x65"] = "\xe9\x99\x90\351\203\250\xe5\210\x86\345\225\206\345\xae\xb6\344\275\xbf\347\224\xa8";
  56. goto PQvO4;
  57. PQvO4:
  58. KEerh:
  59. goto oyZDv;
  60. oyZDv:
  61. IyHnC:
  62. goto Gzoio;
  63. Gzoio:
  64. }
  65. goto Fcg6E;
  66. Fcg6E:
  67. I1y9r:
  68. goto GoLNC;
  69. GoLNC:
  70. $info["\x63\157\x75\160\x6f\x6e"] = $coupon;
  71. goto k3btY;
  72. k3btY:
  73. $info["\x73\x65\164"] = pdo_get("\x79\172\170\143\x70\164\x5f\163\165\x6e\x5f\x76\x69\160\x63\x61\x72\144\x5f\x73\x65\x74", array("\165\x6e\x69\141\143\x69\144" => $_W["\165\156\x69\141\143\x69\144"]));
  74. goto vGEBd;
  75. vGEBd:
  76. $info["\165\163\x65\162"] = pdo_get("\171\x7a\170\143\160\x74\x5f\163\x75\x6e\137\x75\x73\145\162", array("\151\x64" => $_GPC["\x75\x69\x64"], "\165\156\151\141\143\x69\144" => $_W["\x75\156\151\x61\x63\151\144"]));
  77. goto UkXDm;
  78. UkXDm:
  79. $this->return_msg(1, $info, "\163\x75\x63\143\x65\163\x73");
  80. goto GF5Hz;
  81. GF5Hz:
  82. }
  83. }
解密结果:
  1. <?php
  4. {
  6. {
  7. global $_GPC, $_W;
  8. $sid = $_GPC["sid"];
  9. $page = max(1, intval($_GPC["page"]));
  10. $size = intval($_GPC["length"]) ? intval($_GPC["length"]) : 10;
  11. $coupon = pdo_fetchall("select a.* from " . tablename("yzxcpt_sun_coupon") . "a left join " . tablename("yzxcpt_sun_shop_coupon") . "b on b.cid = a.id where b.sid = {$sid} and a.status=1 and a.checks = 1 and a.state!=1 and a.uniacid = " . $_W["uniacid"] . " and b.uniacid = " . $_W["uniacid"] . " limit " . ($page - 1) * $size . "," . $size);
  12. foreach ($coupon as $key => $value) {
  13. if ($value["state"] == 1) {
  14. $coupon[$key]["shop"] = pdo_get("yzxcpt_sun_shop", array("uniacid" => $_W["uniacid"], "id" => $value["sid"]), array("name", "iscoupon"));
  15. } else {
  16. if ($value["state"] == 2) {
  17. $coupon[$key]["shop"]["name"] = "限部分商家使用";
  18. } else {
  19. $coupon[$key]["shop"]["name"] = "通用";
  20. }
  21. }
  22. }
  23. $info["coupon"] = $coupon;
  24. $info["set"] = pdo_get("yzxcpt_sun_vipcard_set", array("uniacid" => $_W["uniacid"]));
  25. $info["user"] = pdo_get("yzxcpt_sun_user", array("id" => $_GPC["uid"], "uniacid" => $_W["uniacid"]));
  26. $this->return_msg(1, $info, "success");
  27. }
  28. }
操作方式:
 工具地址,有问题可 v*x:ama-huangama
 https://download.csdn.net/download/TiaoZhanJi_Xian/33997440
文章来源: markwcm.blog.csdn.net,作者:黄啊码,版权归原作者所有,如需转载,请联系作者。
原文链接:markwcm.blog.csdn.net/article/details/120920475
